12-03-2012, 07:20 PM | #351 |
Re: Cheap Tricks
I bought a box at a auction once with some ss bowls in it but in the bottom of the box were a bunch(like 10 of them) of mismatched kitchen mixer beater bars damn dont they work awesome for paint stirs
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
12-10-2012, 03:46 PM | #352 |
Re: Cheap Tricks
when using a electric fan wire the 12v directly through the battery then T in a gm 2 wire oilsender to your engine Ground one side and run ground from motor to the other When you start engine Fan comes on and stops when engine stops No switches or forgetting to turn it on
12-10-2012, 03:58 PM | #353 | |
www.67HEAVEN.com
Re: Cheap Tricks
www.67HEAVEN.com 2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme) 1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme) 1967 Belair 2-door-post (project) 1967 Corvette 427/435 coupe (now 502/502 red road warrior) |
12-10-2012, 04:12 PM | #354 |
Re: Cheap Tricks
ok also install fuse link in hot wire
12-10-2012, 04:34 PM | #355 |
Re: Cheap Tricks
12-20-2012, 08:04 PM | #356 |
Re: Cheap Tricks
Battery terminal brush to clean the corrosion out of aluminum wheel lug holes. Just did it the other day when putting someones winter tires and wheels on their truck.
12-21-2012, 12:44 PM | #357 |
Florida Edition
Re: Cheap Tricks
Wow! Over 23,000 views! Tons of great stuff in here. About time I made an index for handy reference.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
12-21-2012, 07:54 PM | #358 |
What?
Re: Cheap Tricks
Got corrosion in your taillight bulb sockets?
A brass 20 gauge shotgun bore brush and cleaning rod attached to a drill motor works great!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-22-2012, 03:54 AM | #359 |
Hand Crafted C-10
Re: Cheap Tricks
12-22-2012, 03:03 PM | #360 |
I am a Referee of life.
Re: Cheap Tricks
I don't think I posted this yet.....
Ladder socks,I use an old pair of crew socks to cover the feet of my ladder when I bring it in the house for a project.They slip right on and can be kept in place with a small clamp or some duct tape.Keeps the carpet clean and the Mrs happy.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-22-2012, 04:40 PM | #361 | |
Re: Cheap Tricks
Trueman |
12-22-2012, 04:45 PM | #362 |
Re: Cheap Tricks
To prevent paint chips from spray cans i take electrical tape and rap the bottom lip of the can pulling the tape tight as i wrap it .
Just in case you or someone forgets and sets it on the hood causing a chip or scratch.
Trueman |
12-23-2012, 06:12 AM | #363 |
Re: Cheap Tricks
-flip your aircleaner lid upside down for a nut and bolt/toll holder when your working in the engine compartment.
-old drum brake shoes around your tires in the paint booth so your airline doesnt get stuck under the tires -need to jump start a car with no jumper cable? remove good battery flip up side down and put post to post (of course make sure +to+ and -to-) then start car -hole in radiator? crack an egg and let it go in through the rad cap. add water, put on cap drive on.. -those with air-ride suspensions, always carry a "end to end" splice push pull fitting in case of hole in air lines. -those with air-ride suspensions, always carry a block of wood to place between frame and lower control arm in case of bag failure so you can still drive on.. -install an 'old' york style AC compressor to your engine for on board air. fill tires, use for air-ride etc.. -install secodn alternator to use as arc welder when off roading and breakin parts.. -use wife/gfssponge makeup applicators for puttin assembly lube on bearings and other parts -buy wife something so she leaves you alone while working... <---probably best tip |
01-30-2013, 02:17 AM | #364 |
Re: Cheap Tricks
This has been an AWESOME thread !
Here is one that "may" qualify as a garage cheap trick - I have an old white board on the back of the entry door in the garage, They're great for jotting down thoughts, lists or drawings........until someone (me uses a permanent marker on it. If this happens and you want to remove the permanent marker quickly - just trace over it with the dry erase marker and immediately wipe it off with a cloth. Gone...no rubbing. |
01-30-2013, 03:21 AM | #365 | |
Re: Cheap Tricks
Nice. My beer fridge is covered with chalkboard paint for the same reason. |
01-30-2013, 05:41 AM | #366 |
Re: Cheap Tricks
any trick for getting a roll pin out of my sm465. im losing my religion over it. next step will be the welder
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
02-04-2013, 01:12 AM | #367 | |
Re: Cheap Tricks
I saw a good on the other day. I was refered too this old fella' for some parts so off i went and he was showing me around and I noticed he used a plastic drop in bed liner to put wheels and such in while blasting them outside to help save some media. needless to say I didnt get anything execpt some cool stories and new local car buddie
03-05-2013, 02:01 AM | #368 |
Re: Cheap Tricks
alot of people use rain-x goto a dollar store pickup a bottle of rubbing alcohol same damn thing
03-09-2013, 11:26 AM | #369 |
Re: Cheap Tricks
Did anyone mention using a plastic gallon jug with screw-on lid for an (adjustable) head/neck support when spending time lying under a vehicle? Has saved my neck many, many times.
03-09-2013, 02:12 PM | #370 |
Re: Cheap Tricks
I have never heard that one, but it sounds like a very useful idea.
03-09-2013, 02:33 PM | #371 |
Re: Cheap Tricks
90* plug boot end, replace the gas can spout little plastic cap that falls off....
Chevy GMC Trucks Find Of The Day https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com |
04-05-2013, 11:56 AM | #372 |
Re: Cheap Tricks
This has been an awesome thread! Im glad I found it on your sig, Reno.
Most of the cheap tricks I know have been mentioned but im gonna come up with somethin.... /think think think
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
04-05-2013, 12:02 PM | #373 |
Re: Cheap Tricks
What to do with those old bias ply tires?
My 70 C10(long gone) came with 15" split rim w/ bias ply tires of no interest to me. If you have them taking up space or have no way to get tires mounted/dismounted find your local figure 8 guys they will have a way. The want those tires. No disposal fee! WIN/WIN
"I feel the need for speed!"... as soon as I am done with my nap. |
04-07-2013, 03:13 PM | #374 |
Re: Cheap Tricks
I always liked bias ply tires, when they spring a leak it just goes flat or fall apart, unlike a radial that will go off like a bomb when its done..........
07-26-2013, 02:26 PM | #375 |
Re: Cheap Tricks
New tip.
Bring this thread to the top every once in a while
