#326 |
![]() Join Date: Apr 2012
Re: Project#2 67-72 Restoration's Shop truck
First off. Glad to see your daughter is ok. Your doing an amazing job on the trucks and your customer service.
Posted via Mobile Device |
#327 |
VA72C10
![]() Join Date: Mar 2008
Thanks, wish I had a little more time in the day right now
![]() Posted via Mobile Device
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#328 |
![]() Join Date: Jan 2012
thanks i think they look alright for now until i can afford new headers then i can move the motor ahead, im across the lake at the other camp by the way lol good thing we all still get along though haha, glad your daughter is ok minus the ear infection
#329 |
VA72C10
#330 |
Sleeps over rated lol Truck is looking good.
#331 |
VA72C10
Got the carrier bearing mount off and painted. And got most of the pass side modified to fit the headers. Stopping to eat a late dinner now since it's 9 and I try not to cut/grind/hammer after 9pm...
Will go back out for a bit more later and bmerdoc is coming over tomorrow afternoon after I get back from Church. Posted via Mobile Device
#332 |
Im waiting with great anticipation to see your progress today.
I wish you Dexterity and Speed! |
#333 | |
VA72C10
Headers have fought me right and left (knew they would require work) but after sokme work with the cutoff wheel, grinder, and a can of satin black touch up paint...they are in! Posted via Mobile Device
#334 |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 10-07-2012 at 06:41 PM. |
#335 |
![]() ![]() Join Date: Jan 2011
Is that the 010 block?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#336 |
VA72C10
Yes, it's the 010 high nickel 4 bolt main. Basic 355 .030over with comps 268 cam and performer intake....simple yet good power and torque.
#337 |
I really like that cam. I had one in a 406 a while back. It would pull forever.
#338 |
Productive day VA?
Ive been waiting to hear the final result. |
#339 |
Oh my!!!!!!! that looks os nice, shiney and everything. keep it up.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#340 |
rootin for you man motor looks sahweet!!
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#341 | ||
VA72C10
Productive...yes..... Engine running? ...no... Quote:
Thanks! Bmerdoc is going to try for tomorrow night now. I got the starter installed tonight as well as vacuum and gas lines ran (simple section from hard line to fuel pump) Wiring is my biggest holdup from firing it up now.....will work on that tomorrow afternoon/evening then Nick plans to prime the pump and install the distributor. I have a few hours of contracted cad work to do in the morning and a couple stops after that but from around 3-on I'll be back on the truck... Posted via Mobile Device
#342 |
You are on the home stretch.
I bet it feels good to have gotten as much done as you have in such a short time. Good luck today! |
#343 | |
VA72C10
Very happy with what's been accomplished in a few weeks. Posted via Mobile Device
#344 |
A guy with a truck
Engine looks good!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#345 |
VA72C10
Thanks! Still not running...ran into an issue with the balancer bolt and balancer....thankfully had a new bolt that seems to be holding fine.........
Also took a while to sort through the wiring and I realized I put the wrong fuse block/harness in. It's a nice one but not correct year or options so that was changed tonight. Got the wiring started, flywheel bolted to converter, distributor installed...and a lot of time wasted looking for tools/bolts in my cramped, overstuffed garage....but happy to have a garage as it was in the 40's and raining... Thanks again nick for coming by and all your help. Hopefully by wed night when he comes back we can get it fired up.... I have a lot to do between now and then....plan to put the front clip on so we can use that wiring, have grounds hooked up, and have the battery in place with the junction block and the regulator bolted down. Posted via Mobile Device
#346 |
VA72C10
Also got tach wiring ran, wire for hei made up, oil pressure line hooked up and run into cab, gas pedal installed, carrier bearing mount installed and driveshaft verified (nick I am going to use another one I have....also has a new carrier bearing and after some 0000 steel wool the yoke looks new and u-joints are all good)
Installed a power outlet in the lighter hole and bolted and unbolted the fan/clutch three times ![]() Posted via Mobile Device
#347 |
![]() Join Date: Oct 2010
Wow ! you are making big progress fast ! keep movin forward brother.
John Mild Custom 68' Work Truck Build Facebook LoL 1977 Trans Am (Project) 1965 Chevelle (Project) |
#348 |
Yeesh you are down to 4 days and no doubt feeling the pressure now.
Im pulling for you. |
#349 |
Reminds me of August! Good progress, Keep pushin'!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#350 |
![]() Join Date: Dec 2006
Motor looks great, can't wait to hear it fire up
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
