03-06-2016, 11:52 PM | #376 |
Re: A 15 year old's project. Rusty 62 stepside
Nice work... she's really coming along!
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
03-07-2016, 03:07 AM | #377 |
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
03-07-2016, 10:43 PM | #378 |
Did some work on my sending unit today. The sending unit for my underbed tank was a 90 ohms while the factory tank and gauge are 30 ohms and since I wanted to keep the original gauge I robbed the transmitter part of the 30 ohm sending unit and tacked it on to the sending unit for the new tank. Then I soldered the connection and bent and cut the float arm so that it matched the 90 ohm one and stuck the float from the 90 ohm onto the 30 ohm. Tested it with the multimeter and it works great
The 30 ohm transmitter bent and cut and the new float on to the same dimensions as the 90ohm transmitter |
03-07-2016, 10:46 PM | #379 |
And here it is tacked in place and connections soldered
03-07-2016, 10:48 PM | #380 |
Nice work!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
03-07-2016, 10:55 PM | #381 |
03-08-2016, 11:34 AM | #382 |
Great work Nik. I admire your "work with what you have" attitude. You don't just order parts from a catalog.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
03-08-2016, 11:50 AM | #383 |
Thanks Dale, it just kinda clicked in my head that even if all these aftermarket parts weren't available It wouldn't really make a difference as I have bought next to nothing new for it, well that and I'm cheap
03-08-2016, 06:52 PM | #384 |
I think that is pretty applicable to most of us!
03-08-2016, 09:59 PM | #385 |
Ha ha yeah your right about that
03-09-2016, 03:29 AM | #386 | |
I love the way you just figure stuff out and get on with it. What does your family think of all the work you are doing? And as far as being cheap......... I LOVE THE SOUND OF CASH JANGLING IN MY POCKET !!! It certainly beats the sound of it landing on somebody's counter top....... Also means you can use it another day for something more important.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
03-09-2016, 12:05 PM | #387 | |
03-09-2016, 11:04 PM | #388 |
I have to say I really like the looks of the 60-66 body style, not much I would change but the one thing that bothered me was how big the gap between the top of the wheel and the fender lip. I got the idea from vin63's build. So today after school I got busy and started cuting. I added 2 1/2''. Worked through the rain but still made progress. Welded about half of it up. Here is the 2.5'' panel welded in and the lip mocked up
03-09-2016, 11:07 PM | #389 |
Then I cut the lip section in half and moved them apart by an inch so the lips line up and welded in. Only finished one of the two peices of the lip. I should have it done tomorrow
03-09-2016, 11:08 PM | #390 |
500th post! And this is the picture from vin63's thread where I got the idea
03-10-2016, 03:12 AM | #391 | |
Is Hot Rodding.
03-10-2016, 05:39 PM | #392 |
Thanks rian. Your right, even though I won't be going anywhere fast it'll still be a cool hotrod.
03-10-2016, 10:07 PM | #393 |
Did some more work on the fender sectioning. Cut and tacked in the rear portion. Now I just need to weld in the centre section.
03-10-2016, 10:09 PM | #394 |
I also started on shortening the driveshaft. I grinded the weld down on the camaro yoke till I could see a little crack then I tapped it with a hammer and it came right off, then I cleaned off the rest of the welds. Now I just need to measure and most importantly cut it square and carefully weld the camaro yoke to the original driveshaft
03-10-2016, 10:41 PM | #395 |
Post Whore
Looks good buddy! Be Super careful on getting that yoke on there. Ya don't want it to be off because vibrations can cause severe problems.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-10-2016, 10:48 PM | #396 |
Nice job on the fender Nik. I'm interested in seeing it finished
03-10-2016, 11:05 PM | #397 | |
I have been thinking about doing the same thing for a while now I need the front fenders to hide the tire without doing air ride . good to see your doing the driveshaft too. make shore both u joints are lined up the same. I would take the yoke off so you can use the square to check it to make shore you have it straight both ways before you do any welding . |
03-11-2016, 02:57 AM | #398 | ||
Thanks Dale, I'm leaving on a trip to Maui tomorrow for a week but I'll get right back on it when I return and I'll be sure to share pics. Quote:
03-11-2016, 10:55 AM | #399 |
Like the work! Making good progress
03-11-2016, 11:52 AM | #400 |
Thanks, your making good progress on your panel truck as well.
