Old 08-27-2010, 08:46 AM   #376
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Project: Recycle
Nice design work Scot.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-27-2010, 03:10 PM   #377
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks Good. I wish I could work on mine...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-30-2010, 07:32 PM   #378
SCOTI
SCOTI's Avatar
Well... One step foward, 2 steps back. I worked on the front shock brackets Friday after work & Sun afternoon, but ran into issues.
Because each of the brackets is hand cut & trimmed independently, there were subtle variations on each. Those variations were causing problems w/alignment or positioning when trying to determine the optimum placement.
I could tweak their position, but then when I placed the top covers on them, the covers were not consistent from side to side & looked like butt (not very square & didn't 'flow' well). I was going to try & have my GF's company laser cut some consistent brackets based on my template but they're busy & I didn't want to be a wrench in the works. Instead, I'm going to use some of the RideTech 'universal' weld-on units & I'll tweak from there. They will be a more consistent starting point so I'll end up w/a better finished result.
So.... Sunday evening I played around w/my vent window frames. I wound up grinding the 2 rivets off the pivot bracket which will allow installation of the window frame seal. I used small beveled seat machine screws in place of rivets for re-assembly (just verifying they'll do the job). I still want to blast the vent window frames & get them in black epoxy before re-assembling everything.
After that, I started making a reinforcement plate for the gauge lens I used in the modifed cluster. The OE lexan/plastic gauge lens was a bit flimsy w/all the holes poked in it. When installed in the housing, it was 'ok', but I felt it could be improved upon (cheaply). I used some steel (0.060 I think) & made a backing plate for the lens. I'll panel bond the 2 together & it should work well (seems more solid just flexing them when not installed). A little more weight, but not so much it will be an issue.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-13-2010, 06:12 PM   #379
aggie91
aggie91's Avatar
Its been 2 weeks, anything new? Are you still trying to make the Goodguys show at TMS Oct 1-3?
Karl
The LST Challenge:
Old 09-14-2010, 12:22 AM   #380
SCOTI
SCOTI's Avatar
I just got the Ride Tech shock brackets in today (I actually just opened the shipping box on the couch while watching the 2nd game tonight). I had arranged to have them brought to the GG's Kansas show last week. I inquired about them @ the show & although they did remember to bring them, he left them w/his personal belongings in the 'shop' dually . . ..... which was apparently being used by Bretts wife for a 'shopping' excursion. By the close of the show Sat, they still were not available. He suggested I return to get them on Sunday @ some point but we bounced back to DFW bright & early Sunday morning....
While I'd love to drive this truck into the FtWorth event, I know what it takes to get one together & it's highly unlikely. I'll still be @ the show, sans the 64.
I did finish the gauge cluster. It's very solid now so the steel 'backing plate' was a good decision.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-15-2010, 11:06 PM   #381
SCOTI
SCOTI's Avatar
I got a couple minutes of shop time & verified the Ride Tech universal shock mounts will work w/a little tweaking for my application. I'll move forward on them as soon as I finish some necessary attention toward the 74.
They're doing major construction in my area & the service road into my subdivision is fubar BAD. Well, navigating through the work zone as carefully as possible yielded a solid THUNK (as in you stopped moving THUNK).....
The result? Two broken manifolds & 2 tweaked OE a-arms. I gotta get the exhaust corrected. The a-arms are drivable but look pretty ugly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2010, 12:46 AM   #382
watahyahknow
watahyahknow's Avatar
that sucks i myself ruined a 4 day old low profile tire and a rim on a pothole once and the one responsible for maintaining that road paid the costs for replacing them ..... this was in europe
i think you can get the construction company for the road or the city lyable for the damage as they didnt closed the road or made an alternative for that road to youre company , might be hard to prove the road responsible for the damage unless you make pictures .
as long as you stay reasonable in youre expences they shouldnt give you too hard a time
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-16-2010, 05:02 PM   #383
Painter D
Painter D's Avatar
Well that sucks. I know what you're sayin though ,that construction going on over in your neck of the woods is pretty brutal.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 09-16-2010, 10:50 PM   #384
SCOTI
SCOTI's Avatar
Well.... I ordered 1ea pass/driver manifolds for the 74 & got 2 pass units. Since that was definitely the worse of the two, I swapped it out & I'm back in business. The driver side isn't leaking for now but it definitely is cracked.
