Old 07-22-2010, 09:27 PM   #401
jlaird
jlaird's Avatar
Re: Project: Bad Bagged '68.5
Originally Posted by porterbuilt View Post
Awesome work as always!!!!! Love the attention to detail.
Either the truck is really low... or you are really tall!
Both, the frame sits 1" off the ground and I am 6'1"
Thanks everybody for the positive feedback!
josh
jlaird is offline   Reply With Quote
Old 07-23-2010, 12:18 AM   #402
greystoke
Hey J...you had asked for info on cutting the door frame. I asked and it was actually done by glock and here's the thread with some pictures. As you can see I was mistaken on where the cut was made.
http://67-72chevytrucks.com/vboard/s...d.php?t=413073
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 07-23-2010, 09:54 AM   #403
jlaird
jlaird's Avatar
Thank you SO much! I love this board!
Old 07-23-2010, 10:06 AM   #404
SCOTTMO
powdercoater
Nice job..
SCOTT
SCOTTMO is offline   Reply With Quote
Old 07-24-2010, 12:44 AM   #405
5windowpickup
5windowpickup's Avatar
Truck is looking good! Great attention to detail! Looks like you may need to drop that seat down a foot or two to be comfortable in there! Keep up the great work !
Josh Hart
High Octane Hotrods
71 C10 Bagged work in progress driver
Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912
5windowpickup is offline   Reply With Quote
Old 08-03-2010, 11:45 AM   #406
yfz450_0569
Subscribed! love that build!
yfz450_0569 is offline   Reply With Quote
Old 08-05-2010, 11:41 AM   #407
POPO1984
POPO1984's Avatar
nice work.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 08-09-2010, 02:07 PM   #408
kcjones
I wish I was a cowboy
kcjones's Avatar
Just read the whole thread - at every point of this build your attention to detail and craftsmanship is not just noticeable, but outstanding. I've read a few "I'm gonna steal that idea!"....I think I'm gonna steal all your ideas!
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 08-19-2010, 03:00 PM   #409
kyull67
kyull67's Avatar
Any updates? Your frame turned out awesome!
kyull67 is offline   Reply With Quote
Old 08-19-2010, 06:57 PM   #410
jlaird
jlaird's Avatar
Not really. I'm just fighting a door alignment battle right now.
Old 08-21-2010, 12:36 AM   #411
CheyenneShop
CheyenneShop's Avatar
I take it the door is winning
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 10-06-2010, 04:45 PM   #412
McClinton527
McClinton527's Avatar
very awesome build.. Just when I thought I did a really clean job with my airline and brake line I saw this thread and my mind is blown! so so so awesome.. and the door trimming tip is outstanding. my driver door is so tight in the upper corner it makes me sick to think i ignored it, now ive got chipped paint there ha ha. maybe time for a little revision and spotting in my upper door frames!
McClinton527 is offline   Reply With Quote
Old 10-08-2010, 03:14 AM   #413
c10layinlow
sweet build bro, i like your rear set up, is the truck layin frame in the rear with that set up? is this your 4 link your running http://www.*****************/4-link-k...gulated-4-link ... also where did u get get the 4 link mounts on your axle? keep up the good work man lookin sweet!!!
c10layinlow is offline   Reply With Quote
Old 10-08-2010, 03:48 PM   #414
jlaird
jlaird's Avatar
Yup, got the 4 link from Suicide Doors. The axle tabs I designed. I made an extra set if you are interested. They are CNC cut from .25" steel.
Old 10-08-2010, 03:57 PM   #415
jlaird
jlaird's Avatar
Dude, I LOVE your truck. I posted in your thread too...we have VERY similar tastes. As of right now, the plan is for cream steelies with spyder caps, Cream roof, green body(more of a stock color like forum member tcb-1 which is 504 Yellow Green Poly) and lower trim. I can't wait.
The passenger door is finished. I will post pics later today.
Old 10-08-2010, 11:23 PM   #416
jlaird
jlaird's Avatar
Got the drivers side door finished. The curved part of the window frame was just about hitting the cab, so some reconstructive surgery happened. I had two pairs of doors; the doors that were original to the cab which were rusted to hell on the bottom, and a second pair I bought that were rust free. So what I did was took the window frame out of the original doors (kind of as practice to make sure I could get the window frame out) and put the window frame in the good shells. I also cut the frame at the upper left hand corner to fix the door gap in that area. Then I positioned the window frame in the door shell where I wanted it and spot welded it back in. Here is a before and after:
BEFORE
AFTER
This is what it looks like after you get it out
Here is the frame out and where I cut and welded it
Here is how the other door gaps came out. Not too shabby for a first timer! Remember, I replaced the entire floor, both lower pillars, cab corner, and the rocker. I'm pretty happy with the results.
The right end of the rocker was sliced and new metal put in to align with the door.
You've probably seen this before, but here is a way to be able to hold a small filler piece of meta,l that you cant get behind, for welding.
Last one of the day: Here is how to bolt a door on all by yourself. I had a piece of left over steel that was in the shape of a "c". One lip was small enough to tuck under the door so I could bolt a strap to it and lift the door with a hoist.
Old 10-08-2010, 11:28 PM   #417
greystoke
That's a cool trick...maybe a picture of what the steel piece looks like. It looks like it really helped to get them on with good gaps.
Old 10-08-2010, 11:53 PM   #418
VA72C10
VA72C10
VA72C10's Avatar
Very nice work! Those gaps look great!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-09-2010, 09:58 AM   #419
LEEVON
LEEVON's Avatar
Yes, you should be very proud, nice work. The gaps look great.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 10-09-2010, 12:48 PM   #420
kvn1011
Kvn1011
kvn1011's Avatar
I know this has already been brought up, but .............the gaps look great lol ...awesome build!
kvn1011 is offline   Reply With Quote
Old 10-09-2010, 02:18 PM   #421
jwalk
What was I thinking?
jwalk's Avatar
Dude that turned out great! Your whole truck is looking awesome!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 11-06-2010, 05:44 PM   #422
chapster
chapster's Avatar
Any updates?
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 12-29-2010, 02:43 AM   #423
kvn1011
Kvn1011
kvn1011's Avatar
Originally Posted by chapster View Post
Any updates?
ditto!
Old 12-29-2010, 12:28 PM   #424
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Outstanding job man, can't wait to see the final product.
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
Old 01-31-2011, 10:13 AM   #425
garagemonster
Lookin good
garagemonster is offline   Reply With Quote
