#326 |
Re: Project "Redemption" 68 SWB Fleetside
That sucks Kieth, hope they get things worked out for you.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#327 |
Still Learning
Bummer about the wheels, hope it's a quick fix. Billet Specialties needs to make it right with you for sure..
#328 | |
![]() Join Date: Dec 2012
If you have time, what is the measurement from wheel mounting surface to wheel mounting surface of your rear end with the rotors installed? Thanks, Mike
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#329 |
Junior Member
The set of Intro's I ordered have been delayed because they are having trble with their wheel barrel supplier. They are for the 22x12's, but may be the same supplier to Billet Specialties. They indicated that the barrels they rec'd were oversized and had issues with the tires mounting.
Anyways, I feel your pain & hope it gets resolved soon! |
#330 | |||
![]() Join Date: Dec 2006
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#331 |
So were they built on a Monday or a Friday? Following the same story of assembly line workers who are hung over and tired on Monday, or checked out and ready for the weekend on Friday... I hope they make it right for you, and not waste more of your time with that problem.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#332 | |
#333 |
Despite the issue with the wheels, I'm still plugging away at the frame! Got the motor and trans installed. I think the motor is sitting a little high because the best I can get is them at 7 degrees down! I can't raise the trans up anymore because it hits the Porterbuilt inner frame stiffener! I sent an email to Travis at AZProPerformance to see if Choppin block can get me some different motor mounts so I can lower the motor down a little.
#334 |
Another angle
#335 |
Still Learning
Chassis looks great with that beast of a power plant in there.
#336 |
This is how tight it is from the trans to the inner frame stiffener.
#337 |
Thanks Mike, it's nice to have the motor and trans sitting in the frame. Once I get the angles fixed I can start on the exhaust.
#338 |
Keith are you going to have room to plug that VSS sensor in? That looks really tight for sure!
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
#339 | |
![]() Join Date: Jan 2015
Jimmy Hoelzel |
#340 | |
I'd say I have a good 2.5-3" so the motor has plenty of room to go down!
#341 |
The cleanup and paint you did on the motor looks great. Going to be a nice ride when you get it finished.
#342 | |
#343 |
I got the wheels back from Billet Specialties today. They milled the barrels down and polished them so hopefully I can get some tires mounted this time
#344 |
Man that was a quick turn around. Very happy for you that they took care of it so quickly!
#345 |
I have the same problem with my Raceline Burst 5's. I'm wondering how common this is. I've got to send them back as well.
#346 |
![]() Join Date: Feb 2010
Very nice work
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
#347 |
A person would think these high dollar wheel companies would turn out better items, or is it maybe a quality control problem???
#348 |
hopefully they didn't have to take much material off. looking forward to seeing the chassis finished up.
#349 |
Well I'm officially done with Billet Specialties. After getting the wheels back for a second time, I still can't get a tire to mount! I wasted my time today going to 2 different tires shops and neither one could get the wheels mounted up! The tires still won't fit down over the barrels no matter what you try! I'm disgusted right now. They can have their junk wheels back!
#350 |
I understand your frustration, but as an alternative, you can ask them to have the tires mounted for you. It sounds like you've made a solid effort on your own. I'd even see if they can throw you a little discount or credit for something else from them for the inconvenience.
Keep pressing man! You're doing great!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
