Old 05-31-2012, 09:07 PM   #301
shadow1967
shadow1967's Avatar
Re: My long term 57 project
Are your round a/c vents vintage air? Also, do they open and close?
Thanks for your help and info as far as the dash install,
Mike and Dad
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 05-31-2012, 09:09 PM   #302
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Mike and Dad
They are from VA, and no they do not open or close, just swivel.
ChuckDriver is offline   Reply With Quote
Old 11-09-2012, 11:36 AM   #303
Chevette
Chevette's Avatar
Just finished reviewing your build. Very nice indeed. Your attention to detail is excellent. So many details that look great, but the rear tubs will have me checking eBay. Wow!
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 11-10-2012, 10:34 AM   #304
ChuckDriver
Thanks Chevette, I appreciate that!
Old 11-10-2012, 04:29 PM   #305
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by hammerdog57 View Post
I just reread your build thread and had some questions. Do you have any more pics of your battery box? Looks stationary. How easy is it to access battery? And last how well does trans cooler work?
Hi JJ, Long time no talk!
I was just admiring your truck again and the questions about your battery relocation & photos got me wondering about how you routed your battery cables?
I plan to relaocate mine too and I've wondered where to get long cables? Should I plan to make them myself and if so, what/where do I get the heavy cable and good heavy clamps? How to SAFELY routed/ tie down the cables along the way? ANy advice and photos would be a real help.
Man, I just flat LOVE your truck. The stance is EXACTLY what I'd like to have on mine.
Dan in Pasadena is offline   Reply With Quote
Old 11-10-2012, 06:57 PM   #306
danheit
danheit's Avatar
Dan, sorry to step in where it may not be warranted, but in the off roading world, we get our heavy duty battery cables from welding shops. Welding cable 1/0 is great for battery cables, and carries all the current you will ever need. The welding shop can most likely crimp your ends on with a bench top crimper. Just make sure they use weather tight connections and use the heat shrink for the ends that has glue in it. Hope that helps!
1955 Chevy 3100 Task Force Pro Street - Sold!
1957 Chevy 3100 Task Force "Rat Rod" a.k.a. SLOTH - Sold!
1971 C10 Longbed factory A/C all stock 350/350
1979 Jeep CJ7 - Build date on the day I was born! -Keeper
2004 Expedition - Family Hauler
2007 Accord - Wife's around towner; I have more but not enough lines to post them!
danheit is offline   Reply With Quote
Old 11-10-2012, 07:08 PM   #307
Dan in Pasadena
It helps a lot, thank you very much. Are you saying any sort of shop that does welding, or are you talking about a welding SUPPLY place?
I still would like to see photos of how JJ (or others) routed their cables so they have the shortest run possible (does a foot either way much of a difference?) and the least chance possible of shorting and causing a fire?
Old 12-10-2012, 09:10 PM   #308
butchp
Originally Posted by robozride View Post
anyone looking to do the same set up....I have a set of these tubs from a 1965 truck same color and all, pm me
Do you still have them and how much I am in Tennessee/
butchp is offline   Reply With Quote
Old 12-10-2012, 10:02 PM   #309
ChuckDriver
Dan I apologize for the delay in getting back to you. I'll have an updated picture of the routing soon!
Old 12-10-2012, 10:03 PM   #310
ChuckDriver
ButchP, I'm pretty sure the 65 tubs are NOT the same as the 67-72 Suburban tubs that I used!!
Old 12-10-2012, 10:08 PM   #311
butchp
Thanks was the tank you used a ut-n-3 from tanks.
Old 12-10-2012, 10:24 PM   #312
ChuckDriver
It looks more like the U4 model, but th UT-N-2H also looks like it would work as well.
Couldn't find the -3 on their site.
JJ
Old 12-10-2012, 10:28 PM   #313
butchp
JJ
I am sorry I ment -2
UT-N-2
Old 09-24-2013, 08:18 AM   #314
L_Brown
L_Brown's Avatar
I want to move my springs under the frame, any info you could provide would be killer.
