#351 |
A320 Pilot/USAF Retired
Re: My long term 57 project
Here's the placement of the fittings under the wheel well. Will run the lines up along the top inner fender panel. It's a lot more work to do it this way!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#352 |
The AC fittings on the firewall, mounted vertically, are right in line with the doubler bracket for the hinge mounting nuts. The top fitting is a little tight to the innner fender panel, should have mounted it just a little further to the outside, but it will work fine as is.
Also finalized the position for the Gen IV unit. Tacked four carriage bolts to the flat panel on the back side. Need a few more fittings for the heater hoses and I'll have it wrapped up. Going to busy the next 2 weeks, so not sure when I'll get back on it!
#353 |
Did spend a little time cleaning up the factory control panel. The VA unit uses 3 sliders that replace the old cables. It makes for infinite contol of the fan, temp and door openings, should be nice!
#354 |
Looking good.
Nice job on the AC lines. Kim |
#355 |
![]() Join Date: Mar 2011
Very nice job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#356 |
Elev8r Man
You build looks really nice
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
#357 |
#358 |
I got side tracked after a trip to Lowes. Been wanting to do this for a while but wasn't sure how I wanted it to look. Lowes had a display of pressure treaded boards with a variety of colors. After seeing the "Mahogany Flame" I knew it was the one!
#359 |
That looks real nice.
Kim |
#360 |
These 2 are for Dan in Pasadena! Will have to do some work to get it to sit level, so it will probably be left out for now.
#361 |
Nice color...Jim
#362 |
very nice
#363 | |
![]() ![]() Join Date: Nov 2008
Also, how about using a router to allow the stainless surround to sit down flush with the wood?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#364 |
No progress to report other than I did get the additional fittings I need to finish the install. But probably want get to work on it until after Christmas.
Yep, Dan, I think I'll have to get a router to make the trim piece fit flat with the boards, but I'll get to that later. And I'm not planning to put the metal strips in for now, thanks!!
#365 |
Just a little progress this week. Hope to get more done over the weekend!
Made a fitting for the AC hose to connect to the back of the 64 Caddy vent I put in the center of the dash. Just used a scrap piece of exhaust tubeing.
#366 |
I dig your truck!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
#367 |
X2 here as well, I started following this build even before I became a member.
Bed wood looks good, also great to see some good Aussie Cabot's making its way across the globe.
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
#368 |
Thanks Brad! I've really enjoyed watching your build too! If you and your brushes are ever on the east coast, I'll turn you lose on mine!
#369 |
Thanks Red! The Cabot's went on very easy and I love the way it turned out!
#370 |
I am running my hoses in the fender well too. Where did you mount the dryer? VA has two condensers for the TF trucks one mounts the dryer on the front of the rad support, the other on the inner fender. Another manf. mounts the dryer in the fender well.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#371 |
I like this idea,, I bought some 67-72 ctr vents to try..
#372 |
How I missed your thread beats me. Nice build . I need to order an AC for mine and will have some questions I am sure. I really like the way you are doing the lines. Rich
My build http://67-72chevytrucks.com/vboard/s...d.php?t=576185 |
#373 |
Forgot to ask who did you get your AC from? Thanks Rich
#374 |
Its all Vintage Air equipment that I ordered through Charlotte Rod and Custom. Got a great deal on everything.
http://www.charlotterod.com/ Thanks!
#375 |
Made some progress this weekend. Finishing up the wiring on the Trinary switch. Used a few bullet type connectors and plenty of shrink tubing.
