Old 08-11-2011, 04:53 PM   #376
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Finally starting my Longhorn 4x4 conversion
I gotta say, I am picking up A LOT of body work tips from following your build! These are some things I need to watch when its time for re-assembly!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-11-2011, 07:46 PM   #377
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome progress!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-11-2011, 10:13 PM   #378
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Thanks, I try. If you see something and you want to know more, just ask and I'll try to help you out.
Originally Posted by 72BlckButy View Post
Awesome progress!
Thanks Nate!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-12-2011, 03:50 AM   #379
Dieselwrencher
I tried adjusting the door in, and I moved the fender forward so I could pull the bottom out some. I think it looks a little better now.
Ryan
Old 08-12-2011, 04:00 AM   #380
Dieselwrencher
Tonight I finally got the courage to install my head liner and new trim. I was nervous because I didn't want to break the trim, and I didn't want my head liner falling down. I used some heavy duty spray adhesive, sprayed the inner roof panel and the back side of the head liner, then let it set for about 10 minutes. I honestly think letting it sit was the key. I pushed the head liner to the cab and it stuck pretty much right now. The last time I tried it, the headliner barely stuck to the cab. But last time I only sprayed the head liner and allowed no curing time. I also installed my sun visors. Progress is progress right?
I also dug out my best cowl panel and set it on to see how things were lining up. So far so good, I think.
Ryan
Old 08-12-2011, 04:49 PM   #381
jbclassix
Junk Yartist
jbclassix's Avatar
Are you gonna start a build thread on your 76 CC? I looked for one but couldn't find it.
-Jeremy
Rebuilding an NP205
Old 08-12-2011, 04:56 PM   #382
Dieselwrencher
I might re-start one. I'll find the original one. I'm hoping to start the rework in about 2 months. If the lift and wheels and tires sell, it might be sooner. We'll see.
Ryan
Old 08-12-2011, 05:01 PM   #383
Dieselwrencher
Here you go.
http://www.67-72chevytrucks.com/vboa...d.php?t=414168
Ryan
Old 08-13-2011, 04:58 PM   #384
jbclassix
Junk Yartist
jbclassix's Avatar
Nice! Can't wait to see that thing get family sized
-Jeremy
Rebuilding an NP205
Old 08-16-2011, 03:17 PM   #385
Dieselwrencher
Some more progress. I put the radiator support back on and bolted the fender back on so it would be solid while pulling the dents out. I'm using my Matco stud gun and body hammers to pull these dents. I try to use a hammer and dollie when I can get one in there. Here's some progress pics.
Here's one in the upper roof area.
Ryan
Old 08-17-2011, 04:57 PM   #386
spudz
spudz's Avatar
I just found this build.. man you got some skillss. I love this truckk Reminds me of a ford highboy on steroids.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 08-18-2011, 04:42 PM   #387
Dieselwrencher
Thanks.
Ryan
Old 08-18-2011, 04:47 PM   #388
Dieselwrencher
I went to my local 67-72 parts guy to purchase a new RH fender to save me some body work time. However, when we pulled the only one he had in stock out of the box, it was not right. On the lower portion of the fender where the body line comes off the wheel arch and goes to the door , the line was crooked and the body line was off and it had some dings in it. He had some repairable OE fenders so I got the best one he had that I could see for sure was an OE fender. I have to fix some rust from the normal battery acid drip on the lower cup, but it's better than the RH fender I currently have. Dang, no cutting time on this one!
Ryan
Old 08-25-2011, 04:16 PM   #389
Dieselwrencher
No real progress, but I did score some 99 up 8 lug chevy wheels off of the local CL. I'm going to take them and get them polished next week, then put them on. I also forgot, a few weeks back I met Eric, Toomuchstuff, in Mn and picked up some sweet Longhorn upper mouldings. Thanks again Eric!
Ryan
Old 08-25-2011, 10:03 PM   #390
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Progress is good!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-29-2011, 02:38 AM   #391
Dieselwrencher
This weekend I was busy working on customer trucks so I had a couple guys start removing the bed sides from my donor bed. They almost got it torn apart and only a few bolts are left. Yee haw!
Ryan
Old 08-31-2011, 04:52 AM   #392
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 08-31-2011, 04:45 PM   #393
Dieselwrencher
Yesterday I did go pick up a new fender and more goodies for the truck. Parts keep piling up, but there just isn't any time for it. I highly doubt it'll be making the All Truck Nats next weekend.
Ryan
Old 09-23-2011, 01:53 AM   #394
1972hays
1972hays's Avatar
Cool Re: Finally starting my Longhorn 4x4 conversion
wow thats a lot looks good get-er-done
72 chevrolet 4wd 350/350 swb fleet green mean army machine
1972hays is offline   Reply With Quote
Old 09-23-2011, 04:44 PM   #395
Dieselwrencher
No real progress on the truck. Just more dust build up on it. I have 2 more customer trucks to get out of the way and then I need to get on this thing. Poor truck is a big azz parts bin now!
Ryan
Old 09-26-2011, 01:45 PM   #396
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Looks nice. Did you find a couple donor steel floors to make a long floor yet?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 09-26-2011, 04:12 PM   #397
Dieselwrencher
Jud, I got a floor and I'm going to cut it in between the two front cross members. I purchased a bed floor patch and I'm going to use it to add in the missing 6". We'll see how it works.
Ryan
Old 09-27-2011, 03:45 PM   #398
Dieselwrencher
No progress yet, but I did purchase an older Meyers 7' snow blade for it. It didn't come with the pump or mounting brackets. That's okay because I want to build a mount with removable pump and head lights. I hate how the old plow mounts have the front bumper pushed out and the pump and stuff hangs on all year. No thanks.
We got a few customer trucks done so I hope to get on this thing soon. I'd like to get it running or painted, or something.
Ryan
Old 09-27-2011, 08:43 PM   #399
Vintage Windmills
Vintage 4x4s
Ryan, Do they use road salt in your area? Seems like too nice of a truck to salt up and dissolve by driving in the winter. Looking forward to seeing the custom floor.
Old 09-27-2011, 09:23 PM   #400
mosesburb
I had a V-8
mosesburb's Avatar
Nice plow. So the snow is what, two maybe three weeks away, are you going to have this ready for it??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
