Old 09-26-2013, 04:40 PM   #376
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by mcbassin View Post
Ah, bringing back memories of when I worked on my doors. All those hole are very time consuming and can warp your metal if you hurry them.
Very nice progress since I checked in last.
On those seams, I used Plio-Grip seam sealer. The no sag stuff if I remember right. LINK
Hey Mike did you smooth it out and finish it so it looks like no seams at all? That what I want to do, but maybe it's not something that's possible. :-/
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 09-26-2013, 06:02 PM   #377
KSWes
KSWes's Avatar
Re: Project 69SWB
I used seam sealer in my jams. Just the stuff from advanced auto parts in a caulking tube. Squirted it in there with a good caulking gun then smoothed it out with my finger wearing nitryl gloves, you have to dip your fingers in clean water as you're smoothing it out to help keep it from sticking to your glove. Using filler up there would be tough because getting it smoothed out it would all have to be hand sanded. And if those seams have any potential to flex a filler could crack I would think. I can take a picture tonight of mine and put it up to see if it's something you'd be happy with if you want me to. I'm going for a good looking solid driver on mine though, not sure if you'd be happy with what I did.
Good to see an update! Nice job getting busy on the doors. Looking good!
70 Chevy C10 LWB
My Build:http://67-72chevytrucks.com/vboard/s...d.php?t=513002
KSWes is offline   Reply With Quote
Old 09-26-2013, 09:04 PM   #378
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Man thanks Wes and yeah put up a pic. I'm going for a good looking daily driver too... Just picky... Too picky sometimes.
Jimmy
.69SWB Build.
Old 09-26-2013, 11:25 PM   #379
Xeen
Xeen's Avatar
Re: Project 69SWB
Originally Posted by ~Whitey~ View Post
how would I smooth it out and finish it flat with the rest of the door jam? Want it so you can't tell there are seams there after I'm done. I've always been told putting filler on top of seam sealer is a bad idea. Have you done it with good results?
I'm pretty sure 3M seam sealer is sandable, but I could be wrong and I'm on my 4th beer and I'm too lazy to find out
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-27-2013, 08:06 AM   #380
Low Elco
Re: Project 69SWB
I used the Lord seam sealer from the body shop supply. Can be used in a normal caulk gun and spreads like buttah. Lacquer thinner on a finger and swipe. Truck looks good!
Low Elco is offline   Reply With Quote
Old 09-27-2013, 08:26 AM   #381
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 69SWB
I did trowel it out as good as I could. I just used a small flat piece of flexible plastic. The stuff I used set up pretty fast though so you have to work quick.
I have seen something I wish I would have done since then, tape off the edges on both sides of the seams. Then you just peel the tape off both side before it completely sets up.
good luck
mcbassin is offline   Reply With Quote
Old 09-27-2013, 10:37 AM   #382
KSWes
KSWes's Avatar
Re: Project 69SWB
Sounds like some good ideas from the other fella's since my post. The seam sealer I put in is sand-able but it's easier to get it smooth before it sets up for sure.
Not perfect but I think it looks ok.
70 Chevy C10 LWB
Old 09-27-2013, 03:04 PM   #383
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
good luck
That looks really good and better than I thought... Since I had my cab blasted I can't remember what it did look like when I was driving it. I don't think I'll worry about trying to make the seams disappear and leave them for what they are.
I appreciate all the input from you guys. Thanks!!
Jimmy
.69SWB Build.
Old 09-27-2013, 07:09 PM   #384
TchncnDen
Re: Project 69SWB
That is the route to take. Seam sealer remains flexible for a reason, if you used a filler without welding them up they would crack.
TchncnDen is offline   Reply With Quote
Old 12-09-2013, 04:04 AM   #385
sduckworth13
sduckworth13's Avatar
Re: Project 69SWB
Jimmy, how's the truck project coming along?
Scott
sduckworth13 is offline   Reply With Quote
Old 12-09-2013, 11:11 AM   #386
Low Elco
Re: Project 69SWB
Yeah! Yeah! What's up heah? Hope you're well!
Old 01-07-2014, 12:50 PM   #387
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks for checking in on me fellas.... I've been sidetracked with some mods to my Harley, but that's done now I'm back working on the truck. I've been putting a lot of time into my doors, wish I could have bought new skins, but no-can-do.
I've basically welded up all the holes from trim and mirrors mounted over the years, filled/layered in the welded area with All-Metal, then I really soaked the insides with Eastwood's Rust Encapsulator and I'm ready to put some primer on these dudes. I think I'll still use some seam sealer on the seams inside the doors.
First layer of All-Metal after welding up the holes
mostly level, I'll finish it out with putty. The runs are from the Rust Encapsulator I spray on the insides. It'll sand off.
Coated pretty nice, got a few small spots to hit again.
