Old 01-08-2022, 12:32 PM   #376
Jason 56
Re: My 56 build
Originally Posted by G&R's57GMC View Post
You would be happier with the vents at the highest point on the dash and at the ends of the dashboard also .
I imagine there’s a reason factory vehicles have them at the top. I plan on putting the other 2 near the top on the ends of the dash. I’ll have to see if I have room for the ductwork to change the location of my 2 in the center console. Can always weld the holes up
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 01-12-2022, 01:37 AM   #377
Jason 56
Re: My 56 build
So I decided to make the center console removable. Welded nuts to strips then welded those to the back of the console. Also finished the placement of the vents and welded up the previous holes. I would of liked to put the outer 2 all the way to the ends, but I need a flat surface. So this is where they are going to be Reworked the plenum for the last time… hopefully. Going to start finish welding the dash tomorrow.
Old 01-12-2022, 10:28 AM   #378
Tempest67
Tempest67's Avatar
Re: My 56 build
very nicely done.
Thanks for the pics
Tempest67 is offline   Reply With Quote
Old 01-12-2022, 11:56 AM   #379
youngrodder
youngrodder's Avatar
Re: My 56 build
Is funny to see all of the AC work your doing when considering how cold it has been in MI as of late....ha ha.
Good work tho.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-12-2022, 01:27 PM   #380
Jason 56
Re: My 56 build
Originally Posted by Tempest67 View Post
very nicely done.
Thanks for the pics
Good work tho.
Marc
Thanks! I know… it’s been about -10* here for about a week. 20* today and it feels like a heat wave. Typical January this far north.
Old 01-12-2022, 03:03 PM   #381
6DoF
6DoF's Avatar
Re: My 56 build
final assembly and future tinkering, i think that waterfall being removable will be money
6DoF is offline   Reply With Quote
Old 01-13-2022, 07:22 PM   #382
Jason 56
Re: My 56 build
So the big brown truck brought me a wire harness. So I’ve been tinkering with that for 2 days. Still looks like a mess, but everything is in place and temporarily run. Figured I’d work out as much under dash wiring before I weld in the dash!
Old 01-21-2022, 11:50 PM   #383
Jason 56
Re: My 56 build
Dash is welded in. No problem getting the vintage air unit in. I have a good start on the bed wood.
Old 01-22-2022, 09:07 AM   #384
Father&son56project
Re: My 56 build
Nice metal work on the console and dash extension. The curves in the steel are nice, and and they blend together perfectly. That's tricky stuff to do. The entire box is looking pretty darn sharp too!
Father&son56project is offline   Reply With Quote
Old 01-22-2022, 01:20 PM   #385
Jason 56
Re: My 56 build
Thanks, after the box and seatbelts I’m going to start laying body filler.
Old 01-29-2022, 10:17 PM   #386
Jason 56
Re: My 56 build
Finished up all the bed wood and strips. 2nd picture is a sample of how I plan on staining the wood. Should look petty sharp with the dark blue body paint. Finally welded in the cowl too.
Old 01-30-2022, 10:56 AM   #387
57FleetsideC4
Re: My 56 build
Looks very nice and I agree the wood stain should match the truck perfect. It's amazing how much hardware there is in the bed of one of these trucks. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 01-30-2022, 11:42 AM   #388
oldman3
oldman3's Avatar
Re: My 56 build
Bed wood color should look great...Jim
oldman3 is offline   Reply With Quote
Old 01-30-2022, 06:28 PM   #389
Jason 56
Re: My 56 build
No question about that Steve. I think the strips alone have 49.
Thanks Jim
Old 02-04-2022, 10:26 AM   #390
mrbuck
Re: My 56 build
Love it!!! What did you use for that stain? I’m also thinking off black stained wood for mine
Bucks build thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=825476
mrbuck is offline   Reply With Quote
Old 02-04-2022, 11:47 AM   #391
Jason 56
Re: My 56 build
It’s just minwax water based stain. I’m using semi-transparent because I still want to see the grain. I choose to use pine for the same reason. Oak grain is much finer. First pictures of the wood has one coat and the last picture has two. I’m planning on one coat. I don’t want to loose the grain in the dark stain.
Old 02-04-2022, 08:20 PM   #392
Jason 56
Re: My 56 build
Spent some time in the basement today. Outside temperature was only in the single digits so not a good day to heat the garage. So I got all the bed wood stained. Next is the clear.
Old 02-04-2022, 08:40 PM   #393
bosco
bosco's Avatar
Re: My 56 build
That's going to look great.
bosco is offline   Reply With Quote
Old 02-04-2022, 10:32 PM   #394
BIGglaSS
BIGglaSS's Avatar
Re: My 56 build
Nice, I like it. I was thinking about doing pine, and burning it with a torch.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 02-05-2022, 01:09 AM   #395
Jason 56
Re: My 56 build
Thanks guys. I’m really happy with the way it’s coming out. I believe the burnt wood process is called shousugi ban. If I were going black I’d definitely do it! Hope it turns out bigglass. I’ll probably start clear coating tomorrow.
Old 02-07-2022, 09:38 AM   #396
6DoF
6DoF's Avatar
Re: My 56 build
that wood came out pretty!
Old 02-07-2022, 10:24 AM   #397
57FleetsideC4
Re: My 56 build
Looks very nice!! Steve
Old 02-07-2022, 01:25 PM   #398
daveshilling
daveshilling's Avatar
Re: My 56 build
Burnt pine is very stripey... if you want that look, then pine is definitely the right choice! If you want a consistent dark tone, a hardwood will burn more evenly. It's a good choice though, naturally weather-resistant!
daveshilling is offline   Reply With Quote
Old 02-08-2022, 03:46 PM   #399
Jason 56
Re: My 56 build
Thanks guys. I put the first coat of clear on the bottom and didn’t like how much blond wood was still showing. So I applied a second coat of stain. Now it may be too dark. Some days I see it and I like it, then the next day its too dark. I may now understand how my wife looks at clothes I put the second coat on the back today. In the end it should look good no matter how fussy I get!
Old 02-08-2022, 03:58 PM   #400
6DoF
6DoF's Avatar
Re: My 56 build
this one takes a lot of will power ... i re-did a bathroom and got the drywall JUST right, only to have the wife gouge it in a few spots while painting. drove me up the wall! but no one ever noticed with the room finished, even i stopped noticing after a few weeks, and it simply didn't matter. since then i really try to step back on some things and think "will anyone but me (and my buddies who nitpick everything just to give me sh!t) notice?"
