Old 10-23-2011, 11:37 AM   #401
Rods57
Rods57's Avatar
Re: My 57 Pro Street
"took a chance" dude your like macgyver doing fab work. That bed is one of my favorite parts of this forum. I cant wait to see what you come up with "using only a coat hanger, a scrap piece of 3/4 and an emergency brake cable, he creates an exhaust cut out" Seriously you have skills and its awesome how you make it work.
Rods57 is offline   Reply With Quote
Old 10-24-2011, 12:50 AM   #402
Daze57
Daze57's Avatar
excellent work again -always a pleasure to see great skills and workmanship .
Daze57 is offline   Reply With Quote
Old 10-24-2011, 08:42 AM   #403
Kim57
Kim57's Avatar
Thanks guys, I do appreciate the kind words.
I also get tons of inspiration from the other guys on this site.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-27-2011, 10:28 PM   #404
Fat Mike
Fat Mike's Avatar
Originally Posted by Kim57 View Post
I wanted to tilt the bed to make it easier to remove the tires so I fabbed up some brackets and a frame for it.
The picture of the rear portion of the frame where you narrowed it did you reinforce the inside of the frame before you boxed it in? Also how did you attach the two frames together? Later in the picture of your frame you also triangulated the frames together with gussets. Did this add alot of strength to the frame?
Fat Mike is offline   Reply With Quote
Old 10-27-2011, 10:33 PM   #405
Fat Mike
Fat Mike's Avatar
This is your frame that I am talking about & here is mines which I need some advice on.
Old 10-27-2011, 11:23 PM   #406
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: My 57 Pro Street
Mine are kinda a pain taking them off and on. Then I have to torque those Welds to spec.
Forgot you were talking about the tilt/dump bed. I changed my mind on that idea.
Money and more cutting, welding & fabricating
I'm going to have a small fortune tied up in the bed as it is.
I can't remember.... were you gonna add a fuel cell in the back like mine?
If so filling up with gas want be to bad with the tilt. How far back are you gonna set it back? The tilt that is.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 10-28-2011, 12:26 AM   #407
Kim57
Kim57's Avatar
Originally Posted by Fat Mike View Post
Attachment 820350
Attachment 820351
Fat Mike
Here's a pic of the inside where my frame is attached to the narrowed section.
The left portion with the wood on it is the original frame. I wish I could tell you how it was done but I had a guy with a lot more experience than I had at the time do it. I did add some gussets but they were more for looks than anything else.
Hope this helps.
Kim
My build thread
Old 10-28-2011, 12:32 AM   #408
Kim57
Kim57's Avatar
1Bad62
I am going to run a fuel cell on the rear of the frame. It should sit on top of the lower section of the frame. I took some measurements and I should be able to run a 16 to 20 gallon tank.
Here's a pic of where the tilt will pivot with the bed attached. The hole in the frame is where it pivots. It's pretty far back.
Kim
My build thread
Old 10-28-2011, 08:43 AM   #409
1Bad62Pro/Street
Thumbs up Re: My 57 Pro Street
1Bad62
Kim
Ok.
Sounds good.
Yep that's what i am using 20gallon.
Very good fab work. Alot of guys don't realize the cost in material during fabrication. Especially welding.
http://www.nwsco.com/
Can't wait to see it done. She's gonna be One Bad Mamma Jamma!
Old 10-31-2011, 02:51 PM   #410
Kim57
Kim57's Avatar
A little more progress on the truck.
I had to mount my front bumper. These first few pics show how they came from the factory. I think it sticks out a little to far so I'm going to change that.
My build thread
Old 10-31-2011, 02:56 PM   #411
Kim57
Kim57's Avatar
So on with the changes.
I had to make some new brackets so I made some templates out of cardboard.
transferred the design to some 3/16 plate and went to work with my angle grinder.
After a little refinement this is what we get.
My build thread
Old 10-31-2011, 03:00 PM   #412
Kim57
Kim57's Avatar
Drill a few holes and test fit them to the frame. On a side note I did have to modify my frame horns again.
A little welding and we're almost there.
My build thread
Old 10-31-2011, 03:07 PM   #413
Kim57
Kim57's Avatar
And this is what you get.
The first pic is the original.
The next pics are what you get when you flip the bumper.
Please excuse the jack. As soon as my tires hit the ground I can't get it out (this will be corrected).
It draws it into the truck and IMHO looks better for what I'm doing.
I will be shortening the ends so they don't intrude on the wheel openings.
Kim
My build thread
Old 10-31-2011, 04:26 PM   #414
oldman3
oldman3's Avatar
B**chin, looks great....Jim. Is the F**d yours to, or a job????
oldman3 is offline   Reply With Quote
Old 10-31-2011, 04:54 PM   #415
Kim57
Kim57's Avatar
Thanks Jim.
The F**d is my brothers. He doesn't have enough room at his place so the body is here while we get the frame together at his place.
Kim
My build thread
Old 10-31-2011, 05:03 PM   #416
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking good Kim
Kabwe is offline   Reply With Quote
Old 10-31-2011, 06:27 PM   #417
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Nice job Kim, are you doing some mod to you head bucket also?
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 10-31-2011, 06:55 PM   #418
OrrieG
OrrieG's Avatar
Are you going to narrow or profile the bumper at the ends to keep the same gap as it turns the corner?
OrrieG is offline   Reply With Quote
Old 10-31-2011, 07:10 PM   #419
Kim57
Kim57's Avatar
Originally Posted by Kabwe View Post
Looking good Kim
Thanks Bam, now get busy on yours.
Tri5
Thanks.
I am changing the headlight buckets. I filled in the area that gets covered by the original bezel under the eyebrow. I just haven't found what I'm going to use yet.
Yes OrrieG I'm going to narrow the bumper some. I still have to figure how much.
Kim
My build thread
Old 10-31-2011, 07:57 PM   #420
pbeguy
pbeguy's Avatar
Love the " jackstands " that are holding your bumper.
pbeguy is offline   Reply With Quote
Old 10-31-2011, 08:35 PM   #421
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice work, it does look much better closer to the body!
ChuckDriver is offline   Reply With Quote
Old 11-01-2011, 12:37 AM   #422
Kim57
Kim57's Avatar
I have to use whats available and they were nice and wide.
I set the front tires in them when I was doing my hood and needed extra room to crawl under and get up in the engine compartment.
thanks.
Kim
My build thread
Old 11-27-2011, 02:07 AM   #423
Green 1959
Green 1959's Avatar
Nice going! I'm going make brackets for my bumper that weld on just to clean up the bumper, I will probably leave it the original way. If I ever get to my bumper.. Thanks for the idea
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 12-08-2011, 12:24 AM   #424
beanyard
Smile Re: My 57 Pro Street
So I have been looking at your build thread and you have mad fabrication skills...
beanyard is offline   Reply With Quote
Old 12-08-2011, 01:19 AM   #425
Kim57
Kim57's Avatar
Thanks.
Kim
My build thread
