Old 03-26-2017, 11:04 PM   #351
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: The Snortin' bull
Maintenance is good on these old trucks. What are the details on your headliner? Hard to tell from the pics. It looks like some kind of vinyl/leather material.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 04-02-2017, 08:59 PM   #352
namloc
namloc's Avatar
The headliner is a kit from LMC.Vinyl upholstered panel .It is a medium weight Fiberboard backed. Good color. Nothing fancy but fit was good and a fair value.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 04-02-2017, 09:01 PM   #353
namloc
namloc's Avatar
Back at it . Got the sway bar bracket's fab'd and installed.
The Snortin' Bull
Old 04-02-2017, 09:04 PM   #354
namloc
namloc's Avatar
The sway bar is now on the frame mount's.
The Snortin' Bull
Old 04-02-2017, 09:07 PM   #355
namloc
namloc's Avatar
Bar is on the truck.
The Snortin' Bull
Old 04-02-2017, 09:12 PM   #356
namloc
namloc's Avatar
Moved steering lock to lock.No interference.Moved suspension full up and full down .No interference.Welded a couple of tabs to lacate the way link's to A arm's.The bar sit's up higher than then the lowest portion of truck.
The Snortin' Bull
Old 04-09-2017, 10:32 PM   #357
namloc
namloc's Avatar
Tested out the sway on a little freeway driving.Took the Snortin' Bull out for some pIzza at a cool place the Bull kinda liked and the wife.
The Snortin' Bull
Old 04-16-2017, 01:06 AM   #358
namloc
namloc's Avatar
The Snortin' Bull has no horn.I had an old siren the the fiftie's .So I thought for the time it will be fun.Fab'd a momentary switch bracket and mounted .
The Snortin' Bull
Old 04-16-2017, 01:15 AM   #359
namloc
namloc's Avatar
Mounted off to the side .Easy to switch. It's loud enough .The thought is to add a air operated train horn .
The Snortin' Bull
Old 04-16-2017, 03:36 AM   #360
62stepside longbox
62stepside longbox's Avatar
Horn looks cool, but I really like your idea of a train horn!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 05-06-2017, 11:32 PM   #361
namloc
namloc's Avatar
So the old siren just was not loud enough.So I installed a real horn set. These myself and other have used for years on street rod's.They arm from Ford (sorry) superduty trucks, 2000 - 2006 , fiamm hi and low and a bracket and weather pack connection,
The Snortin' Bull
Old 05-06-2017, 11:38 PM   #362
namloc
namloc's Avatar
Took the Snortin' Bull to NSRA inspection day this Saturday at Mathewsons Automotive in Seattle.The horns got it Stickered to pass.last year it's first time it did not.
The Snortin' Bull
Old 05-15-2017, 10:35 PM   #363
namloc
namloc's Avatar
Installed a new extinguisher .Behind the seat .Fit real well.Safety first .
The Snortin' Bull
Old 05-16-2017, 12:18 AM   #364
62stepside longbox
Great to see that back there, that's something I'm definitely going to add to mine when I start driving it.
Old 05-21-2017, 01:09 AM   #365
namloc
namloc's Avatar
Well most of the bug's are out .Hearing the gear drive and exhaust, air compressors and such is cool some beat's would be good. So still this is a budget build and no polished billet ride. Fabbed up some spacers to fit Stillwater Kicker speaker's on to door rib's.SSL audio deck installed is the start.
The Snortin' Bull
Old 05-27-2017, 11:20 PM   #366
namloc
namloc's Avatar
Air horn's.Out garage sailin' today and picked this trio of air horn's.They cleaned up real nice and all work.Very loud at testing with just 60 psi.The Bull's tank hold 120 psi.
The Snortin' Bull
Old 05-28-2017, 12:50 PM   #367
jcramsey
jcramsey's Avatar
Digging the bull. Love everything you've done with it so far.
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 05-29-2017, 01:28 PM   #368
namloc
namloc's Avatar
Thanks for the comp. I like the Mule project.I think the service truck's have a cool back story for all the years of work .And than some one like you brings them back to life.
The Snortin' Bull
Old 05-29-2017, 09:21 PM   #369
jcramsey
jcramsey's Avatar
Thanks man, it's a neat old truck for sure. I am looking forward to getting it going. I've got a vision for it in my head...I'll be happy if I can execute it half as good as you've done.
The Egg Hauler
The Government Mule
Old 05-29-2017, 09:54 PM   #370
namloc
namloc's Avatar
Using the radio delete plate. A simple insert to blend the audio deck into the dash.
The Snortin' Bull
Old 06-03-2017, 12:03 AM   #371
namloc
namloc's Avatar
I had a manual air horn valve for years.Now it is going to be used.Just mocking up horn's before mounting all.
The Snortin' Bull
Old 06-03-2017, 12:10 AM   #372
namloc
namloc's Avatar
From my new friend's at Trique mfg. Altman latche's.Very helpfull and nice on the phone.I have installed bear claw style latche's on other ride's and this kit will save time and be safe.BTW I believe I see Boosted Bertha is on the package label.
The Snortin' Bull
Old 06-04-2017, 12:51 AM   #373
namloc
namloc's Avatar
Out with old in with the new.The old gmc latches worked though took hard slamming of the door and where worn out.
The Snortin' Bull
Old 06-04-2017, 12:55 AM   #374
namloc
namloc's Avatar
Just had to show this .The year's of different paint color's.Salmon,Blue,White.
The Snortin' Bull
Old 06-04-2017, 01:03 AM   #375
namloc
namloc's Avatar
Installed trique mfg. altman latch kit and massaged a few part's and the striker plate.The door's have become effortless in latching, locking and releasing. One of most rewarding change's I have made.I can shut and latch the door with just a light push..
The Snortin' Bull
