09-02-2013, 06:36 AM | #326 |
Re: 1951 Chevy / C4
nice build
USN RETIRED there are two things you don't need in the navy. that's a wife and a pick up truck. cause when your out to sea someone else is using them |
09-03-2013, 10:37 PM | #327 |
Re: 1951 Chevy / C4
Mr incredible, thank you.
Here are the pictures from the weekend. I made up new running board mounts. I used 1x1 1/16 box with 3/4 3/16 stock welded to the inside. Then drilled and tapped for 1/4-20. I ground the spot welds and removed the factory ones. Then plug welded the new ones at the right places. It work out great. I then finished fitting the splash aprons and welded a 3/16 rod to the edges after it was bend to the profile of the edge. Next is the steering and the brake peddle assembly. Also the bracing for the fire wall to the peddle assembly. Here are the pictures. Shannon Posted via Mobile Device Posted via Mobile Device
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
09-03-2013, 10:40 PM | #328 |
Re: 1951 Chevy / C4
09-03-2013, 11:31 PM | #329 |
Re: 1951 Chevy / C4
Nice job, looks good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-03-2013, 11:48 PM | #330 |
Re: 1951 Chevy / C4
Outstanding. Keep it coming
09-04-2013, 11:28 AM | #331 |
Re: 1951 Chevy / C4
very nice shannon, I was gonna ask you about the edge on the filler pans, but then I went up and read what you did.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
09-09-2013, 10:35 PM | #332 |
Re: 1951 Chevy / C4
Oldman3, thank you.
Mr incredible, thank you and I will keep rolling. 99 to life, thank you, that is the best way I came up with. Well I will try this again, nothing worse than writing everything up and with the way the site is now with uploading pictures and loseing everything This weekend i worked on the brake pedal assembly and the steering. I made a plate for between the booster recess and the pedal. Then used 1 inch box tubing to span from cowl to cowl. The also to the area where the hood bolts up. Also tied in the booster plate so the fire will not push when breaking. Nice and strong now. Next was to put on the lower steering joint and mock up the dd shaft to check for the steering column placement. The lower mount is made out of a piece of round tubing and has a 3/8 nut welded to it to lock the column in place. There will be an aluminum bushing so it does no t crush the column. The upper is going to be a connecting rod. I picked one up tonight from a buddy. Picture will follow. Shannon Posted via Mobile Device
09-09-2013, 10:46 PM | #333 |
Re: 1951 Chevy / C4
09-09-2013, 10:47 PM | #334 |
Re: 1951 Chevy / C4
09-09-2013, 11:40 PM | #335 |
Re: 1951 Chevy / C4
Bracing, and column mount looks good...Jim
09-10-2013, 08:28 AM | #336 |
Re: 1951 Chevy / C4
Excellent
09-10-2013, 09:58 AM | #337 |
Re: 1951 Chevy / C4
Your work always looks so well planned out and executed.
You have a real talent my friend. Keep it up. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
09-10-2013, 03:08 PM | #338 |
Re: 1951 Chevy / C4
looks great, def stealing your column idea on the floor, little extra security and even nice to get the column where you want it, then tighten it up so you get all the linkages right for the steering by yourself.
09-10-2013, 05:17 PM | #339 |
Re: 1951 Chevy / C4
I agree with the guys before me. Nice work and attention to detail.
09-12-2013, 08:20 AM | #340 |
Re: 1951 Chevy / C4
oldman3, Thank you
mr incredible, Thank you youngrodder, Thank you. I alway love to post my stuff that way if someone is doing something the same way, they can see how I did it. And hopefully it will work for them. 99 to Life, Thank you. That seemed like a good way of doing it. I am going to turn up the aluminum bushings for the upper and lower mount after work tomorrow. Then hopefully I can get them in this weekend. I am driving a old military truck that I put panels in years ago to a 9/11 / veteran ceremony on Sunday. So it is taking up some of my hot rod time but it is for a great cause. 69CST-V, Thank you Shannon
09-16-2013, 08:33 PM | #341 |
Re: 1951 Chevy / C4
I turned my upper and lower bushings out of aluminum. Then slit them in half. I turned flanges on both of them so they will not push through. I put the steering column where it belonged and figured out where to cut the connecting rod off at. I took a piece of round bar stock and drilled and tapped it. Then cut it at 3.5 inches. I then TIG welded it to the connecting rod. Then fit it on the column and made tabs with holes in it.Bolted it up together and TIG welded the tabs to the 1x1 box I put across the cab. Column is nice and strong. Now all I need is a wheel to steer it.
09-16-2013, 09:57 PM | #342 |
Re: 1951 Chevy / C4
heh thats awesome! kepp up the good work!
2011 Silverado ECSB LT 2000 Silverado RCSB 2WD super bad habit of not owning a vehicle for a long time |
09-16-2013, 10:18 PM | #343 |
Re: 1951 Chevy / C4
great work, looks good.
09-16-2013, 10:39 PM | #344 | |
Re: 1951 Chevy / C4
The drop looks killer !! I love how you take a concept & turn it into a pice of art!
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD |
09-16-2013, 11:21 PM | #345 |
Re: 1951 Chevy / C4
Nice job Shannon, looks great...Jim
09-17-2013, 11:48 AM | #346 |
Re: 1951 Chevy / C4
Shannon, Setup looks great, connecting rod is a really nice touch.
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647 |
09-17-2013, 05:37 PM | #347 |
Re: 1951 Chevy / C4
Looks great. I love how you thought it all out so it all ties together for added strength. Will definitely keep that in mind when I do mine.
av8tr33337 AKA Bartman Email av8tr33337@yahoo.com Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
10-01-2013, 01:25 PM | #348 |
Re: 1951 Chevy / C4
Been following your work. Very impressive. I have a 1950 that i'm trying to work on. Right now I wish I have half your skills and tools! I have ideas but need to go ahead and try them. So far I just have the body off the frame. Need to clean it, paint it and figure how to install the front crossmember.
1950 chevy PU work in progress. |
10-01-2013, 06:35 PM | #349 |
Re: 1951 Chevy / C4
Hey Shannon, hope everything is OK your way, no update for two weeks....Jim
10-01-2013, 08:21 PM | #350 |
Re: 1951 Chevy / C4
Chevyboy73, thank you.
99 to life, thank you. 48 GMC BURB, thank you, give an idea and I will make it happen. Glad you like it. Oldman3, thank you. bubba54 , thank you, it was easy to do. I just turned up bushings to make it work. Av8tr33337, thank you. It did work out great. Feel free to use it. Yawdie1, thank you very much, tools really make it go easier. If you ever think I can help you with something give me a shout. Always glad to help. Oldman3, I know , I know. I have been crazy busy, ken has me doing a frame quickly for his wife's 47 chevy double duty box truck. It is a 3600 frame, I put 87 1/2 ton suspension in the front. It has bags in the front, leafs in the back with 6" bags in the back for helpers. I have the 350 motor and 700r4 mounted all ready. Waiting for the rear bags. Have to finish the rear shocks and bags this weekend and hopefully mount the steering box and idler arm too. Bend up brake lines and install hoses and then he can take it back to Md. You know just setting around! Shannon Posted via Mobile Device
