Old 10-28-2016, 07:03 AM   #351
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Let's Build A 1 Ton Crew Cab 4x4
http://67-72chevytrucks.com/vboard/s...&postcount=121
Check out my build thread (signature) or the link above for my idea about Version 2.0 for my brake upgrade using Spyntec hubs...
Rich
1972 K5 Blazer CST Click HERE
Old 10-28-2016, 07:08 AM   #352
mcmlxix
mcmlxix's Avatar
http://67-72chevytrucks.com/vboard/s...52&postcount=5
Here is more info and pics on the rear disc conversion bracket...
Rich
Old 10-28-2016, 07:10 AM   #353
NastyBuzzard
NastyBuzzard's Avatar
I tried to find that bracket to buy... They don't list it on ebay anymore and I cannot find it on there site???
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 10-28-2016, 07:15 AM   #354
mcmlxix
mcmlxix's Avatar
I think you just have to call them. Hopefully they still offer it. Once my Blazer is finished I can sell off some spare parts including the brakes....and knowing that the brackets really available will help.
Rich
Old 10-28-2016, 07:33 AM   #355
NastyBuzzard
Exactly, if you have a spare set I may be interested but I would need those brackets. I was going to start designing my own until I found those. Then I was like well since it already exits then blam couldn't find them for sale. I will see about giving them a call or something.
Right now though the main concern is finding a solution for the front. I don't want to swap to ford knuckles and use their brakes but they seem a lot better than stock at the least. I am not sure what options I have.
Old 10-29-2016, 12:24 AM   #356
porpaintt
Hey Nasty,I am attaching 2 pictures of the crew I am building,73 3+3.
Look at the narrow pillar between the doors,and see if you can tell me what went there in those two holes,they look like a factory hole.
I took this truck apart 20+ years ago,and don't remember what was there.
porpaintt is offline   Reply With Quote
Old 10-29-2016, 12:27 AM   #357
NastyBuzzard
I'll look into it but that's a first for me. I can't say they couldn't be factory or dealer but they look like someone added those holes. I'll do some investigating.
Old 10-29-2016, 12:28 AM   #358
porpaintt
On another note,I have heard of Saluda NC,where is Saluda SC?
Saluda NC has the steepest railroad grade in the US ,4.3 percent
Old 10-29-2016, 12:29 AM   #359
NastyBuzzard
Saluda SC is in the midlands. About 40 miles west of Columbia SC. Super small town in the woods
Old 10-31-2016, 02:26 PM   #360
NastyBuzzard
Not much for updates.. It was a very busy weekend. Hopefully I will get my revised engine xmember on order this week.
I will be picking up a 1 ton crew cab 4x4 front frame section next weekend though. It should make the next crew cab 4x4 swap much easier, but mostly I will be jigging it up to make some more prototype parts off of .
I also found another NV4500 swapper who didn't want to use the AA conversion bellhousing that is around $500 total. He had 4" lift but said even at stock height he said it would never come close to having the driveshaft hitting the bellhousing on the crew cab.
http://www.pirate4x4.com/forum/chevy...g-build-3.html
So I started to look at ways for me to do it, one hurdle was the plastic line. I didn't really like the swagelock piece that he used...
This one.. https://www.swagelok.com/en/catalog/...-500-6-4&item=
So I went to look at the factory Nv4500 clutch parts.
So... The plastic line has a metal line... Idk why I thought it was all plastic! Problem solved.
Use this and make an AN line/SS braided line to the Wilwood Master and voila right?
I guess we shall see!
mcmlxix I contacted the people who made the bracket to bolt onto 14BFF to convert to newer style brakes and guess what. Their volume wasn't high enough so they quit selling the part!! So ****. Still trying to work out what I am going to do for brakes.
Old 10-31-2016, 03:27 PM   #361
MalibuSSwagon
I'll have to do some digging for the parts list, but we did a NV3500 swap in my buddies 88 Suburban using the stock 1994 slave cylinder with that adapter, the stock squarebody master with an AN adapter and a custom line. Worked quite well.
Looks like I deleted the parts list. But the adapter for the master is easy to find, and you already found the slave adapter.
