Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-04-2015, 10:20 PM   #376
argonaut
argonaut's Avatar
Re: 66 4x4 my sons new project
Chris, it's a chevy, big hub, dana 44. The plastic Spicer hub selectors were cracked when I got it and I tried to repair then by epoxying in steel sleeves. Apparently one failed so I just pulled them off and bolted a pair of hub flanges on. So the front hubs are always locked in, and I haven't noticed any difference in fuel mileage.
I did recently buy some ridiculously priced replacement blue Spicer lockouts. I need to disassemble, lubricate and install them.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 07-04-2015, 10:58 PM   #377
'63GENIII
'63GENIII's Avatar
They look slick Jason. I have no idea what mine are out of. I thought they were Chevy, maybe Mopar. Just got a set of the Warn premiums. We will see how they work. Yours look killar
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 07-07-2015, 01:05 PM   #378
61K10
61K10's Avatar
Looking good Jason! It's tough to paint big areas with a R/can. hell it tough with a spray gun. be careful if color sanding, you might rub through. For some reason i like the color lol! really only a little different shade than mine.
Do you know the difference in caster on an C/K axle and a newer O/k axle? or just the specs. My steering is still loose feeling after i reduced pump pressure even though it's better. maybe need some more caster in the ft axle. Read some good and bad things of wedges. anyway your tk is looking good.
Kimble
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-26-2015, 07:35 PM   #379
rusty76
rusty76's Avatar
I need to be watching this one for sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-27-2015, 01:49 PM   #380
argonaut
argonaut's Avatar
Kimble
Kimble,
I set my caster to 6* (I think) using steel shims. I think they were 4* shims. I used a pair of shims on each spring, one below and one on top to make sure that the u-bolt plate stayed square to the spring pad on the axle. It might have been only 4* of caster, I can't remember exactly but I'm sure I have it written down somewhere.
What do you mean by "loose" steering? I put a newer model PS pump on my mom's 64 and man that steering is SUPER TOUCHY, but still driveable. Anyway that is a 2wd so not exactly a good comparison. Are you thinking the "looseness" is because you don't have enough caster??
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 08-01-2015, 12:34 PM   #381
61K10
61K10's Avatar
Jason--It just has little feel to it, easy to turn even while stopped. when i put in the 3.31's i will get some 4* shims.
1961 chevy K10
Old 08-05-2015, 12:57 PM   #382
argonaut
argonaut's Avatar
Kimble, park the truck on a flat surface and put an angle finder on the bottom of the lower ball joint. Then compare that to the angle of the level of the ground and you'll have your static caster angle. Then at least you'll know where you stand. I just use a cheap angle finder from harbor freight.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 08-06-2015, 12:55 PM   #383
61K10
61K10's Avatar
put my angle finder on the bottom of the knuckle bearing pin thing with the 4 bolts (don't get old lol) anyway it shows 3*
1961 chevy K10
Old 08-07-2015, 02:44 AM   #384
argonaut
argonaut's Avatar
Looks like you might be good with only a 2* shim. You don't want to get your pinion pointed down any further than you have to.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 08-07-2015, 02:54 AM   #385
argonaut
argonaut's Avatar
Put some big black lug nuts on today.
I wouldn't exactly call it progress, but at least its something.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 08-07-2015, 12:25 PM   #386
61K10
61K10's Avatar
looks good---now paint your hubs lol.
1961 chevy K10
Old 08-07-2015, 12:39 PM   #387
MTCK
MTCK's Avatar
Looks tough! Nice work.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 08-07-2015, 02:32 PM   #388
vectorit
What?
vectorit's Avatar
Looks like you got your hub selectors in
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-07-2015, 08:26 PM   #389
RANDY COX
RANDY COX's Avatar
Big Ugly is lookin good, I believe that the color of your bed is the original color of the bed that's on my truck, at the front panel that's against the cab is peeling and looks like that same color blue.... your truck looks like a Beast and that's a good thing.....Your fenders and door looks good...where you painted them.....Of course I like the sea-horse too, I miss my 70 Burb 4x4... Here's a picture of it now when I had it it was 1/2 ton....
I'd say it's a beast now... It was factory 250 six 3spd 4x4 less than 1,000 were made with this combo, I wished I could have kept that one....Plain Jane version no power nothing...
I added power-steering and upgraded to HEI... had 33's with 4" lift...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-07-2015, 09:20 PM   #390
'63GENIII
'63GENIII's Avatar
Don't want to be the guy getting off topic but that Burb is pretty sick Randy! Wonder if I could con the wife out of her Denali to get something like that!
Chris
'63 k15 long step
Old 08-08-2015, 02:00 AM   #391
argonaut
argonaut's Avatar
Agreed, that is a sweet suburban! I love that 70 grill!
I know how you feel about the one that got away...I wish I never sold my 72 blazer. What a fool I was!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 08-08-2015, 06:41 AM   #392
RANDY COX
RANDY COX's Avatar
Jason I also had a 72 Blazer with 33s and 4" lift. Right before I sold it I had just put 35s on it pro~comp all terrain... Talk about how much bigger a 35 compared to 33s wow...I think we've all had ones we wished we had back...
Old 08-08-2015, 12:35 PM   #393
61K10
61K10's Avatar
this is getting weird guy's----I had a 72 Blazer also-----------
1961 chevy K10
Old 08-08-2015, 01:10 PM   #394
'63GENIII
'63GENIII's Avatar
Lol, so did I.
Chris
'63 k15 long step
Old 08-08-2015, 08:30 PM   #395
RANDY COX
RANDY COX's Avatar
The Twilight Zone........
1964 BBC 402 4x4
Old 08-08-2015, 08:39 PM   #396
argonaut
argonaut's Avatar
So this is what everyone does after the loss of a first gen blazer... they buy and build a 60-66 K10!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 08-09-2015, 01:02 AM   #397
'63GENIII
'63GENIII's Avatar
I guess this makes us a former owner of a 72 Blazer support group? That is kinda weird.
Chris
'63 k15 long step
Old 08-09-2015, 01:06 AM   #398
argonaut
argonaut's Avatar
Come on man! I need your support! I can't get through this 12 step program without you guys!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 08-09-2015, 01:24 AM   #399
'63GENIII
'63GENIII's Avatar
My name is Chris and I like 60 - 66 Chevy 4x4 trucks......
Chris
'63 k15 long step
Old 08-09-2015, 08:20 AM   #400
RANDY COX
RANDY COX's Avatar
LOL,, Hi my name is Randy, Anywho I guess it started when I was looking at 4x4 trucks over on stovebolt.com. I would have loved to had a 56-57 Napco but there a rare piece and MO money So I thought the 60-66 trucks and burbs looked KOOL 4x4 of course then it was on. I saw one on the ole C/L and then it was on, but it's not a factory 4x4, it was still a 4x4. Oh one more thing it didn't help any when I was looking at your alls builds. I think the first builder I got interested in was Oklahomerduner Rock Tonka's son's truck, Then it was Jason's truck and then Rock Tonka's 58 truck and their Burb, then it was 61K10's build and then 63GenIII.. There are other's but you's guys are my favorite...When I find pictures of all my old rides I'll post them over on my build page so's I won't be taking up Jason's space on his build...
1964 BBC 402 4x4
