06-18-2011, 12:05 AM | #301 |
Re: '72 Chevy SWB, Project Driver
watched the movie for the first time it sounded awsome, shes quiet for open manifold! mine was alot louder!
06-19-2011, 12:53 AM | #302 |
6>8 Plugless........
Looking good! Good to hear the guy you purchased the column from had insurance on it!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
06-22-2011, 06:46 PM | #303 |
Has more rust than truck...
Got the MAF wires ran across in the wire gutter on the core support and then finished bundling and securing the wires from the engine to the PCM. Then took her on her maiden voyage Two laps around the block, added some more coolant then off to the gas station for gas and some trans fluid. Plenty of power Gas fill leaks though
06-22-2011, 08:54 PM | #304 |
made in america
we get some visual proof soon right?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree 2004 corvette- lowered, borla, tuned. slow my old girl 1966 c10- 305v8, t-5 sold |
06-22-2011, 11:09 PM | #305 |
Still Learning
Glad to hear you got the maiden voyage out of the way. Any chance we'll see a burn out video?
06-23-2011, 11:28 AM | #306 |
Video(s) will be posted as soon as I get a chance and find a place to do it. This thing is LOUD when you get on it! Maybe I should work on exhaust
I pulled two codes out of it last night after my gas trip. P0643-fuel level sensor......should have been turned off in the computer P0650-Check engine light, need to buy a led for this. Oh, the hydroboost brakes.....holy (fill in the blank) This thing will stop on a dime! I have never driven a truck that has this good of brakes. |
06-23-2011, 12:09 PM | #307 |
Master Procrastinator
and my question is do you need new rear tires already? congrats, didn't take long for you to get it put together at all
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project Last edited by tantrumpipeline; 06-23-2011 at 12:10 PM. |
06-24-2011, 10:01 PM | #308 | |
Did a bit of wiring in the cab today-finally hooked up the wiring to the brake switch so the torque converter will lock. Had a little help... Then took her on about a half hour cruise. No burning this time, just a nice cruise. The thing is just so smooth! I did get stuck in some traffic and I was worried the fan was too far away from the radiator, but she stayed under 200. More pics sometime this weekend. Last edited by usmcchevy; 06-24-2011 at 10:02 PM. |
06-26-2011, 11:19 AM | #309 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
06-28-2011, 10:07 PM | #310 | |
I know, I'm slacking on pictures I guess I'm just enjoying it too much. I threw some plywood in the bed and used it to haul 600 pounds of scrap metal to the scrap yard today. I'm still amazed how nice it drives! On the way back from the scrap yard I stopped into a couple exhaust shops for quotes(350-450). I think I'm going to use these mufflers: http://www.summitracing.com/parts/PYE-MVR33/ Any input? |
06-29-2011, 11:05 AM | #311 | |
For about the same money you can get the Hooker Aero Chamber mufflers. They perform well in the dyno tests and sound great. I have put them on two vehicles of mine in the past and really liked them. http://www.summitracing.com/parts/HOK-21502HKR/ There are video clips on youtube of various vehicles with them for you to hear them for yourself.
07-01-2011, 07:50 PM | #312 |
Kvn1011
[QUOTE=usmcchevy;4682317]Been too busy lately! Thanks guys, I hope to get 17+mpg
Made the spacer for the hydroboost. You can kinda see it in there cool build!! i picked up a hydroboost from a 94 astrovan last week and was curious on where you picked up your hardlines, or where you may have found your fittings?? and also what did you use for the extension to reach the brake pedal?? thanks kev here the one that i just got |
07-02-2011, 03:59 PM | #313 | |
[quote=kvn1011;4766622]
Thanks! The pressure line from pump to HB unit is from a 85 C/20 diesel. The pressure line from HB to steering gear is made from Jegs teflon AN-6 hose with adapters(forgot what size). The mounting plate and extension came from this guy: http://www.ifsja.org/forums/vb/showt...ght=hydroboost Then the little spacer I made that goes in the master cylinder hole is made from a cheap 3/8" extention 1 1/16" long. |
07-03-2011, 11:41 AM | #314 | |
[quote=usmcchevy;4767792]
07-03-2011, 11:48 AM | #315 |
Kvn1011
awesome!
thanks you sir!! |
07-09-2011, 10:45 PM | #316 |
Bought this today, guy is going to sandblast it for me and I pick it up next week.
Long ways from perfect, but workable. |
07-10-2011, 03:15 AM | #317 |
this one is actually better then yours? doesnt look like it! lol
07-10-2011, 10:18 AM | #318 | |
07-10-2011, 11:55 AM | #319 |
Grandpa in the rustmobile...
wow never seen a truck rust perfectly in half
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-10-2011, 02:15 PM | #320 |
VA72C10
that bed looks pretty solid to me...
...will be interested to see how it looks after sandblasting. I had a cab that looked almost rust free....but as I sanded it...the metal disappeared
Looking for a 67-72 swb or blazer project in or around VA. |
07-10-2011, 03:10 PM | #321 | |
I guess I should re-word I gave him a small deposit to pay for blasting and I will give him the balance once its done and it there is still a floor left. Oldblue, It was rusted perfectly in half right at the front bed crossmember. I just made the hole a little bigger for easy access to other things. |
07-10-2011, 07:26 PM | #322 |
07-11-2011, 11:21 AM | #323 |
I hope you end up with a good bed after the blasting is done. It's amazing what you will find under the paint some times.
I found chicken wire & card board covering a rust hole the size of a softball in a door once. It had about a gallon of bondo in the door alone. It didn't look too bad with a coat of paint on it.
07-16-2011, 07:33 PM | #324 |
Got a real good deal on these gauges, paid ~25% I will need to buy a tach and get the correct gas gauge.
http://www.jegs.com/i/Auto+Meter/105/1402/10002/-1 So started working on this Thinking about leaving the button and making it the trip/reset button for the speedo. |
07-16-2011, 08:27 PM | #325 |
That's what I'm making mine out of too. Pretty cool idea for the button.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
