Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-17-2014, 09:30 AM   #326
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Went to Pine Valley raceay last weekend . I was .005,.007,.005 and first round it rolled in 2 " i was .-031 red . Bought back and set up .020 in the long throw i was .031 and didnt drive the strip and broke out . Truck has been spot on most of the time , but would rol in nw an then and b .050 late every once and a while . Pulled he trans out hda ook atit . .035 loose in the reverse clutch pack Missing one o rig on the inpt shaft and part of the other . Reverse pack apply springs were mixand match . Dump chamber passage got messaged to get the fluid out faster. Total reseal inside . clutch pcks looked great . I have nevr had his trans apart , i just bought it and threw it in . Pics .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-14-2014, 11:11 AM   #327
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Ran a 7.0 index race since the season was over and i was actually able to do well . I was number 1 qualifier with a 7.008 . My lights were in the .050s on .4 proo tree . 3 rd round i creamed the guy on the tree , but it spun when it came down from the wheelie . I drove it out to a 7.24 loss . Slicks where bald and to the cords . Just thought i had enough left to run on more race . Cords showing . Oh well .
About done for the season . Division 4 bracket finals this weekend in Ennis, Texas . Of coarse i have to change up the truck to try and footbrake it at this one race . I am putting the slicks off the S-10 in it just for this weekend .
Plans for the winter are to buy a block and a set of pistons and build the "new" motor that i broke first of season . Looks like im going around 410-412 inch and 11.5-12 to 1 . Also swapping to E-85 with this change . Alot depends on the rules for next year . Im going to ask the Div 4 director at the bracket finals how the 2015 rules are going to be and build from there . Either No box or footbrake . I ought to put a delay box in it and move to electronics for the weekend .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-14-2014, 04:43 PM   #328
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I got the heads back from Ricky at slick ricks racing heads in magnolia . He did a great job on the repair . They look like new and have 3 new valves and valve job . Damage for head repairs $690 .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-14-2014, 11:33 PM   #329
djracer
djracer's Avatar
Re: New project
ouch
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-21-2014, 03:03 PM   #330
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Div 4 bracket finals , ended up finding my footbrake spot . Long story . I ended up brending the brake pedal away from the gas peddle , adjusting the rod into the master cylinder , and geasing that pivot point , readjusted the bars and went for it . I was late at first and was moving around on the launch rpm . I finally found a good spot at 2000 rpm . I could stage the truck with the brakes and they would hold . I also figured out the bump in pretty quick as last year i won a race off the footbrake . Ended up with 3-.036's and a .035 . Lost on a double breakout as i only had 11" to back up . Pretty tough at 100 mph . The more i loaded it up on the converter the less it smoked . Guessing the rings were seating in . Good outting none the less . Had a great time anyway .
Guess the next question is if we will have a footbrake or NO-E class next year . That will decide how things go . Definatly going to concentrate on the S-10 and getting to know it during the winter teardown .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-19-2014, 07:34 AM   #331
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Been more of the usual . Passengerside axle seal leaking . Pulled the rear fenders and mounted a set of 29.5 x 10.5 slicks . Need to remount the rear fenders . Been working alot lately . Not much drag strip time .
Things are not looking good for 2015 . They posted the calender and it looks like i would need to take 16 days of vacation just to run the season . Not good for me as i dont have that much time . we will see . Last year they posted the sechedule , then changed it which worked in my benifit . we will see .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-30-2014, 12:36 PM   #332
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well the girls were in town and im a pian for them when shopping . "You might as well go racing" . Loaded up and went to the nitro jam deal in San Antonio . Had a good weekend . Ended up breaking out in the final friday night by .004 . The sun went down and the track was less than stellar . Truck started to drift to the right and by the time i noticed i was out of the groove and headed to the centerline . As soon as the driverside tire got out of the left groove it made a pretty hard left , i drove it out and never lifted and it landed right back in the groove and took a set back . I thought " no way i can break out now" well i was .004 under .
Saturday was kind of a different day . Alot more cars and more of a show . Track was better Got dowen to 8 cars and had the truck in a position to be .00? on the tree . Their wasw a young guy on a street bike that was killing the tree . during the draw i was in the last 3 cars and got a challenger , but the rush was on and left the set on kill set up in it . Should have just taken some out . I was .002 red and dead on 8 with a 6.90 dial to a 6.908 . I was my own worst enemy and it was my race to win .
I ended up getting into the money both days and had a great time . Came close to free racing . Not bad for the first time out on 29.5 trues and a newly adjusted chassis .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-30-2014, 04:16 PM   #333
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Cause updates without pics are lame.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-04-2014, 07:19 AM   #334
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Random shots from last weekend :
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-10-2014, 05:26 PM   #335
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well im going to try this . Forgive the poor editing as im learning how all this works . I also sound like a hillbilly on camara . Going to do some different angles next year . I also forgot the camara alot of last year and sometimes forgot to turn it on and such . Here goes nothing .
http://youtu.be/QE-2s-c8p7E
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-15-2014, 09:31 AM   #336
regan wilson
regan wilson's Avatar
Re: New project
You do sound like a Hillbilly but the video is cool!
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 12-15-2014, 01:45 PM   #337
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Gee thanks LOL , I actually like that program Marv refrered me to I will be putting more of these together as im learning . Im going to work on different angles also .
