Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-14-2011, 06:46 PM   #326
VA72C10
VA72C10
VA72C10's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
On the wheels not being centered...that's common with bagged trucks....I ended up having some spacers made to move the trailing arms back (put in between the T/A crossmember and the t/a mount)
Or you can move the whole crossmember back the necessary amount.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-14-2011, 06:50 PM   #327
kev2809
low n' slo
kev2809's Avatar
ah, ok, well that makes me feel better lol...thanks.
i thought i screwed something up! im thinking of switching to 1.5" blocks to keep the bags from getting that flattened out, they just scares me. that flatten out so much, the notch makes contact with the bags. so as soon as i find some 1.5" blocks to trade or buy, ill be swapping those in and straightening the bag up, then fix the shock mounts. gotta do something while the compressor is down...
*edit*
$10.81 and a new v belt later, compressor is running like a champ! ill get on sanding down the doors this week and also repraying the window frame and passenger side door jambs.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-14-2011, 08:45 PM   #328
67chevy1series
67chevy1series's Avatar
well mkevin i think you have the sexiest 67 suburban on the site! you need to sand them doors and install them! it must suck thats alot of roof and body......
67chevy1series is offline   Reply With Quote
Old 02-14-2011, 11:21 PM   #329
kev2809
low n' slo
kev2809's Avatar
lol..im working at it. and yes, i had to take a week of from work to get the quarters and roof sanded down and painted...man that sucked!
i may have found a new way to mount my bags...im thinking of something like this..
a little hard to see but its just the bags moved along the trailing arm, then mounted to a crossmember going across the frame. still thinking about it so i guess well see
-_--_--_ _________
Old 02-14-2011, 11:31 PM   #330
67chevy1series
thats a good idea i bet ou can do that no problem! keep up the good work kevin!
Old 02-15-2011, 12:47 AM   #331
1sik7t2
dave
1sik7t2's Avatar
uuuuuummmmmm!!! don't wanna burst ur bubble but, speaking from experience...the bags mounted to ur trailing arms will work for a while but in the longrun, no good....mine was that way and the driverside trailing arm started to seriously twist, bady so bad we made 6,yes 6 1/4" spacers under that sides bag to make up the difference in lift ended up doing the trianglulated 4 link much better, but lots more work just my opinion( and expereince) build is awesome otherwise checkout my build "dirty burb"
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
Old 02-21-2011, 10:07 PM   #332
kev2809
low n' slo
kev2809's Avatar
well im gonna try another idea...i bought some top mounts that bolt to the side of the frame, just looking for some lowers and ill be getting on it. it basically will let me get a few inches lower, just like the above picture would...just moving the bags outside the frame rather than in between it. i need a lower bag plate that will bolt to the stock coil location, and then ill weld gussets to strengthen it up some.
in the meantime, i got the back passenger door sanded down, inside and out, and primered up. i then hung it, which probably was a waste of 3 people and 20 minutes because i have to replace that rocker lol. hopefully i can get it off without removing the door, but i will if i have to. i did the get the new rocker in as well...
heres a few pics of the past couple of days of work..
-_--_--_ _________
Old 02-22-2011, 12:28 AM   #333
67chevy1series
it is lookin amazing i woulod hate to see it rain! so have you sweeped out all the dirt and threw away all the trash on the inside?
Old 02-22-2011, 07:21 AM   #334
kev2809
low n' slo
kev2809's Avatar
lol ya..i need to hurry and get the doors and glass back in! i ripped out all the carpet seats trash a few months ago...although u probably couldnt tell with all my crap layin in there lol
-_--_--_ _________
Old 02-26-2011, 07:14 PM   #335
Burb
Coordinator of Synchronicity
Burb's Avatar
looking good Kev ... you've made some real head way
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 02-27-2011, 02:41 AM   #336
project 67 sub
project 67 sub's Avatar
lookin good kev
project 67 sub is offline   Reply With Quote
Old 02-27-2011, 07:30 PM   #337
kev2809
low n' slo
kev2809's Avatar
thanks, long time no see! hows the burb coming along?
Originally Posted by project 67 sub View Post
lookin good kev
thanks!
got the front passenger door sanded down and primed, also scuffed the passenger door jambs and front window frame and reprimed that also, i was having compressor problems the first time around..and hung the door! this front door is super tight to open and close...does that mean it needs new pins?
-_--_--_ _________
Old 02-28-2011, 02:42 AM   #338
67chevy1series
oh that looks perfect you can now send me my burb back! haha jk nice burb kev cant wait for you to put the front clip and glass black in
Old 02-28-2011, 08:27 PM   #339
kev2809
low n' slo
kev2809's Avatar
lol..you cant wait...I cant wait!! im tired of all my stuff laying around on the ground lol
well, i got the driver side door sanded all up, only sprayed the inside of it first. bad news is, i ran out of primer! man this sucks..im gonna try to scrape ALL of it out of the can, or at least as much as i can. and try to spray the other side tomorrow. i guess well see what happens, because another gallon is just not in the budget right now
-_--_--_ _________
Old 02-28-2011, 09:22 PM   #340
Slick67
Sofa King Crazy!!
Slick67's Avatar
Kevin....you rock! That burb is lookin sweet!! Can't wait to see some gloss black pinstriping on that flat black!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-28-2011, 11:39 PM   #341
67chevy1series
kevin this burb is so awsome ! hurry up and put that door on! hahaa
Old 03-03-2011, 07:46 PM   #342
kev2809
low n' slo
kev2809's Avatar
and its on! nothing special, but glad its on now! lighting sucked today, so the door looks ugly but its the same color as the rest of the truck (except this 4th door area, for some reason its the only section that was really shiney when i sprayed it)
-_--_--_ _________
Old 03-04-2011, 02:36 AM   #343
67chevy1series
looks good now get the windows and front clip on haha
Old 03-04-2011, 09:38 PM   #344
kev2809
low n' slo
kev2809's Avatar
lol...man ur turning out to be my motivation!
well, since i ran out of primer earlier this week i cant do anything with the rear hatch and gate, and the front clip. sooo...im hopinh i can get my friends cherry picker over and start to pull this motor, clean up and shave the firewall, paint it, then get the my new motor in. BUT, i guess well see what i can do in the next few days, thats a tough one for me to do myself right now.
-_--_--_ _________
Old 03-04-2011, 11:45 PM   #345
jbclassix
Junk Yartist
jbclassix's Avatar
Thats because the fourth door wants to get your attention! It wants to OPEN!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-05-2011, 12:11 AM   #346
67chevy1series
i am glad i can keep you motivated it is such a bad ass burb i cant wait for tit to be finished! wish i was closer i would let you borrow my cherry picker and help you....
Old 03-05-2011, 02:54 AM   #347
project 67 sub
looking sweet
now hurry up lol.
Old 03-10-2011, 11:19 PM   #348
pickup67man
pickup67man's Avatar
nuff said.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
Project Family Hauler
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 03-21-2011, 12:09 PM   #349
kev2809
low n' slo
kev2809's Avatar
lol...u guys are funny. no progress to report...kinda sucks. been REALLY tied up lately and havent done squat. i did get to move it back in the yard on to some "level" ground...snapped a few pics. im still trying to get the back hatch and tailgate and jamb sanded down and sprayed...until then, this will have to do
-_--_--_ _________
Old 03-21-2011, 06:45 PM   #350
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hey Kev! That burb is just sick!!! I want one so bad.......
