03-20-2017, 07:10 PM | #376 |
Re: Plus Five
Thanks,
I made it with .060 thick 3003 aluminum. I used an english wheel to curve it to match the curve of the roof panel. It's slightly rounded in both directions. The front moldings at the visor area are also made from the same aluminum. I rolled the profile to match the look of the original headliner retainer... sort of. Then I used the original retainer at the rear. Kind of keeping a metal look to it.
53 Chevy Pickup |
03-20-2017, 09:55 PM | #377 |
Re: Plus Five
Amazing work! Like this truck. Wish I had small amount of your talent.
1950 3100 5 window |
03-21-2017, 04:45 AM | #378 |
Re: Plus Five
WoW!
That's really nice! Your eye for details is amazing!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
03-25-2017, 12:16 PM | #379 |
Re: Plus Five
My son was home today so we mounted the doors.
No major issues, and no paint damage getting it all lined up. Not too bad for a 1953 truck!
53 Chevy Pickup |
03-25-2017, 12:25 PM | #380 |
Re: Plus Five
03-25-2017, 01:00 PM | #381 |
Re: Plus Five
Looks REALLY nice!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-25-2017, 01:27 PM | #382 |
Re: Plus Five
Very nice sir
03-27-2017, 04:04 AM | #383 |
Re: Plus Five
Donandal
You concepts and execution is offffffffff! the charts, When I come on this site I look to for you updates. Strong Work!! I would venture a guess you could earn a few BIG coins selling these quality trucks. Thanks for sharing. NC
Been there, wrecked that |
03-27-2017, 08:00 PM | #384 |
Re: Plus Five
Thanks guys,
Today I messed around with the doors. I put sound deadening inside the door skins and then started putting the hardware on the doors. I put the handle and bearclaws on and put the striker plates on. It closes very nice. Also put in the vent windows and stainless window trim.
53 Chevy Pickup |
03-28-2017, 06:41 AM | #385 |
Re: Plus Five
Door gaps are incredible! Well done. I have door gap envy...
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
03-30-2017, 03:22 PM | #386 |
Re: Plus Five
quick shot of the vent window deflector...
53 Chevy Pickup |
03-30-2017, 03:42 PM | #387 |
Re: Plus Five
I installed the roll up windows today. Kind of tricky to get
it in there but it's in with out scratching the glass. The track along the vent window side is a bit snug fitting. I wiped on a little silicone spray into the felt channel and that helped quite a bit. It's still a little stiff rolling it up and down, but I think it will break in OK. The black rubber wedge trim slides in a channel in the door. That was a pain to get installed. I used 3M black weatherstrip adhesive on the felt strips along the lower window trim and it worked great! The vent window track lower bracket bolts to my door brace. The stop also fastens to the brace.
53 Chevy Pickup |
03-30-2017, 03:48 PM | #388 |
Re: Plus Five
some more photos,
53 Chevy Pickup |
04-02-2017, 05:29 PM | #389 |
Re: Plus Five
finished the installation of the interior door latches
and handles. I used bear claw latches and modified the trip mechanism to accept the actuator rod following the channel in the door. The flat rod they supplied worked great with the original handle rod. I slotted the holes and this allows the handle to travel to the original lock detente. That allows a little more security preventing the door from being accidentally bumped open.
53 Chevy Pickup |
04-15-2017, 09:44 PM | #390 |
Re: Plus Five
Well, no pictures today, but a pretty big day.
We had nice weather this morning and all the guys were around. No more excuses. We pushed the truck out of the shop, got 4 gallons of fresh gas, three fire extinguishers and the rest of the fluids and fired it up. I primed the oil pump then cranked it without fuel or engine computer hooked up. It had 50 psi just cranking. Then I hooked up the fuel pump and turned the key on. Pump worked fine so time to fire it up. It started on second crank of about 10 seconds. Settled right down to a smooth idle and sounds great. We filled the tranny up and it seems to shift ok thru all the gears and wants to move in forward and reverse so all seems good. I managed to get the power steering filled without overflowing and put about 14 and 1/2 quarts of coolant in the system so I think most of the fluids are in. I'll need to fire it up and go thru the whole break-in process when we get more nice weather but at least its been warmed up. No leaks anywhere so far..... Sweet!
53 Chevy Pickup |
04-15-2017, 11:04 PM | #391 |
Re: Plus Five
Congrats, ready for more great updates...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
04-16-2017, 03:19 AM | #392 |
Re:
Donandal
WOW! Again off the charts, great idea on the adjustable connection between the handle and the latch. When you where fabbing the doors and cab, did you use a sacrificial rubber weather stripping between the cab and doors to get the door closing and latch all working well with each other and straight, level and plumb, getting that behind you before you get into paint? I envy your skills and ideas! Keep on keepin on NC
04-16-2017, 11:54 AM | #393 |
Re: Plus Five
Good News, just like you planned it !!
I must have missed the break in procedure, where did you find it!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-16-2017, 01:21 PM | #394 |
Post Whore
Re: Plus Five
Always makes you feel warm and fuzzy on the inside when it fires off for the first time...
04-16-2017, 05:48 PM | #395 | |
Re: Plus Five
shop that installed the rear end gears and posi are going to do some sort of break-in for that too.
53 Chevy Pickup |
04-16-2017, 05:52 PM | #396 | |
Re: Plus Five
I had a real concern with the fuel lines since they were sort of a pain and I had no experience. I very happy I had no fuel leaks. Thanks
53 Chevy Pickup |
04-16-2017, 06:03 PM | #397 | |
Re:
I'll still need to adjust the doors after I put the last weatherstrip pieces on. My old gaskets were reproduction ones that were torn up a bit when I removed them, and they were 5 inches too short to really check the entire fit. Thanks
53 Chevy Pickup |
04-17-2017, 08:52 AM | #398 | |
Re: Plus Five
How did you monitor your oil pressure before you started the engine the first time?
04-17-2017, 01:38 PM | #399 | |
Re: Plus Five
included in a folder with engine/transmission instructions and emission decal and tuning CD. I used a separate oil pressure sending unit from classic instruments that independently supplies their oil pressure gauge that I used in my dash. I disconnected the computer and fuel pump before cranking it as the instructions said, then after a couple of turns I had oil pressure of about 50 PSI. Then I reconnected the fuel pump only, powered the pump on without cranking and looked for leaks, then hooked up the computer and fired it up.
53 Chevy Pickup |
04-18-2017, 12:19 AM | #400 |
Re: Plus Five
Thanks I can do that!
I have a oil gauge screwed to the oil bypass on the side of the pan, but have not turned the engine over It did not say to pressure the system until the rocker arms have oil before turning the engine over? So with the starter motor only you have good oil pressure, did it come right up to 50# ?
