Old 08-01-2016, 01:48 AM   #301
62stepside longbox
62stepside longbox's Avatar
Re: The Snortin' bull
Is that the bolt that holds the box to the frame?
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 08-01-2016, 05:19 AM   #302
That doesn't look familiar too me. Is your power steering the original ram style? All I have ever dealt with is the later model power steering boxes that have been added on.
Old 08-07-2016, 01:35 AM   #303
namloc
namloc's Avatar
It was one of the of bolt thru the frame and into the casting of the steering gear.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 08-07-2016, 01:45 AM   #304
namloc
namloc's Avatar
It is a later gear box. I fab'd an 87' c-10 frt crossmember and suspension into the original torsion x frame ,Look back earlier in build. The gear box is mounted to a boxed frame section on adapter plate's from CPP .It must of flexed. Now I have installed a longer grade 8 bolt thru the old threaded area on the casting of gear box and torqued her down.All part's on the steering are new though the gear box was a reman.
The Snortin' Bull
Old 08-07-2016, 08:09 AM   #305
I went back and looked at your picture and it made sense then
For whatever reason I didn't see it as the mounting tab for the box. I guess I am getting old.
Old 09-03-2016, 12:50 AM   #306
namloc
namloc's Avatar
the last few week's the bull and I been out runnin' around. A half dozen show's and just about 1500 mile's on the clock now.I noticed at nite time people didn't seem to see me from behind well. I now have brightened it up with led taillamp's. I still have not got to installing my frt sway bar.
The Snortin' Bull
Old 09-03-2016, 01:07 AM   #307
namloc
namloc's Avatar
And just for fun. a friend of mine sent some pictures of this truck.Crazy
The Snortin' Bull
Old 09-03-2016, 05:26 AM   #308
I wonder if he can smoke them?
Old 09-03-2016, 12:30 PM   #309
62stepside longbox
He would need 5.14 rear gears with the granny 4spd to do any tire spinning with that
Old 09-05-2016, 08:40 PM   #310
namloc
namloc's Avatar
Came across this burb. Or what is left of it.Still in a driveway of a home. The pacific ocean salt air has ate away most of it. There was a perimeter pile of rust on the ground under it.Long beach Wa.
The Snortin' Bull
Old 09-05-2016, 09:50 PM   #311
62stepside longbox
R.I.P.
Old 09-07-2016, 11:32 PM   #312
namloc
namloc's Avatar
LED update for front lamp's also now.Found some nice frt. socket's with a ground tab to have a good constant ground at NAPA. Full body led bulb's.Like mini chandelier's from another vendor.
The Snortin' Bull
Old 09-07-2016, 11:46 PM   #313
62stepside longbox
Looks great, would you mind giving me a part number? I'd like to do that with my 60 gmc hood
Old 09-08-2016, 11:52 AM   #314
namloc
namloc's Avatar
No problem, Napa socket # ls6469 for frt, in the rear is used lmc led lamp boards . You must use a no load flasher with led lamps , CEC #ef32rl. And have good ground and circuits for all to work well. If you dnt change frt and rear to led you can use a standard flasher though will have to wire in led resistors at the one end to allow flash to function.
The Snortin' Bull
Old 09-11-2016, 02:52 AM   #315
namloc
namloc's Avatar
One item that has bugged me from the beginning with Accuair is that there are two mini fuse's attached right to the main control very closely wired. Even though I made the bed open to access all I just thought it would be a better inside the cab.
The Snortin' Bull
Old 09-11-2016, 03:02 AM   #316
namloc
namloc's Avatar
One detail I did was to put the bed as forward to the cab as I could .As the frame has no flex. It is one of the point's people notice alot .The gap between the cab to bed .
The Snortin' Bull
Old 09-11-2016, 11:49 AM   #317
62stepside longbox
Gap looks way better now, almost like a unibody
Old 09-11-2016, 01:37 PM   #318
Old 09-23-2016, 06:12 PM   #319
namloc
namloc's Avatar
Hood alignment.So when I first got this truck it had the cab on the frame the rest was loose.As most of you that have been thru this the hood is a bugger to get aligned and to sit right.After a couple of hour's I finally got it . Sit's flush and flat.Latche's work flawlessly.
The Snortin' Bull
Old 09-26-2016, 04:59 PM   #320
namloc
namloc's Avatar
The rear diff. started to leak and spot every where, Found that the axle tube's to housing as well as all the factory plug weld's where weeping .Cleaned these , welded and sealed them up.I also made sure the vent is still clear
The Snortin' Bull
Old 10-02-2016, 09:36 PM   #321
namloc
namloc's Avatar
Some more minor electrical . I would like to put in a stereo.ONE that is Bluetooth,usb,ipod etc.Though not to be seen and there is a hole in the dash as the P.O had hacked it. And sticking with the original plan I used all the existing drilled holes in the dash as I am going to with this. Now you see it now you don't.
The Snortin' Bull
Old 10-09-2016, 09:27 PM   #322
namloc
namloc's Avatar
In the Seattle rain the wiper motor siexed up on me. It is the last original electrical part on the truck.I had a job getting the motor out.Now to find a new one.The production date on the dead motor is 3-59.Early for my 1960.
The Snortin' Bull
Old 10-09-2016, 09:36 PM   #323
I used the kit from that Brothers sells. Converted my 1 speed to a 2-speed. It appears quicker than the stock 2 speeds also. It has been very good to me. I cannot remember who actually makes them off the tops of my head, but very good units. It has been tested a good bit in the Mississippi and Louisiana rains. I have had it 2 years on the truck.
Old 10-11-2016, 11:39 PM   #324
namloc
namloc's Avatar
Thank you.i looked into the kit.I also looked a Newport engineering kit.Though still trying to stick a budget kinda thing I worked with what I had.
The Snortin' Bull
Old 10-11-2016, 11:44 PM   #325
namloc
namloc's Avatar
My wiper motor is not made by anyone for reman.though could be restored. I chose to take it a part.It was in good shape internally .I found that a breaker point spring became weak and contacted the inside body.Shorting it out. Greased the gear drive back up and reassembled, Work's again. Ready to reinstall.
The Snortin' Bull