I'll be working on shock mounts this weekend (Sat).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-17-2010, 08:09 AM   #385
watahyahknow
they can be welded with a special weldingrod , i heared sumting of a vibrating table where you mount it on during welding and let it cool inside sand to keep the moleculair structure close to cast iron and prevent stresscracks
Old 09-17-2010, 08:54 AM   #386
SCOTI
SCOTI's Avatar
I would just swap to headers before that.... just didn't want to go that route @ this time. Patch it & return my focus to the 64!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-19-2010, 01:54 AM   #387
SCOTI
SCOTI's Avatar
I got some time in today to work on the front shock mounts. I spent about half of that time running back & forth between local auto-part joints, Home Depot, & my house. Frustrating to say the least but I pushed on....
The shocks are C10 spec'd Bilsteins, 15.5" extended length w/5" of travel. I set them @ 13.5" length @ 6.5" bag height which = my ride height. This should allow 3" compression w/o fear of bottoming out yet still allow the bag to 'air-out' if desired.
I cut off the dbl shear shock brackets I had previously welded on the Ride tech lower a-arms (I was concerned the upper/lower shock eye orientation @ opposing 90° angles would cause a binding condition). I welded some 'new' shock tabs on the side/top of the a-arms (just like how they sell them now). After some intial measurements, I trimmed the universal Ride Tech upper mounts to yield the correct distance between the upper & lower mounts while clearing the upper a-arm shaft hardware & the frame.
In these pics, I haven't welded the upper mount yet because I'm still working on the driver side. I want to ensure both sides are the same (placement, angle, & appearance) before final welding of the upper portion. I still need to do the fit & finish on the driver side upper mount & then I can weld both sides up.
I also picked up some vent window setting tape @ the swap meet yesterday to start reassembling the vent windows & got my Hush Mat 'kit' for the cab.
I think I nailed my target dimensions for the shock length looking @ the last pic . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-19-2010, 09:27 AM   #388
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work SCOTI!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-19-2010, 09:58 AM   #389
VA72C10
VA72C10
VA72C10's Avatar
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-19-2010, 02:42 PM   #390
MattA
MattA's Avatar
The new lower mount looks much better. Good work.
MattA is offline   Reply With Quote
Old 09-20-2010, 08:27 AM   #391
N2TRUX
Happy to be here
N2TRUX's Avatar
Progress is good bro. Glad to see you got this obstacle resolved.
Articles-
"Refining Sierra"
Old 09-21-2010, 09:01 PM   #392
Painter D
Painter D's Avatar
Nice work
Old 10-01-2010, 12:35 AM   #393
SCOTI
SCOTI's Avatar
Welding on the front shock towers is complete....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-01-2010, 08:10 AM   #394
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nice work!... Nice shop setup.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-01-2010, 08:50 AM   #395
SCOTI
SCOTI's Avatar
It the maint shop @ my job. Nice stuff; but even after 22+yrs of employment, I have to semi-covertly work on my 'goverment projects' which usually means deep nights.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-03-2010, 12:34 AM   #396
aggie91
aggie91's Avatar
Nice work on those shock mounts. I know what you mean about those "government jobs".
It was good meeting you today.
Karl
The LST Challenge:
Old 10-03-2010, 06:58 AM   #397
watahyahknow
thats clasified information
Old 10-03-2010, 08:39 AM   #398
SCOTI
SCOTI's Avatar
Funny, but true. I can give my friends/family a tour of the plant where I work. You can see everything except the main area where I work..... it's pass-key access only (even for internal employees).
The funny part is I'm nobody..... Just an average maunfacturing employee.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-06-2010, 12:20 AM   #399
SCOTI
SCOTI's Avatar
More progress but no pics yet.
I set-up my extra swb frame w/a DM main crossmember on my trailer. It's just the main rails, front DM x-member, & T/A x-member sitting on some 2x4's & spare wheels. This allowed me to put the sbc/700r4 in place for determining the tranny x-member needs.
I have several x-members for consideration & decided to use an ECE x-member as I feel it will offer better torsional rigidity vs. a tubular unit (it bolts to the top & bottom of each frame rail vs. just the sides).
Because the DM relocates the drivetrain slightly, I'll need to cut the mount 'flange' off the x-member, flip the x-member 180°, & re-weld the mount flange. This offered the best alignment of the 'puzzle pieces' & should work well. I'm actually going to place the mount flange w/a little fudge factor in the dimensions & use a shim for dialing in the level (to set the carb flange @ 0°).
I ran out of time tonight so I'll try & get @ it earlier tomorrow. I had to wrap the drivetrain in towels, cardboard, & plastic to keep moisture @ a minimum until I can get it back in the garage tomorrow.
I'm crossing my fingers we won't see any sudden 'scattered showers' before then....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-06-2010, 09:22 PM   #400
aggie91
aggie91's Avatar
Scoti
For the front shock brackets you got from RideTech, how thick is the material they used?
After this past weekend, I think that I might shoot for getting mine rolling/driving for the spring show.
Thanks,
Karl
The LST Challenge:
