Old 02-05-2015, 09:16 AM   #351
Advanced Design
Advanced Design's Avatar
Re: 55 Wagon Progress
Yes, really nice work. The magnetic brake is pretty handy.
Advanced Design is offline   Reply With Quote
Old 02-05-2015, 10:02 AM   #352
MP&C
MP&C's Avatar
Kyle is a quick learner, I think he enjoys welding especially, but we'll see this weekend how he fares with sheet metal
The magnetic brake does have some limitations over an apron brake, but overall it really comes in handy for radius forming and other situations where the truss of the brake would normally get in the way..
Robert
MP&C is offline   Reply With Quote
Old 02-07-2015, 09:39 PM   #353
MP&C
MP&C's Avatar
Today Kyle needed to start some welding on the hood brace, so while he was getting set up with the welder, I started making him an anvil that he could use to planish the weld dots inside the radius voids..
Heat applied...
Kyle's first job at welding sheet metal, he's a quick learner. He did have a couple spots that didn't like the heat and blew a hole, but he did a real nice job in getting those fixed as well.
Planishing weld dots on the new "anvil"..
Full weld penetration...
While he welded away, I turned my attention to the front end. The passenger door had a bit of a tight spot to the rear edge of the fender while opening.. Using a hack saw blade as a "feeler gauge", it was tight in one area. To help out the situation, time for another tool. I have a dent puller with a small pair of vise grips permanently attached, so we just need an adapter kit...
This was some leftover square tubing scraps...
In use..
After the pulling effort, the tight gap was well over two HSB thicknesses.
Moving on to other fender fitment, the bottom edge of the fender was higher than the adjacent rocker. Any adjustment was futile as the bolt was at the bottom of the adjustment hole. Time for some die grinder action to bring the hole downward and also flatten the bottom edge of the hole so any movement forward or backward doesn't push the bolt upward..... This was done on both fenders..
Test fit shows much better alignment.. This may be why the 57 went to a square hole..
Kyle done with his welding on the center patch, just needs to be dressed with the sanding disc. We'll save that for after the other patch gets welded in place..
Front:
Rear:
And I was also busy making more dust... Can't wait for springtime and the leaf blower
Robert
Old 02-07-2015, 10:54 PM   #354
duallyjams
duallyjams's Avatar
Are you keeping track of how many hours you have on this project.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-07-2015, 11:01 PM   #355
MP&C
MP&C's Avatar
Yes, I got a time clock at an auction a few years back and have been keeping better track of all the projects since then. Don't have a running total right now, someone asked me about that a couple weeks ago.
Robert
Old 02-10-2015, 11:12 AM   #356
MP&C
MP&C's Avatar
Someone noticed we use some rather "vintage" ice picks as scribes for metalwork, and asked to see a closer look.. I had picked these up a few years ago at an auction as my wife looks at me with that "and why do we need those" looks... The one came shorter as shown, but to prolong the life of the picks, sharpen with a very fine file, never use a grinder
The auction was in Fredericksburg VA, if anyone recognizes any of the old ice plants, be sure to chime in so we can all get a history lesson. I tried calling them but nobody answered 8 or 30..
Robert
Old 02-10-2015, 08:43 PM   #357
swamp rat
swamp rat's Avatar
Thats too funny, phone 8, phone 30, thats back in the 20's era i would guess, back when every little town had a switchboard and operator to physically connect each call.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-11-2015, 10:28 AM   #358
reaper71
reaper71's Avatar
Rob...Just was able to get up to date on your build...Love the metal and detail work.
Alot of cool tools in your shop!! Makes life easier for metal shaping..
Mark..
reaper71 is offline   Reply With Quote
Old 02-11-2015, 11:53 PM   #359
MP&C
MP&C's Avatar
Thanks for the comments guys!
Kyle finishing up on the hood brace....
Because he had gaps to contend with, we used some copper to insure less chance of blow outs. A piece of 1/2" copper pipe was flattened and bent in the press brake to make a fitted backing for the vee bead detail..
Just a bit of work with the sander and this part should be done. Like the new look without all the gaping holes..
Meanwhile, I continued to make dust. Here's a good view of the built in "guide coat" feature of the SPI. Blocking on the top of the hood shows a low spot.....
And with just a couple scuffs from the bottom, the low shows up there as well
Just a few bumps with the hammer from the bottom into the small shot bag on top and the low is gone.
And the rest looks pretty much the same other than the piles of dust on the floor moving around..
Robert
Old 02-12-2015, 12:44 AM   #360
Advanced Design
Kyle did a really nice job on the hood brace!
Old 02-12-2015, 10:23 AM   #361
reaper71
reaper71's Avatar
Looking good Guys...
Old 02-12-2015, 10:54 AM   #362
oldman3
oldman3's Avatar
Nice work, thanks for the update...Jim
oldman3 is offline   Reply With Quote
Old 02-12-2015, 11:24 PM   #363
MP&C
MP&C's Avatar
He's a quick learner.. I've been pleased with his work.
A while back we had made the brackets to make up three "reproduction" battery trays based on a 1955 Chevy factory air conditioned car.
The only part that did not come with the used original pieces we had as patterns was the factory hold down with it's attached "zee" bracket that secures the battery hold down to the rear of the core support, as seen here in the factory assembly bulletin.
We recently mocked up the battery location, and made a zee bracket based on the picture and the dimensions we had in front of us.
Now to make the remaining two brackets for the other two battery trays.. A roll former die in the press brake was used to make the vertical bends.
A bit of tipping using a press brake die as an anvil, and then using the tipping tool...
The finished brackets and a comparison....
Robert
Old 02-13-2015, 12:28 AM   #364
oldman3
oldman3's Avatar
Very nice work...Jim
Old 02-14-2015, 09:53 PM   #365
MP&C
MP&C's Avatar
Thanks Jim!
Today's progress, Kyle finishing up the hood brace..
While I continue to generate dust on the floor...
Recently we installed a used core support that was quite a bit nicer than our original, but still showed some issues...
Here we see some rust...
And not quite enough clearance to the petcock..
So this will be next on the list, cutting out a new one with a bit better fitment.
Robert
Old 02-15-2015, 12:10 AM   #366
oldman3
oldman3's Avatar
Brace came out really nice, young man is doing some great work...Jim
Old 02-15-2015, 10:14 AM   #367
Advanced Design
You guys make a great team.
Old 02-16-2015, 08:15 PM   #368
MP&C
MP&C's Avatar
Thanks for the comments guys... We had an early schedule today to try and miss the weather.. As I still hadn't finished blocking the front end, rather than pull the core support just yet, Kyle will start on the rear of the wagon in wrapping up some details there. Before pulling the tailgate, there was one gap that was inconsistent, so I gave him a hand with the rework before he got welding..
First to unfold the flange a bit...
Next, some 14 gauge steel was cut out and a strengthening bend added to use for some friendly persuasion..
Refolded...
For comparison, before:
After:
Then we tweaked the twist of the tailgate for good fitment to the opening and Kyle added three plug welds down each side to lock the skin to the inner tail gate.
...Then we removed the tail gate so he could finish the plug welds for the top flange of the tail pan, I had only tacked it in place when the tailpan was installed, so this should help check off another item from the list......
Meanwhile I continued blocking out the front end..
Robert
Old 02-16-2015, 09:54 PM   #369
Advanced Design
Wow, this is going to be about the most perfect 55 wagon on the planet. Nice process on the tail gate gap...I am learning a lot following along.
Old 02-18-2015, 11:32 PM   #370
MP&C
MP&C's Avatar
Thanks!
Well Kyle skipped out on me tonight, something about a birthday and his parents taking him out to dinner.. and here he could have been welding!
So I took the opportunity to have dinner with the family, so tonight was a short night...
One of the other areas I skipped over at the rear of the wagon was when the tail pan was installed. The factory version with the pinch welded flanges has a gap in the crimp seam for the rear bumper seal:
As I got rid of all the pinch weld seams at the rear of the wagon to eliminate those rust traps, the gap at the crimp seam will be filled in. To assist in filling in the wide gap, a piece of copper flat bar is used as a backer..
Next, as the reproduction tail pan has a rounded crimp seam and the area on the original quarters is more of a square, we'll add some hammer action here. The remaining piece of the flat bar is clamped in and used as an anvil..
Continuing welding...
.....and a repeat on the driver's side...
Robert
Old 02-19-2015, 12:18 AM   #371
bagman
Wow! Very amazing work! I really like the fabrication of the factory style A/C battery box. It gets that ugly battery off the firewall and will let everyone focus on the engine when the hood is open. I am helping a friend with a 55 handyman wagon and there is no trunk to hide the battery. So why not hide it in plain sight? Genius! I see that you made an extra bracket so if one comes up for sale I would be first in line.
bagman is offline   Reply With Quote
Old 02-19-2015, 05:15 PM   #372
MP&C
MP&C's Avatar
Thanks, but I only have the one set here. All the other sets were sent to WI..
Robert
Old 02-19-2015, 05:41 PM   #373
bagman
Well if you decide to build more, keep me in mind. Thanks!!
Old 02-21-2015, 07:08 AM   #374
Mjminino
I have already started using your welding process on my project. this is just too cool! Rock on bro!
Mjminino is offline   Reply With Quote
Old 02-21-2015, 07:18 AM   #375
Mjminino
And another thing, I can see that you make most of your body tools but where do you buy them at and what brand do you prefer?
