07-22-2010, 11:16 AM | #1 |
cutting door glass frame
Hey guys,
A member on this forum cut his door frame towards where the angle is in order to get a little more clearance where the curve of the frame meets the cab. Could you if you read this please post what you did again. Much appreciated!!
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
07-22-2010, 07:14 PM | #2 |
Re: cutting door glass frame
Ttt
07-22-2010, 07:29 PM | #3 |
I had the same problem and my body-man friend told me about using hydraulics to move the top corner. I got an idea and put a board vertically outside of the window frame and gave it one good whack forward with a mini-sledge. Moved it just right.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
07-22-2010, 08:05 PM | #4 |
Next project: 1970 K10
Was it me? I cut mine on the upper rear curve of my 68. If so, I'll post up some pics after dinner.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-22-2010, 08:12 PM | #5 |
I ate fast.
Tested the process on the other side before I did it in the new doors:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-22-2010 at 08:12 PM. |
07-22-2010, 09:49 PM | #6 |
The Few, The Proud
Bob,
How much material did you take out when you made the cut? I ask because I run into the same problem on my repop door that I recently mocked up. The gaps and body lines are perfect. I'm just having issues with the window frame. I even drilled out the spot welds on the frame and tapped the frame down lower into the door, but it didn't help alot.
Shannon |
07-23-2010, 12:22 AM | #7 |
yes it was you Glock...I thought it was Kevin. Thanks for replying and showing us what you did. Seems like an excellent way to fix this common problem. Sdailey, 1/8" is the information you seek
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 Last edited by greystoke; 07-23-2010 at 12:34 AM. |
07-23-2010, 06:56 AM | #8 |
Thanks greystoke! Gotta love these boards! Man, that looks like the perfect solution to this problem. I was at a big car show this past weekend and almost every truck was the same way...tight in that curved corner. I will probably try this and post pictures. Thanks again.
07-23-2010, 08:35 AM | #9 |
The Few, The Proud
Thank you Sir.
Shannon |
07-23-2010, 10:01 AM | #10 |
your more than welcome guys and I love the little finish you put on the hood hinges jlaird, I'm going to copy that on my truck.
07-23-2010, 10:18 AM | #11 |
Yup, it was about 1/8", about the width of a well worn Sharpie tip! As little material as it was, it made a HUGE difference!! And with such little material removed, at has zero effect on how the window operates or sits in the rubber.
Shannon (and jlaird) - Yours looks exactly how mine did when I first hung them. As for where to cut, I just eyeballed a spot right in the middle of the curve from where the gap started to open up on each end, and made the cut there. Cleaned up the cuts and prepped for welding, then used a variety of vice grips and slide clamps to hold things in place while I tacked it, then pulled them off to weld. I used a cutoff wheel to clean up the welds in the corners where a flapper wheel couldn't get.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-23-2010 at 10:19 AM. |
07-23-2010, 02:13 PM | #12 |
The Few, The Proud
Thanks Bob. The pictures are great. I guess I'll be cutting my doors then.
Just another example of how great this board and its members are.
Shannon |
