Closed Thread
Old 08-13-2016, 11:35 AM   #326
59chev
59chev's Avatar
Re: Roadkill's 58 Chevy Stepside
It might be a Canadian engine. Or at least one that came from somewhere that gets cold winters. The extension cord is probably an oil pan warmer or a block heater.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline
Old 08-15-2016, 12:05 AM   #327
Roadkill58
Roadkill58's Avatar
The car (maybe a Pontiac) had Canadian plates so I knew it had seen some cold weather. The shop teacher explained that if he forgot to plug it in at night he wouldn't be driving in the morning.
Need to remember to write down the engine numbers so I can see what's up.
I pulled the heads this morning and am not very happy with what I found.
Looks like something was left or fell in that cylinder. I bet that made some noise.
I think the beat piston was originally in the cylinder with the groove in it.
Heads don't look too bad, but won't know until I break them down.
Overall I was not happy with how dirty the engine was inside.
Going to tear it all apart to clean everything.
I will replace oil pump and pickup screen at the least.
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline
Old 10-23-2016, 04:11 AM   #328
Roadkill58
Roadkill58's Avatar
Got an engine and transmission installed in the 58 last month.
Used the stock battery box for now. Still need to install the drop box on the chassis.
With winter coming soon I decided to clean up the shop so I could have room to keep the truck inside. Once I had enough room for the truck and room to work I ran some conduit (free from demos) for light and outlet circuits. While I was at it I added some 3-way switches for two of the bays where I park the bikes, and truck. Need to clean up more every week until it is done.
Motor didn't fire on first try (180 out on the distributor).
Re installed the distributor and the second try it fired right up.
I need another crossflow radiator. The one I have is too wide and sits on top of the frame rails. I'm too cheep to buy a new one until I get closer to driving the truck.
Fought with the brakes for a while. I finally won.
Didn't like the way the return line on the power steering pump ended up. There is a loop in the return hard line and then it seems to be brazed to the side of the reservoir. I'm going to have do something about that.
Checked the rear end and discovered I have 3.23:1 limited slip 10 bolt.
Filled it with fluid. Also filled the Muncie with some fluid.
Today I installed the coil springs and shocks on the IFS.
The lower arms are not level. Instructions say to drive a thousand miles to let it settle before cutting on the coil spring.
Took the wife for a ride down the street and back. She wanted to know why I didn't have an "Oh ****" handle for her. She also said something about not having mufflers. At least I think that's what she said I couldn't hear her at all.
Maybe I won't install mufflers....
Still have a lot to do before starting metal work.
I'm just happy it moves on its own power now.
Rust Never Sleeps
Old 10-23-2016, 04:50 AM   #329
jjzepplin
jjzepplin's Avatar
Nice build. How did I miss this? Those heads look to be 2.02s and the pistons are flat top probably replacements. Could be a nice engine. The new one looks good too.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline
Old 10-23-2016, 05:52 AM   #330
Softpatch
Softpatch's Avatar
Great just great .!
Like the last post now I have to go back and read your whole thread
Don't know how I mised this
thanKs for the up Date RK58...I used a V8 Trifive rad in my 59/327...Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline
Old 10-23-2016, 09:53 AM   #331
Kim57
Kim57's Avatar
Looking good.
Nice to be able to drive it if only up the street and back.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline
Old 10-23-2016, 12:48 PM   #332
Roadkill58
Roadkill58's Avatar
Thanks jjzepplin. Yes those are 2.02s. The pistons are replacements (made in brazil). The engine has 4 bolt mains and a gear drive.
The engine in the truck is a 350 out of a 1989 firebird.
Rust Never Sleeps
Old 10-23-2016, 12:49 PM   #333
Roadkill58
Roadkill58's Avatar
Originally Posted by Softpatch View Post
Great just great .!
Thanks Softpatch.
Rust Never Sleeps
Old 10-23-2016, 12:51 PM   #334
Roadkill58
Roadkill58's Avatar
Originally Posted by Kim57 View Post
Looking good.
Kim
Thanks Kim. I was getting tired of pushing the truck, so yes its nice to be able to move on its own power.
Rust Never Sleeps
Old 10-23-2016, 03:32 PM   #335
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Congrats on your first ride!
ChuckDriver is offline
Old 10-24-2016, 02:24 AM   #336
Roadkill58
Roadkill58's Avatar
Thanks JJ.
Technically it is the second ride. I drove it once when it had the stock axel in the front and rear and the three on the tree. Also had the 307 SBC in it.
I liked the second ride more.
Rust Never Sleeps
Old 11-01-2016, 09:04 PM   #337
ptc
ptc's Avatar
All right Jim!!! congrats on the driving machine!!!! glad to see it.
Still waiting on a few things for mine.