Once I get the doors in primer I can mount them and really start knocking out the body work.
Jimmy
.69SWB Build.
Old 01-07-2014, 12:54 PM   #388
sduckworth13
Re: Project 69SWB
Jimmy, I was starting to look for your truck on craigslist, thought you abandoned ship . Glad everything's good and your still at it, doors look good.
Scott
Old 01-07-2014, 01:11 PM   #389
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Never! Not for sale!
Jimmy
.69SWB Build.
Old 01-07-2014, 02:09 PM   #390
Low Elco
Re: Project 69SWB
Glad you're still on this. Gotta see the end!
Old 01-07-2014, 08:59 PM   #391
Bennett68C10
Bennett68C10's Avatar
Re: Project 69SWB
Glad to see your back at it Jimmy, nice job on the doors
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-09-2014, 12:19 AM   #392
jmking9
jmking9's Avatar
Re: Project 69SWB
I was starting to get worried about ya! Glad to see your still at it.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 01-12-2014, 07:45 PM   #393
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks guys.. I've been at it, just got sidetracked for a while on bike stuff.
I decided to take a little detour here from the sanding and the sanding and the sanding and the sanding.. You guys get the idea I'm sure.
I've had ordered my whole interior from a board vendor Truckseats a while back, real nice guy and has the got hookup with some really fantastic products. The quality of everything has been top notch.
So on with the pics.. the best part of any post.
Old and new foam
Laying it all out
New cover and foam installed. My grandson loves to come in my Chevy room (spare bedroom used to store my junk) and get into my stuff!
My dear sweet wife says I can work in the kitchen sometimes if it makes my life easier. I'm blessed.
Closet in the Chevy room is a good place to hang small parts to dry when it's too cold for paint drying in the garage. The brackets I wire brushed, used Eastwoods Fast Etch, painted first with Eastwoods Rust encapusaltor, the top coated with Rustoleum High Performance Paint, says it dries in 15 minutes. Yeah right. No paint dries in 15 minutes. paaalease. But it is good stuff if you let it dry a couple days.
Jimmy
.69SWB Build.
Old 01-12-2014, 07:53 PM   #394
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Here's the seat all done, brackets installed.
Nacho thought he was in trouble when I put him up there on the seat. Only thing I didn't do and I would have if I were made out of money is to have the seat frame blasted and powder coated. But I'd say that's a little overkill for a driver.
Here is a pic of the drivers side. It's all there except for the bigger spring, I have it somewhere just got to find it.
This is the side I am not sure about. I think it should have a small spring and clip on the outside of that key that slides back and forth. Can one of you guys verify what the passenger side bracket is supposed to look like (both sides) where the rod attaches?
Jimmy
.69SWB Build.
Old 01-12-2014, 07:55 PM   #395
sduckworth13
Re: Project 69SWB
Seat looks great Jimmy
Scott
Old 01-12-2014, 09:03 PM   #396
Bomp
Bomp's Avatar
Re: Project 69SWB
Seat looks great.
Storage closet and (room In the House no less) for drying paint, you are one lucky guy.
Grandson, camo jammies and diggin in truck parts (truck guy in the making)
Looks great.
Bomp is offline   Reply With Quote
Old 01-12-2014, 09:17 PM   #397
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by Bomp View Post
Seat looks great.
Looks great.
Thanks fellas, yeah I'll make a truck guy out of that little guy for sure.
Jimmy
.69SWB Build.
Old 01-13-2014, 09:29 AM   #398
Low Elco
Re: Project 69SWB
I was gonna say, you need to get your wife one 'a them pope hats and sing a song, or somethin'. If I tried to bring curing enamel parts in the house, I'd get shot! Lucky man!
Old 01-14-2014, 12:44 PM   #399
KSWes
KSWes's Avatar
Re: Project 69SWB
That seat looks great! Nice progress, sometimes you gotta take a break from one thing and work on another to keep your motivation going. Glad to see the updates!
70 Chevy C10 LWB
Old 01-14-2014, 02:15 PM   #400
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
HA! She's good to me, I can't complain... I am a lucky man indeed.
Thanks Wes! I'm glad to be back on the truck. I want to be driving this thing by summertime.
Next item up for some loving is a fine fine specimen... A 1968 C10 Steering Wheel in all it's glory. Picked this up on Craiglist for $60 Column, Horn Cap (great shape), and all. I never really cared for the look of the 69 Wheels. I won't be using the column as I have a tilt column that was in my truck already.
This is what I'll be using to fill in the cracks after I open them up a bit with a v-cut. I've heard that just using bondo/filler doesn't last but a couple years before it's cracking again, but this stuff or similar products last forever pretty much.
Jimmy
.69SWB Build.
1969, black, custom 10, fleetside, shortbed
