Old 01-11-2014, 11:36 PM   #376
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: My long term 57 project
Also fabbed up a mount for the Drier. Will be mounting it under the fender/fender wheel on the outer flat panel of the cowl.
ChuckDriver is offline   Reply With Quote
Old 01-11-2014, 11:46 PM   #377
59stepside
59stepside's Avatar
Nice fab work. I really like the bed wood color too. Looks really good.
USCG Aviator
C-130
1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386
59stepside is offline   Reply With Quote
Old 01-11-2014, 11:49 PM   #378
Flames97
Flames97's Avatar
Wiring and mount turned out nice!!
-Aaron
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 01-11-2014, 11:49 PM   #379
ChuckDriver
I was also able to get the heater lines done. I covered them with a nylon mesh used for covering electrical wires and cables, then used heat shrink tubing to keep it in place.
I will be re-doing the shrink tubing on a couple of the ends to make them more uniform and cover the complete crimped end. I'm also thinking of painting the fitting a flat black too. This was all done to make it look a little more custom and have somthing besides plain black hose. What do you think?
Old 01-12-2014, 12:23 AM   #380
oldman3
oldman3's Avatar
Very nice work on the bracket, the covering makes the lines look so much better...Jim
oldman3 is offline   Reply With Quote
Old 01-12-2014, 12:04 PM   #381
Kim57
Kim57's Avatar
Very nicer.
Those hoses look sweet.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-12-2014, 12:05 PM   #382
Baldeagle SR
Originally Posted by ChuckDriver View Post
Its all Vintage Air equipment that I ordered through Charlotte Rod and Custom. Got a great deal on everything.
http://www.charlotterod.com/
Thanks!
Thanks I will give them a look see.
Rich
my build
http://67-72chevytrucks.com/vboard/s...d.php?t=576185
Baldeagle SR is offline   Reply With Quote
Old 01-12-2014, 06:28 PM   #383
_Ogre
_Ogre's Avatar
nice attention to detail. all it takes is time and money
i like your heater hose fittings, i used stock nipples and hose clamps now they look cheesey.
shop air compressor timer
Old 01-12-2014, 08:29 PM   #384
ChuckDriver
Thanks guys I appreciate your comments!!
Old 01-12-2014, 11:33 PM   #385
Dan in Pasadena
Dan in Pasadena's Avatar
Hi JJ,
Outstanding work...as usual. I really like the mesh covering but even more important is that it'll provide some protection. And every little bit of that will help since you're running them through the wheel wells, right? Maybe I missed a detail but HOW are you securing the lines up over the tires securely?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 01-13-2014, 10:19 PM   #386
ChuckDriver
Thanks Dan! My plan is to make some simple L brackets that will attached to the fender to fender wheel bolts, and use adel clamps and zip ties. I'll be sure to post pics when I make the AC lines and have them all in place.
Old 01-13-2014, 10:31 PM   #387
Dan in Pasadena
My only comment is that zips ties come in a couple of materials. I may be misstating this but I think the cheaper, more brittle ones are PVC and the better ones are nylon. I've never had any issue with the cheapo ones I buy from Costco or Harbor Freight, but for something as important as your application I'd check into which will hold most reliably.
Old 02-04-2014, 05:55 PM   #388
daveshilling
daveshilling's Avatar
Had her up on a lift last week doing an oil change. Thought you might like to see some pics!!
how do you fill that Master Cylinder when its under the cab? I tried, and although it got done, it was messy.
daveshilling is offline   Reply With Quote
Old 02-04-2014, 10:15 PM   #389
ChuckDriver
Very slow and carefully with a couple small bottles. It was a little bit of a challenge, but worth it, and its not something that has to be changed very often.
Thanks!
Old 02-05-2014, 07:43 AM   #390
fabguy
Elev8r Man
fabguy's Avatar
Excellent work, I really like the attention to detail on the routing of the lines. Good job
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 02-05-2014, 02:15 PM   #391
ChuckDriver
Thanks! I really enjoy watching your C4 install, got the wheels turning in my head for sure!
Old 02-05-2014, 11:56 PM   #392
Flames97
Flames97's Avatar
Keep up the great work. Love this build.
-Aaron
Old 02-06-2014, 08:11 PM   #393
59stepside
59stepside's Avatar
Truck is looking great. I like the details, very professional. Seems like once you look at aviation methods, nothing else looks as professional. Heater hoses look very good.
USCG Aviator
C-130
Old 02-06-2014, 09:43 PM   #394
ChuckDriver
Thanks again fella's! I plan to redo the heatshrink on the hoses soon!
Old 02-10-2014, 11:15 PM   #395
apache200
apache200's Avatar
Well I got her back home today!! Made a little progress getting it back together. I think it's going to turn out nice.
ChuckDriver where did you get the round ac vents from that you put in your dash? Also where did you get your dash switches from, I am looking for some for my dash. Thank you
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 02-11-2014, 11:54 AM   #396
ChuckDriver
The round AC vents came from Vintage Air. The headlight switch came with the wiring harness, the wiper switch came with the motor from Brother's, and the ignition switch is the original from GM!
Thanks!
Old 02-11-2014, 08:17 PM   #397
apache200
apache200's Avatar
Thanks for the info! my dash did not have any switches or heater control with it, so I have been looking around for sum or other options.
1955 BBW Fleetside
Old 03-16-2014, 09:54 PM   #398
ChuckDriver
Well it's been a while since my last update, but I've finally made some progress!
I was able to finish all of the AC lines, mount the drier and get the tri-nary switch wiring run. Also got the lines secured to the L-brackets bolted to the fender/fender well bolts.
My AC guy charged it with dry nitrogen to 110 psi, we'll check that hopefully Tuesday to ensure we have no leaks, then charge it with 134!!
Old 03-16-2014, 10:49 PM   #399
Flames97
Flames97's Avatar
Excellent work as usual.
-Aaron
Old 03-16-2014, 11:12 PM   #400
solidaxel
solidaxel's Avatar
Are you using the nitrogen for a drying agent or just pressure testing?
How long will it stay in a vacuum, did you evac. after the nitrogen charge?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