Here are a few pic's of the rear suspension. I want to run a wider tire and rim than stock and keep them tucked under the fenders. I saw an article in Classic Trucks a few years ago for a mono-leaf kit that I think fits the bill perfectly. It's been so long ago when I bought it that I don't remember who I bought it from. I do have nearly 10 years worth of magazines that I would have to look through to find the article. Maybe someone here will recognize it!
It was very easy to install and came with everything needed to put it in.
The rear is from a 69 chevy car and it's a 12 bolt. I've since had it shortened by Moser who also added a 373 gear with a Tru-Trac Posi. It also now has Ford big bearing axle ends and faxles.
I also put a big brake kit on it from Master Power brakes. And ran SS brake lines.
Here are the pic's!!
JJ
Larry Brown
North Texas
My 1956 Build - Huff Truck
http://67-72chevytrucks.com/vboard/s...48#post6308448
L_Brown is offline   Reply With Quote
Old 09-25-2013, 03:12 PM   #315
ChuckDriver
L Brown,
I dont have anymore info on the kit I used. I guess the manufacture must have gone out of business soon after selling it. I've never seen another one like it.
As far as putting your springs under the frame I have seen it done by using the hangers and shackles from the front end used on the rear under the frame mounted in reverse. What I mean is that the rear mount for the front spring is used as the forward mount on the rear spring.
I'm sure there has to be another kit out there that would do the same thing, or maybe adapt a setup from a late model truck, maybe an S-10?
Did a little research and found this!! Look at Kit #16117
http://www.fatfenderedstreetrodshop....alog/17/17.htm
Hope this helps!
Old 09-25-2013, 06:47 PM   #316
L_Brown
L_Brown's Avatar
Thanks, it was a big help. I called them and he was installing that kit on a truck. They have a complete kit with springs, shocks, mounts as well. He said they made it to fit wider tires.
Kit is $589.95 # 16014
L Brown,
Hope this helps!
Larry Brown
North Texas
Old 10-21-2013, 10:21 PM   #317
ChuckDriver
Well I haven't done much to my 57 lately so I decided it was time for a little upgrade! Will have more pics as I do the install, a first for me so wish me luck!
Going to the GoodGuys show at Lowes Motor Speedway this weekend, hope to get some ideas and a few items!!
Old 10-21-2013, 11:22 PM   #318
oldman3
oldman3's Avatar
Looking forward to the install...Jim
oldman3 is offline   Reply With Quote
Old 10-21-2013, 11:24 PM   #319
L_Brown
L_Brown's Avatar
What size are you front wheels and tires?
Jamie, I didn't C-notch the frame. The rear end housing is 3in below the frame rail. It comes very close to bottoming out if you bounce up and down on the bumper.
My rear wheels are 16x10 with 4in back spacing The BFG's are 285/60R16. If I had the 15x10 I would go with a 295/50 for more width. Just for your info my rear end measure's 57 1/4in flange to flange.
Larry Brown
North Texas
Old 10-21-2013, 11:58 PM   #320
hotrod1
56 - autocross
hotrod1's Avatar
What unit is that? Looks like the compact.
hotrod1 is offline   Reply With Quote
Old 10-22-2013, 12:54 AM   #321
Kim57
Kim57's Avatar
Be sure and post lots of pics as I will have to do this on mine.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-23-2013, 09:49 PM   #322
ChuckDriver
Fronts are 15x8 with 4in backspacing, tires are 235/60's!
Old 10-23-2013, 09:55 PM   #323
ChuckDriver
It's the Universal Gen IV Magnum. Went with the Universal instead of the Surefit model because of my Impala dash!
Went with 3 outlets on the end as I only have 3 vents in the dash.
Old 10-23-2013, 09:57 PM   #324
ChuckDriver
Me too!
Old 10-23-2013, 09:58 PM   #325
ChuckDriver
Kim
I'll do my best!
