Old 05-17-2015, 02:24 PM   #301
ryanroo
ryanroo's Avatar
Re: My 56 6bt 4X4 build.
I like an 1/8" toe in or so on the tread of the tire. You want some toe in. None or out and it will wander
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-17-2015, 10:40 PM   #302
mud.man.rj
mud.man.rj's Avatar
Most all older trucks/cars were a 1/16" toe in.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 05-18-2015, 03:08 PM   #303
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Until you get to a truck with wider tires. Then 1/8" seems to be a standard. On big dump trucks and semis with super singles we'd go up to 1/4" or 5/16" depending on how the truck drove.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-18-2015, 03:09 PM   #304
Dieselwrencher
Originally Posted by 6BT 56 View Post
So I'm going to get under the truck this afternoon and try to do the alignment myself. Any one have any comments on where to set it ? Dead straight? Toed in a bit ? Haven't had too much time to drive it yet. Seems I'm always in the big truck these days with a boat hooked on the back. The end is in sight tho. Then only 10 weeks and it will be time to pull all the boats back out again . Lol.
Wow, is that your entire summer season and then it gets to freezing again?
Ryan
Old 05-18-2015, 10:53 PM   #305
6BT 56
6BT 56's Avatar
Not so much that's it's freezing but boat traffic deffinately goes down by 70% once the kiddies go back to school in September. True boaters will try for October but not too many try for that long I think I stored 55 this year and more than half are still in the shed.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 05-27-2015, 02:39 PM   #306
Green 1959
Green 1959's Avatar
What is your camber at? If its positive you will eat your tires with a aggressive toe in.
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 05-27-2015, 03:52 PM   #307
6BT 56
6BT 56's Avatar
Me thinks it's at abt 4 deg. The front springs on this truck are dead flat so,I put some 4 deg shims in there when I put new springs and bushings in the front . The dodge this axle came out of had springs that were deffinately higher in the front thus it got the 4 ish deg with no shims . Still haven't done it yet. Just no dam time !
Old 05-30-2015, 12:49 AM   #308
lower50's
lower50's's Avatar
Looks like a sweet truck. I'll read your whole build soon didn't want to loose it. Fellow Ontarian.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 07-19-2015, 10:14 PM   #309
6BT 56
6BT 56's Avatar
So I was on a detour the other day due to construction and happened across this 85 K20. 6.2 diesel Th400 208 .etc. Looks ugly as heck but look further and this things rock solid.
Old 07-19-2015, 10:22 PM   #310
6BT 56
6BT 56's Avatar
There's none of these left up here in any kind of restorable condition.
Turns out this one came up from pieces from Fl. Rock solid all over. The bed has been punched in at some point in the left rear corner and has a bunch of bondo in it. That's better than rust tho
Old 07-19-2015, 10:30 PM   #311
6BT 56
6BT 56's Avatar
So I took a chance. Truck had been in a lean to for almost 10 years . Started and driven around farm on occasion. I bought it as is where is and took a chance. The guy was planning on building it some day so he did all the mechanical. Brakes , front end , fluids and filters etc. Got it home ans took the cap to the dump. Spent abt 3 hrs with the hotsy . Threw in a few batts and off we went . Runs ok. Has a miss on the drivers side bank. The more I run it the better it gets so I assume a cranky injector. The oil cooler lines blew off also. Bypassed for now.
Old 07-20-2015, 07:59 PM   #312
Dieselwrencher
That should make for a nice grocery getter!
Ryan
Old 07-20-2015, 10:56 PM   #313
6BT 56
6BT 56's Avatar
That's abt all I have in mind for it for now. I'm just trying to get a good look at what I have. Got lots of little stuff working now. Need to take the dash out to see why oil pressure gauge is pegged and the voltage gauge reads lower than voltage actually is . I will get a exh on it soon then I can go,put some miles on it and see what I really have .
Old 07-21-2015, 12:13 PM   #314
gerfunken
gerfunken's Avatar
Not trying to be mean, but there's an uncanny resemblance....
Could it be.....
The long lost.....
Bride of Frankentruck?
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 07-21-2015, 12:32 PM   #315
6BT 56
6BT 56's Avatar
Could be . You know the age old question . Does the carpet match the drapes ? Well this ones just as ugly on the inside aswell. Lol.
Old 07-21-2015, 05:55 PM   #316
BK4020
Originally Posted by gerfunken View Post
Could it be.....
The long lost.....
Haha yeah sounds about how most of the ones around here look too, took me awhile to get mine, suppousedly came from down south. The underneath looks flawless yet. The salt they put on the roads wrecked most of the square bodies long ago.
84 gmc 1500
BK4020 is offline   Reply With Quote
Old 07-21-2015, 07:02 PM   #317
gerfunken
gerfunken's Avatar
It was the white zig-zag pattern down the side that made me think of it. Looks like the vinyl wrap started peeling off.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 07-21-2015, 07:27 PM   #318
brimc
brimc's Avatar
Very nice. I like the square bodies. Very true they are not very plentiful up here that haven't been hit hard with the rust. Good score!
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 07-21-2015, 09:07 PM   #319
mud.man.rj
mud.man.rj's Avatar
Almost no squares left where I live, only 2 lately were mine, one went out of town and sold the 86 shortbox to a young fellow as his 1st project...ever, so couldn't say no to a future truck guy.
5.0 4spd std.
7" lift w 35's.
Old 08-01-2015, 01:36 PM   #320
6BT 56
6BT 56's Avatar
So I came across this truck the other day . A guy I worked with years ago had it . I had plans for my 6.0 LS and a single turbo . When I went to look at it I was so,disappointed . He had left it sitting in his back,yard on the grass for the last 6 years . Was so nice years ago . Just shot underneath . Cab mounts , floors etc . Junk . It will make a great parts truck tho for the k 20. I better get a thread started for that thing
Old 08-01-2015, 01:37 PM   #321
6BT 56
6BT 56's Avatar
After a good scrub
Old 08-02-2015, 08:07 AM   #322
brimc
brimc's Avatar
Looks like you got a lot of great parts between the two of them. A complete parts truck would be way better than looking at single parts to buy. Wish I could have done this. Great score
If you buy anymore I'll know where to get parts for mine
BRIAN
Old 08-02-2015, 01:48 PM   #323
BK4020
Looks good, I've got the fever too, cant beat a good parts pickup! I get some grief from friends and family with all these parts pickups I bring home getting ready for my project. I should have some extra stuff to sell or barter with when or if I ever get done.
84 gmc 1500
Old 08-03-2015, 08:55 PM   #324
Dieselwrencher
Nice new to you parts rig! That still looks nice compared to the stuff setting down here. Turbo LS? You have the same issues I have I think. LMAO!
Ryan
Old 08-03-2015, 10:48 PM   #325
6BT 56
6BT 56's Avatar
Ever since the rear frame fell out of the wife's 6.0 l burb I have needed to,put that 6.0 somewhere. I haven't done a efi standalone swap before so I thought it would be a good fun learning project . Check out sloppy mechanics on you tube. These guys are building 10 sec cars on junkyard parts and kraft dinner budgets. My kind of people for sure. Can you imagine running 10's in a ford fairmont with no cage and no c clip eliminators . Once would be enuf I think . Lol.
4x4, cummins, napco
