Old 09-23-2012, 12:09 AM   #301
Low Elco
Re: Boppa's old yeller truck
Been lookin-all grounds sanded greased and tight. Light signal good from switch. I dunno. Works when it wants to. I dunno.
Low Elco is offline   Reply With Quote
Old 09-23-2012, 08:29 AM   #302
c10327
c10327's Avatar
do you have disc on the front or drums ? I have had issues with the rubber brake line collapsing inside an not allowing the fluid to go either way just a thought . one issue i am having with mine an will change for next summer !! is the motor that came with my truck 327 has to big of a cam an is radical to were it should have a stall convertor .
the guy I bought the truck from didn't have a clue to what was put into the motor for up grades . my bro inlaw has a 350 punched 40 over all new short blk an a nice set of edelbrock alum heads which should perk it up a little with a lower end cam .. love the truck jus have to feather the throttle at stop lights to keep it running which keeps the wife from wanting to drive it maybe I should keep it that way !! ha ha not
c10327 is offline   Reply With Quote
Old 10-01-2012, 07:10 PM   #303
disturbinglykool
disturbinglykool's Avatar
I just love the paint on this one.
disturbinglykool is offline   Reply With Quote
Old 10-01-2012, 08:10 PM   #304
Low Elco
Thanks! It's a LOT of yellow. We had another burned out headlight. General consensus is we need a 3.73 rear, which ought a really make it a tire fryer. Still have some loose ends to tidy up. Boppa redid the brakes, and he thinks the bearings were just too tight. It was weird, I was up there Sunday and he had yeller in what was its usual spot and it was weird seeing the truck we'd always talked about instead of a rusty beat down POS.
Old 10-01-2012, 08:17 PM   #305
jlsanborn
jlsanborn's Avatar
That's gotta feel good. Nice job man, props!
Couple Chevy's
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 10-01-2012, 08:19 PM   #306
Low Elco
Thanks, now to fix up Big Blue and get the pole out of my butt about LBT!
Old 10-15-2012, 09:21 PM   #307
Low Elco
Finally an update with pics! Here's some shots from the Truck Nationals.
67-72 Forum crowd checking out Yella-They approve!
Finally got all of the &%$#@!$ bedliner shot the thurs before the nats
Name:  IMG_2916 (1024x768).jpg
Boppa in his natural habitat! Neighbor Jay just hangin' out!
Name:  IMG_2922 (1024x768).jpg
The whole gang-
Name:  IMG_2931 (1024x768).jpg
Boppa sez-See Ya!
Name:  IMG_2941 (800x487).jpg
Old 10-15-2012, 09:23 PM   #308
VA72C10
VA72C10
VA72C10's Avatar
cool...glad you're getting to enjoy it now!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-15-2012, 09:40 PM   #309
Low Elco
Now for the real update- Stereo still a mess. Alternator lost the voltage regulator and almost blew up the battery on a fishing trip last thurs. Literally. Acid boiling out the vents. Thankfully he stopped at Uncle Matt's bodyshop (right by the lake) and washed it down. Long story, but minimal damage, except to Boppa, who was just sick. It's all ok, though. I went up on Sunday and put more and better ground straps throughout. 14.5 volts at 3000 rpm, all is good. Biggest issue is a Throbbing vibration at around 60-65. I dunno, but WUBWUBWUB, big vibe! Didn't have time to climb under for that on Sun, so I guess it's the next thing. It's still in the fight, though!
Yeller in it's new home- it used to live outside. Not no more, according to Nanny!
Name:  IMG_2968 (1024x768).jpg
Yours truly attaching cab grounds-
Name:  IMG_2969 (1024x768).jpg
Fat guy down! 10-23! Fat guy in distress! (apologies to Katt W)
Name:  IMG_2974 (1024x768).jpg
The culprit- all fixed and shined back up
Name:  IMG_2975 (1024x768).jpg
Old 10-15-2012, 09:42 PM   #310
Low Elco
Thanks! Still debugging, but it's at least together and on the road!
Old 10-15-2012, 10:50 PM   #311
litew8
litew8's Avatar
You should have known to check the ground straps, electrical etc..!
