Old 09-20-2018, 06:42 PM   #301
Russell Ashley
Russell Ashley's Avatar
Re: Columbus..the 1957 IH 4x4..
Very nice work.
Russell Ashley is offline   Reply With Quote
Old 09-20-2018, 08:30 PM   #302
mongocanfly
Post Whore
mongocanfly's Avatar
Thanks Russell and rgun....I do watch and read what mp&c does....I just wish I had 1/10000 of the talent they have....oh and his equipment...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-22-2018, 08:10 PM   #303
mongocanfly
Post Whore
Well my engine mounts finally showed up ...so today was all about getting the engine supported by something besides the cherry picker...
I boxed the frame in the section where the engine mounts are and further forward to the point where the steering box will mount...so I duplicated the same thing on the pass side..I used 1-3/4 dom tube for the main supports...this will later get gusseted and a cross frame brace when I get the steering done...in the 1st pic you can see where i had to bend the support on the driver side to clear the headers...
(wound up using a C6 oilpan)
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-22-2018, 08:42 PM   #304
mongocanfly
Post Whore
Also painted the new battery tray and temporarily hung it on to the firewall to check clearances...it's coming back off for new mounting bolts
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-22-2018, 10:08 PM   #305
Advanced Design
Advanced Design's Avatar
Looks good Greg. Nice beads there too.
Advanced Design is offline   Reply With Quote
Old 09-23-2018, 12:12 PM   #306
mongocanfly
Post Whore
Thanks Doug!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-28-2018, 12:52 AM   #307
mongocanfly
Post Whore
Started working on mounting the hydroboost for some shownuff stopping power...
Had several hurdles to jump to get there...in the 1st pic you can see the old single res master compared to the hydroboost...the hydro is for a early 80s c30...
The 1st issue was the longer snout where the pushrod is...the hydro was way to long ..
In the 2nd pic you can see I made a 3/4" aluminum spacer and a 1/4" steel nut plate..this extra inch is almost good....ill have to shorten the pushrod some but itll be real close...
In the 3rd pic you can see that the orig master also angled down...I'm not sure why they did that but both trucks are that way...so I had to straighten up the plate to get the hydro level...I cut out the old master mount from the firewall plate and welded in the new nut plate...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-02-2018, 02:54 PM   #308
PunishedC10
This thread amazes me. Truly outstanding metal work. I am jealous that I don’t have the skills to do all of the work you have done. This is going to be a work of art when it is finished. It looks like you have tons and tons of time put towards this project.
1964 Coupe Deville(cruiser)
1966 Chevy II Nova 2door Hardtop
1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys
2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s
2000 Trans Am WS6, LS1/T-56, too many mods to list
PunishedC10 is offline   Reply With Quote
Old 10-03-2018, 09:15 AM   #309
mongocanfly
Post Whore
Thanks punished....it's been a adventure for sure....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-13-2018, 04:35 PM   #310
mongocanfly
Post Whore
Well after taking a short break to work on some other projects (1/2mile 5 strand barb wire fence on creosote posts and rebuilt a 12ft disc so I could plant my greenfields)... I got back on the truck...i got the steering box mounted and crossover steering completed...i had to bend a offset in the crossover link to give some extra clearance for the oil pan...it also helped it line up better with the Pitman arm..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-13-2018, 04:42 PM   #311
mongocanfly
Post Whore
Also got the crossover for the motor mounts in as well as the kicker braces...
and got started on the trans crossmember..had to notch one of the tubes on the trans crossmember for bolt clearance.....
got it all fabbed up..and of course...I run out of argon...on a Fri night...it'll have to wait til next week when I get more welding gas..and I'll get it all welded and get some better pics of the crossmemebers with paint on em..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-13-2018, 09:34 PM   #312
Advanced Design
Nice....what are you using for a tube bender Greg?
Old 10-14-2018, 03:34 PM   #313
mongocanfly
Post Whore
Thanks Doug...i finally broke down a couple yrs ago and bought a jd-squared bender and dies....I had always used a bender that I made some 25yrs ago...it worked ok but was slow..not content to leave the new bender alone I modified it by removing all the manual ratchet system and adding a air over hydraulic cylinder to it and changing it from horizontal to vertical bending direction..it's designed to be anchored to the floor or a work table and required a solid anchor to operate the rachet...I built it where it's self contained and relies on no anchor...got it on wheels so I can roll it to wherever I need it...and roll it out to the way when not in use...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-14-2018, 09:52 PM   #314
Advanced Design
Thanks Greg. Started with a really good one and made it better. Great idea!
Old 10-17-2018, 10:24 PM   #315
mongocanfly
Post Whore
Got me some welderup gas so I finished the trans crossmember....turned out purty good...also got a call today that one of the driveshafts was finished so I picked it up and stuck it in...they're still waiting on parts to fix the front and intermediate shaft..going with all brand new parts on the shafts...should have them next week....just like a puzzle ....one piece at a time..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-20-2018, 01:25 PM   #316
mongocanfly
Post Whore
Had a couple of welds I needed to finsh on the engine crossmember...I couldn't get to them with the engine and steering box in place so i pulled those this morn,,,finished the welds and sprayed it down with some paint...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-24-2018, 04:18 PM   #317
mongocanfly
Post Whore
Got the mid and front driveshaft back today..they look great...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-24-2018, 04:20 PM   #318
mongocanfly
Post Whore
Also got my e-brake band back from the relining people...they did a great job...hopefully it'll hold now seeing as to how it wouldn't before..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-01-2018, 07:10 PM   #319
mattfranklin
mattfranklin's Avatar
Beautiful truck and great progress.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 11-02-2018, 12:39 AM   #320
mongocanfly
Post Whore
thanks Matt!!!...im still plugging along...waiting on some parts to show up so I can start some assembly...right now just tying up a bunch of loose ends..not really worth showing
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-02-2018, 04:01 PM   #321
mongocanfly
Post Whore
After alot of searching and bidding I finally scored a set of IH logo mirrors..theyre not perfect but they'll do...I may get em rechromed later on...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-02-2018, 04:02 PM   #322
mongocanfly
Post Whore
Also got my new floor mat and pads in ....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-07-2018, 11:06 PM   #323
67ChevyRedneck
67ChevyRedneck's Avatar
Neat score on the mirrors and very freakin cool motor and trans mounts!!!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-08-2018, 08:35 PM   #324
mongocanfly
Post Whore
thanks Jesse!!!!...I didn't even know that IH had their own logo mirrors til back in the summer...theyre manufactured by yankee mirror and I saw some on ebay while looking for something else...originally I was gonna use west coast style mirrors but I like these much better...I bid on a bunch of em before I got a set...ill getem rechromed later on...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-09-2018, 11:26 PM   #325
Old57
I just read through your build on this. Great work! I need to look around these pages more... I haven't ever been to this section! Glad I found your project here.
My 57 GMC build
Old57 is offline   Reply With Quote
