07-26-2013, 02:34 PM | #376 |
Re: Cheap Tricks
If you want to save cash dont restore your old truck.
07-26-2013, 06:03 PM | #377 |
I am a Referee of life.
Re: Cheap Tricks
I'm going to the "restore" next week to look for a good quality file cabinet.I plan on using it as shown earlier for power tool storage but also plan to put a grommet in the back and mount a power strip in the top drawer,That way I can keep my tool batts. recharged.I'll also use a drawer or part of one for abrasives like sandpaper and grinding disc.I may have to get 2.........
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
07-26-2013, 06:43 PM | #378 | |
Countdown Survivor
Re: Cheap Tricks
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
07-28-2013, 04:10 PM | #379 |
Re: Cheap Tricks
Get a few divider folders that hand in the drawer and you can separate by grit,style(DA or hand or wet/dry. The back of the drawer will work for grinding wheels and such.I find it easier to keep abrasives,and other stuff organized by type of item.
07-30-2013, 12:18 PM | #380 |
Re: Cheap Tricks
Add a 1 teaspoon of dish soap to your windshield washer fluid,it really makes a difference as far as cleaning fresh bugs off
07-30-2013, 12:55 PM | #381 |
Re: Cheap Tricks
i want you to want me! oh wait a minute, thats cheap trick!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
07-30-2013, 01:59 PM | #382 |
Re: Cheap Tricks
show truck? or maybe you just like to impress those driving by
while you change a flat tire? no more unsightly scratches on your jack with the help of a little heat shrink tubing! ---
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
08-03-2013, 10:15 AM | #383 |
Re: Cheap Tricks
Here's a couple:
Tube bender converted to air-over-hydraulic using a Harbor Freight Ram. Then tuned vertical using round table stand. No longer has to be mounted to the floor (Hydro is +$400 from JD2 ). This cost me less than $50: Made this beading tool from vice-grips (can do smaller diameter tube than my bead roller can). Used for making beads on aluminum cooling lines: Bench Mounded: Pads added to prevent external indentations: Installed (lower one kinked and was remade) : 2nd go at lower line: |
11-27-2013, 10:11 PM | #384 |
Re: Cheap Tricks
Here is one, don't know if it has been mentioned yet. One day I was with my buddy in his S10 and a tie rod end went. I used one of his cam action tie down straps. It got us almost home before it came off! we stopped and I put it back on and we made it. Needless to say he drove slowly the whole time. Can't be positive about any results someone else might have, but it worked for us.
01-03-2014, 03:24 PM | #385 |
Florida Edition
Re: Cheap Tricks
Thought I'd bring this back up as there is soooooo much talent here. Every time I look in here I learn something new and valuable.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-14-2014, 05:54 PM | #386 |
Re: Cheap Tricks
This thread is awesome!
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!) |
01-19-2014, 03:55 AM | #387 |
Re: Cheap Tricks
This is my Hillbilly Drill Press. I made it with scrap pieces from my work while at work so I even got paid to build it. I made it to fit the big Milwaukee drill at work and my 1/2" Makita drill. This is the easy way to drill the frame of a truck to install say Sway Bar brackets, or holes for an Air Bag installation, Trailer Hitches etc. I made the handle removable for easy storage - OK I actually made it to be disassembled so I could sneak it out of the plant in my lunch box.
01-19-2014, 04:21 PM | #388 | |
Re: Cheap Tricks
01-19-2014, 07:32 PM | #389 |
Re: Cheap Tricks
It also prevents dirt, rust, crud & hot metal shavings etc. from getting in your eyes, down your neck and sleeves. Unfortunately not everyone has access to a welder, drill press, chop saw etc. to make such an okie contraption.
01-22-2014, 02:02 AM | #390 |
78K & 79C Jimmys
Re: Cheap Tricks
I'm doin some wall paper removal...
and i realize the soaking with a sprayer is not working as well as it has it the past, paper just dosn't hold onto the water,and then the gravity thing. Left wall came off in little strips= 4 hours put an old pillow case up with tacks,and soaked it......a few times,moved it around bout an hour ,came off in big pieces. went full scale,i'd say it works... use thumb tacs all over, to be against the wall and spray
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-22-2014, 10:43 AM | #391 |
Re: Cheap Tricks
I don't know if this would work for wallpaper, but if you want to remove window tint very quickly and easy, use a clothing steamer.
Just run the attachment slowly back and forth starting on one edge and in a minute or two you can start to peel it, then move down(or left - right depending where you started) and continue back and forth. I saw this somewhere online a while back and recently needed remove some tint. I was amazed how fast it worked, less than five minutes per window!
01-22-2014, 04:16 PM | #392 |
Rusty Nuts
Re: Cheap Tricks
I have not read all of the tips yet and will get through them tonight.A bunch of useful tips here. But here is one, when changing your oil filter and do not want oil all down the sides of the filter and your hands. Take a sharp screwdriver or and ice pick and poke a hole in the bottom center and let drain while your engine oil is draining. Hands stay clean and probably your frame and engine. Hopefully not already posted on here.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
01-23-2014, 10:03 AM | #393 | |
78K & 79C Jimmys
Re: Cheap Tricks
may have to try that
01-24-2014, 02:44 PM | #394 | |
Re: Cheap Tricks
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
05-01-2014, 12:26 PM | #395 |
Re: Cheap Tricks
Found a tip on MyTractorForum, instead of adding Slime or fix a flat, use liquid starch in my garden tractor tires. $3.55
Cheaper than the other choices and way cheaper than adding tubes. Also easy clean up if tires do need to come off. Was adding air every mow. Just added last weekend. We'll see how it works out. The one bad part was going to Walmart to get the stuff.
"I feel the need for speed!"... as soon as I am done with my nap. |
05-01-2014, 02:38 PM | #396 |
Re: Cheap Tricks
Never heard of liquid starch ,how much do you use per tire such as a Zero turn mower tire ?
05-01-2014, 02:54 PM | #397 | |
Re: Cheap Tricks
I added 16oz per tire the same amount that Slime suggests. see thread for Slime link chart.
05-01-2014, 02:56 PM | #398 |
Re: Cheap Tricks
[QUOTE=flashed;6655059]Never heard of liquid starch ,QUOTE]
And Unless your already going there, don't bother looking for liquid starch at regular grocery stores (or the dollar stores) I had no such luck and ended up having to go to Walmart.
05-02-2014, 12:08 AM | #399 |
Re: Cheap Tricks
Used to go flat in a day or two. Added last Saturday and they still look good!
05-02-2014, 01:12 AM | #400 |
Re: Cheap Tricks
old stuff I put a wipe of clear silicone on the bead before seating tire. Keeps the air in.