MalibuSSwagon is offline   Reply With Quote
Old 10-31-2016, 03:29 PM   #362
NastyBuzzard
Awesome that is the info I need to know. I am dying to get some parts on order and some progress going.. I have some vacation I have to use before the end of the year so I would love to have a parts pile built up by then!
Old 11-01-2016, 07:36 AM   #363
NastyBuzzard
New image of my conversion crossmember. Working on getting rev 2 made!
Found a guy on facebook last night who was showing me alternative ways to mount turbo in the square... Really interesting, would love to keep air box as is and add an intercooler for sure. Thoughts?
Old 11-01-2016, 12:42 PM   #364
daddyjeep
daddyjeep's Avatar
That's the beauty with turbos...you can mount them wherever you want. You should do it like this...
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 11-01-2016, 12:43 PM   #365
NastyBuzzard
Hell yeah! I dig it!!
Old 11-03-2016, 01:37 PM   #366
NastyBuzzard
Finally sourced a bracket that allows me to bolt on brakes from 08-13 Dodge 2500/3500.. So 14.125" rotors and dual piston calipers on order soon! Slip on rotors for GM dana 60 kingpin. Woohoo! I ordered my set today, wasn't really cheap but I think they will be worth it. Hopefully they will arrive next week.
Old 11-03-2016, 09:11 PM   #367
Wide Open
Sweet!
If you can source some more I'm interested! 😋
Wide Open is offline   Reply With Quote
Old 11-03-2016, 09:44 PM   #368
mcmlxix
mcmlxix's Avatar
Please divulge the source.
Rich
Old 11-04-2016, 06:43 AM   #369
NastyBuzzard
WWW.TORQAXLE.COM
They list a dana 60 big brake kit but if you call and talk sweet to them they will sell you just the brackets. They are around $200 for a set + shipping.
Here is a thread I found that lead me to them.
http://www.pirate4x4.com/forum/gener...tor-setup.html
Old 11-07-2016, 09:55 AM   #370
NastyBuzzard
Axles disassembled. Got to order some rotors so I can see what OD the hubs have to be turned down to.
I did pick up some used Dodge front calipers.
I also picked up the front frame portion. I was unaware that they implemented a kind of stock steering brace at some point.
Anyone know the OD of the rear 14BFF hub? I forgot to measure and I need to order rear rotors from a 2500HD. Well they had AAM 11.5 and AAM 10.5, the 11.5 went under duramaxs and 3500s and the 10.5 went under gas 1500hd/2500/2500HD. Apparently the rotors are different. I think I will be fine running the 10.5 rear rotor which is a little shorter than the 11.5 and the hole for the hub is quite a bit smaller.
I am going to be modeling up the rear adapter bracket soon. Awaiting the front mounting brackets. Slip on rotors here I come!!
So... I have the fronts disassembled... So now would be a good time for kingpins, which seem fine but if they aren't too expensive may as well replace. More importantly though, the ujoints in the "halfshafts" of the dana 60 look like they are from 1979 so... How hard are they to replace? May as well do that while its torn down.
Old 11-07-2016, 10:37 AM   #371
Wide Open
Are you going with the slip on style rotors mentioned in the other thread or the bolt on style?
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Old 11-07-2016, 11:40 AM   #372
NastyBuzzard
Slip on front and rear mounting in front of the hub not behind it. Front rotor is 14.125" in OD with a nice giant dual piston caliper. It won't clear 15" wheels but that doesn't bother me. A lot better brakes which are a lot easier to service and found in parts stores everywhere.
Old 11-07-2016, 11:43 AM   #373
Wide Open
Yeah I've read through all the links you've posted and I'm interested in upgrading my brakes too but don't think I have a slip on option.
1972 K10
2002 Z06
2007 Escalade
Old 11-07-2016, 11:45 AM   #374
NastyBuzzard
Why would you not have slip on option?
Old 11-07-2016, 12:03 PM   #375
MTCK
MTCK's Avatar
https://m.youtube.com/watch?list=PLA...&v=KleZ8eGogHo
This guy is a member on here. I need to do one stub shaft u joint on my 91...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