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 10-15-2012, 11:19 PM   #312
Low Elco
Oh, I had them, all sanded and tight and all that. Just not as many or as nice as I would have liked. These are 4ga. welding cable and copper ends, encased in electric grease, and multiples of same. Much mo betta! The Alternator was 12 years old and needed a bearing anyway, which it got. The regulator crapping out was a bit of a surprise, though. Hi Lite!
Old 10-16-2012, 12:43 PM   #313
litew8
litew8's Avatar
Old 10-16-2012, 12:47 PM   #314
jlsanborn
jlsanborn's Avatar
Boppa sez-See Ya!
Attachment 999089[/QUOTE]
Best photo in the thread right there!!!!! Cool - very,very cool!
Damn good thing that batt didn't rupture too! Glad to hear you're working the kinks out.
Old 10-16-2012, 01:05 PM   #315
Low Elco
Yeah, I liked that shot too. Took it while following him out in LBT. He was shaking his head at me because I left the park sideways....pulling a trailer... in front of a cop. It was a good day.
Old 10-20-2012, 10:35 AM   #316
jlsanborn
jlsanborn's Avatar
Sideways pulling a trailer..... THAT I'd like to see!!
Old 10-20-2012, 11:15 AM   #317
Low Elco
In all fairness it's a small trailer, and the road was dusty from construction.
Old 10-20-2012, 12:37 PM   #318
litew8
litew8's Avatar
Old 10-25-2012, 01:10 PM   #319
Low Elco
Small update- Yeller is now in Neighbor Donnie's garage, so I can debug-at-will. When I showed up with it, donnie gave it a pat and told it "welcome home" Vibration is still present, I have a thread going under driveline. Currently on the hunt for a 3.73 rear to maybe up the R's a tad and get better MPG, which was the whole point. Have vibe narrowed down to worn rearend yoke or shocks (which are WEAK) allowing suspension to oscillate. If we swap rear, probably going to lower a tad, and might rework trailing arms, they need blasted and patched up. Might get some more work in this weekend.
Old 11-04-2012, 11:40 PM   #320
Low Elco
Another update- Got a 3.73 rear today- have to clean it (Yech!) and put a new pinion seal in it. Think I found a clue about the driveline, replaced the loose front ujoint, then Saturday I jacked up the truck, leveled the frame and found just about every number involved with the driveline to be wrong. Apparently it's running in a straight line through the joints, which my research says is bad. Soooo, I gots some shimmin' to do. Looks like an exciting near future for ol yeller. Hope to hell this works.....
Old 11-05-2012, 04:03 AM   #321
jlsanborn
jlsanborn's Avatar
Hmmmm.... I've heard the same thing and my understanding of that theory is that if there ain't no angle of the dangle the roller bearings never roll and ur always mashing on the same couple little guys. I wouldn't expect any vibration tho until they're shot. I'm sure you've eyeballed the intermediate bearing..... Drive shaft aint tweaked is it? I think you can re-clock the two too? If so, did you witness mark the two shafts when you tore it down? Just thinking out loud here... If your joints are tight maybe take the whole mamba-jamba in for balance???
Old 11-05-2012, 07:40 AM   #322
Low Elco
Sorry, one piece shaft, has already been cut and balanced. New ujoints.
Old 11-05-2012, 11:37 AM   #323
Low Elco
Confabbed with my boss, who builds 2,000 hp 11.5 Outlaw cars ground up, and he says I'm on the plan. A big 4x4 guy at work says the same. Just ordered the shims, tech guy at the roundy-round place says I'm on the right track, oughta be a fun weekend! Gawd I hope this works.
Old 11-05-2012, 02:00 PM   #324
Xeen
Xeen's Avatar
I hope all goes well with the Driveshaft, any more bugs to be worked out before its 100%?
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 11-05-2012, 04:05 PM   #325
Low Elco
Ummmm, lessee..... New blower motor works when it wants to, stereo still buzzes, drive shaft throb, drivers window hard to roll up, gulps gas more than it should, need to put nice wheels back on, need to put 3.73 rear in, huge passenger side wind whistle. I think that's it.