I am already ready to race . The off season is tougher than i remember.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-15-2014, 10:03 PM   #338
Marv D
Registered Truck Offender
Marv D's Avatar
Re: New project
I just got my new window net, new header teathers new steering wheel / quick release, picking up the glide from Hughes tomorrow after a re-cert/ freshen, have to put current belts in the car and renew my physical / license ,, all before January 16th and the first ADRA race. The end of my 'off' season is coming TOOoooooo QUICK!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-16-2014, 03:23 AM   #339
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well we have a test and tune in late febuary , but it will be here and their races until the season opener in March . Motor is fairly fresh , trans was freshed higher up on the page . Belts and cert are new. Could probably use a set of front tires . Im pretty much ready .
I bought this Camaro and got a decent offer on the S-10 , so it will probably go . I have a nice pile of parts to build a street car class Luv if the right body comes along .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-23-2014, 01:49 PM   #340
leftcoast66
leftcoast66's Avatar
Re: New project
GVWv
leftcoast66 is offline   Reply With Quote
Old 01-10-2015, 05:07 PM   #341
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Originally Posted by leftcoast66 View Post
GVWv
Hummmmm..... I don't know what that means . Just thought id throw up an update . I am having Eric @ horsepower Innovations build me a carb for next season . I am also upgrading to an Aeromotive pump and regulator to keep up with the extra needs of E85 . My big cartridge filter will be going away for a stainless screen type . I also have been testing local pump E85 and it shows to be 85% dead on . We will see how this works out . I have exhaust temp meter and im looking into a o2 data logger .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-23-2015, 09:25 PM   #342
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-01-2015, 08:51 AM   #343
JJLT1
JJLT1's Avatar
Re: New project
gross vehicle weight v??
wtg, good video, keep it up Hotrod..
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
Old 02-01-2015, 09:19 AM   #344
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
2880 with me ( we could both lose some weight ) and thanks
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-02-2015, 10:55 AM   #345
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Quick update : I got the fuel system lined out . It is now set up for pretty much anything . It is -10 from the tank to the filter . Filter is on the pump inlet . Pump is Aeromotive SS which is good for 1000HP . -8 from pump to regulator which is a Aeromotive return style . -8 return to the tank and 2 -6 lines to the carb . Fuel pressure is rock solid . Started the truck up on pump gas then drained the tank and did the swapped the new carb . Got the fuel pressure lined out @ 7 psi . I am really happy with results although I didn't get to test Friday night due to a bent pushrod and broken rocker stud . I have no ideal what happened , went bang and lost #4 . Started with compression test which yielded 85# . Pulled valve cover and found this .
Did a leak down while I had it down and all cylinders where low 90's at 100 psi. I had worries I got a head gasket or a valve , but I got lucky . A buddy of mine had a stud and we were able to pull the piece out of the poly lock . Bought 2 new pushrods and got it back together . Just kinda set the carb to the best running settings . Plans are to get it on a chassis dyno with an o2 or temporarily set one up and test at the drag strip . Pretty happy with the whole swap . Went up one heat range on plugs cause it was acting like it would load up a bit . That seemed to stop with hotter plugs . I added a good bit of initial timing also moving the curve to 20 with all the timing in by 2000 with a total of 36 . This took a lot of cam lope out .
http://vid47.photobucket.com/albums/...ps178b8013.mp4
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-08-2015, 08:59 PM   #346
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well , went to start it today and it bucked . I pulled the plugs and it had water in a couple of holes . Looks like it got both head gaskets . Heads are off and going to be surfaced tommorow and gaskets are on the way . Also bought a wideband for it and will be moving the gauges around so i can see them better .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-09-2015, 07:10 PM   #347
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
One of the heads was pretty bad off . Had both surfaced and got some real head gaskets . The ones i used when this motor was thrown back together were cheap out of a builder kit . Anyway got the heads back on and torqued today . Have the plug out so the pan can drain tonight . Trying to finish up assembly tommorow .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-13-2015, 12:05 AM   #348
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Thanks for the tips . I run a hydraulic roller . well I got the head gaskets replaced and everything is back together . Changed the factory dash , as all it did was temp gauge , oil light and alt light anyway . set it up where the back light for the volt gauge excites the alt . This means when I turn on the key the volt gauge lights up til the truck fires . then the back light goes out . I will know I have a charging issue it the volt gauge is lite after the motor fires . I added a A/F meter in Lambda scale . Mechanical temp gauge vs the factory unmarked gauge . Oil pressure gauge vs light I had before ( never paid attention anyway) . The speedo doesn't have a cable , but this dash has a lot more info .
Added a carb pan and sealed it to the cowl hood . Lot of off season work .
[IMG]
Just thought id take a picture of these as they may be rare now .
http://i47.photobucket.com/albums/f151/hotrod80/IMG_20150212_185653_zps073da068.jpg[/IMG]
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-14-2015, 09:27 AM   #349
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Had a good test session last night it was within .03 for 3 passes and still a touch lean at WOT , which may have been the air .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-14-2015, 05:30 PM   #350
JJLT1
JJLT1's Avatar
Re: New project
dam the luck
think its time for some guide plates maybe??
with them no chance of the rocker jumping off the valve..
retork the head after a heat cycle..
wtg Hr
JJ