But the cab is going on... bed is going on, everything is going on and Im driving it when its ready.... rat roddin here i come
My Build: 57 Chevy Pro-Street
ptc is offline
Old 11-02-2016, 03:30 AM   #338
Roadkill58
Roadkill58's Avatar
Thanks PTC.
Did some more cleaning in the shop and now I have the front end group in the shop. Now I can disassemble it so the inner fenders can be modified as well as the core support (for crossflow radiator). The bed will be next.
Rust Never Sleeps
Old 11-15-2016, 05:00 AM   #339
Roadkill58
Roadkill58's Avatar
Got a radiator and shroud and fan from ebay.
It's a crossflow for a 1969 Camaro. 23" core.
I had to shave the mount brackets off to make it fit.
Also started on the bed.
Rust Never Sleeps
Old 11-15-2016, 05:34 PM   #340
ptc
ptc's Avatar
looks good!!!
ptc is offline
Old 11-17-2016, 03:58 AM   #341
Roadkill58
Roadkill58's Avatar
Thanks PTC.
Got my weatherpack kit today along with the fan relay parts.
Need to install the new plug wires.
Need to do about a million things on the truck....
Rust Never Sleeps
Old 12-07-2016, 06:41 PM   #342
tpimuncie
tpimuncie's Avatar
Nice! Greetings!
1959 apache 1948 chevy coupe
http://67-72chevytrucks.com/vboard/s...d.php?t=562949
1964 gmc burban build for pops
http://67-72chevytrucks.com/vboard/s...d.php?t=724632
tpimuncie is offline
Old 12-07-2016, 07:38 PM   #343
Roadkill58
Roadkill58's Avatar
Originally Posted by tpimuncie View Post
Nice! Greetings!
Thanks tpimuncie.
Happy Holidays to you and your family!
Rust Never Sleeps
Old 12-10-2016, 04:32 PM   #344
Roadkill58
Roadkill58's Avatar
Re: Roadkill's 58 Chevy Stepside rainy day work
When I first got the truck I bought a new gauge/instrument cluster.
Finally got around to installing it. Not really liking the billet look anymore.
Thinking about painting the inner part flat black.
I noticed the high beam indicator light was red. My other vehicles the light is blue.
I ordered some electrical related items from All Electronics and one of the items was some blue LED's. Wanted T3 but got T1. It will still work.
Removed the red LED and installed the blue LED. The red LED was for 12v (no resistor) so I added a 1k resistor to the blue LED to not let the smoke out of it.
Also used weather pack connectors for gauge lighting and signal.
Still need to finish connecting the turn indicators and high beams.
Rust Never Sleeps
Old 12-10-2016, 07:09 PM   #345
Kim57
Kim57's Avatar
Looks good but I think it will look real nice in flat black.
Kim
My build thread
Kim57 is offline
Old 12-10-2016, 10:46 PM   #346
Roadkill58
Roadkill58's Avatar
Thanks Kim.
The speedometer lighting only light up the mileage and not the needle and numbers. I tried sticking a golden white T5 LED down the hole where the bulb goes but it didn't work.
I'm thinking a T3 golden white LED shining at the speedometer from the column might work as long as it doesn't look too cheesy.
Swapped the Monte Carlo wheels for the ones off the 88 IROC.
The Monte Carlo wheels have too much backspace and just don't look right.
They worked ok for rollers.
I'll post some pictures tomorrow.
Rust Never Sleeps
Old 12-12-2016, 03:07 AM   #347
Roadkill58
Roadkill58's Avatar
These are the wheels I'm going to run until I decide what and what size to buy or trade for.
They are from a 1988 Iroc. They are 16X8? and 0 mm on the front and 16 mm (negative - outward) on the rear.
They are marked front and rear on the rims.
Thinking they have 51/2" back space on rear and 5" on front.
Tires are 245/50/16 front and rear. They need replaced soon.
Should be enough clearance for the extremely rusty bedside.
Maybe I should give them a tetanus shot?
Rust Never Sleeps
Old 12-14-2016, 01:39 AM   #348
tpimuncie
tpimuncie's Avatar
Originally Posted by Roadkill58 View Post
Thanks tpimuncie.
Happy Holidays bud! Soooooo theres a lady by the name lisa with a big 4x4 apache fleetside that wants to get a truck day at a park in elk grove in feb you down? If we get enough people interested we can make it happen
Old 12-14-2016, 03:57 AM   #349
Roadkill58
Roadkill58's Avatar
Yeah I'm down.
Rust Never Sleeps
Old 12-14-2016, 02:21 PM   #350
tpimuncie
tpimuncie's Avatar
Yeah I'm down.
Cool! theres a park there they do a Camaro show every year think show is called Camaro gernerations or something close
Closed Thread
