Old 12-31-2009, 04:21 PM   #401
watahyahknow
watahyahknow's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
awesome build it was a verry nice rustfree car ti start with that shouldve helped a lot
think the sunbeam brand is derived from simca and talbot might be some renault in there too not sure
this car looks an awfull lot like a volvo amazone
come to think of it in india the cars are still used as taxies:
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-03-2010, 05:43 PM   #402
Frizzle Fry
Frizzle Fry's Avatar
wow they are very similar. Here's a side-by-side:
Sunbeam was a brand under the Rootes Group, which also held the Singer, Humber, Matra, Simca, and Hillman marque. Rootes Group was later purchased by Chrysler. Here are some links:
http://en.wikipedia.org/wiki/Rootes_Group
http://www.team.net/www/rootes/
http://www.rootes-chrysler.co.uk/
I'm just back from two weeks in Ukraine. What an experience! Saw some interesting rides there too. Can't wait to get back on this. Should be out there by Thursday (gotta work first).
Frizzle Fry is offline   Reply With Quote
Old 01-03-2010, 06:44 PM   #403
watahyahknow
they do sheetmetal too
when youre on google look up bangla bangers and leepu its an english discovery series bout an indian chip foose who makes sportcars out of regular datsuns and nissans
Old 01-04-2010, 12:26 PM   #404
Lippyp
English Chevy Owner
Lippyp's Avatar
The big Indian Taxi is a Hindustan Ambassador. They're basically an old Morris Oxford III/IVwith IIRC an Isuzu diesel engine under the hood.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 01-10-2010, 01:57 AM   #405
Frizzle Fry
Took a little break from metal manipulation this week to play with an idea I've been brewing - gotta just roll with the ADD inspired motivation sometimes...
I converted my OG speedo from manual to electronic.
Took it apart and added the needle actuator from the Acura RSX-S cluster (extra actuator shown at bottom of 1st image):
Surface mounted a jack on the RSX cluster PCB to enable remoting of the actuator:
I found a nylon nut for that upper stand-off after this shot was taken:
Old 01-10-2010, 02:01 AM   #406
Frizzle Fry
...and the end-result:
Now the real question: Does it work? I'll find out after a lot more wiring work is done...
and thanks again to my awesome helper
Old 01-10-2010, 02:42 AM   #407
sleepertruck72
sleepertruck72's Avatar
I hope it works for you Nice work !
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 01-10-2010, 02:54 AM   #408
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Wow! U aren't afraid to jump into anything and everything are you? That car is cool and that motor/trans. swap is gonna be sweet. Keep at it and good luck.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 01-10-2010, 04:51 AM   #409
Frizzle Fry
Thanks gents By the way if my math is right, the indicated speed will be almost exactly 50% of actual with this setup. So I'll have to get the face reprinted to 180 MPH (not that I expect/want it to reach that ) I'll also have some adjustment available via the AEM EMS.
Old 01-10-2010, 05:54 AM   #410
watahyahknow
i allways wondered why people DIDNT do that , 9 out of 10 times the gauges bolt up to the facia without adapting
its useful when you put another cluster in the truck like an impala dash
Old 01-12-2010, 03:30 AM   #411
Frizzle Fry
More gauge work:
With only three holes in the cluster I had limited options for adding a tach. I also HAD to have speedo, fuel level, H2O temp, and oil pressure. Five gauges in three holes means multi-gauges or cutting additional holes (no).
Since the OG cluster came with a multi, but only used one of three slots I went with that style. It had oil, water, and amps. I needed oil, water, and fuel and happend to get lucky enough to find one on ebay from a MG, Morris, Austin, AC...
The only visible difference from the Sunbeam/Hillman style was the center "button" and needle color. That was easily fixed:
This looks much worse than it is because of the flash.
Now the center cluster hole is freed up for a 52mm tach
Here's what's on the way for that. I'll try to use the Minx bezel and needle. Maybe re-silkscreen too:
Old 01-12-2010, 03:44 AM   #412
Sub-versive
Boss Hogg
Sub-versive's Avatar
Very nice!
Sub-versive is offline   Reply With Quote
Old 01-12-2010, 09:58 AM   #413
hgs_notes
GEARHEAD
hgs_notes's Avatar
I'm sure glad I found this board and then found build threads like yours and LFD's and many others that always have some cool detail or mod that I wouldn't have thought of on my own.
hgs_notes is offline   Reply With Quote
Old 01-13-2010, 02:29 AM   #414
Britain Smith
Nice work man...
-Britain
Britain Smith is offline   Reply With Quote
Old 01-13-2010, 09:57 PM   #415
dammitmitchell
the pollock
dammitmitchell's Avatar
just another annotation....
show off..
hahahhaa
damnned good work brother
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 01-13-2010, 10:29 PM   #416
Frizzle Fry
Thanks guys. Just been doing some odds and ends. Made an EGR block-off plate last night. Haven't been motivated to grind for 2hrs which is what I need to do next on the driver's side frame mod. Probably get to that this weekend.
Old 01-16-2010, 04:43 PM   #417
Mil-Spec
Mil-Spec's Avatar
FF you definately got "Mad Skeelz"
Questions about your guage setup:
Are you going to use any other functions of the later model instrument cluster PCB?
Also that PCB was originally mounted in an enclosure with in the dash, how do you plan to mount it in the Minx's dash and you plan to conformally coat it?
And lastly, is the RS-232 connector isolated from the PCB? I see you're using nylon washers on one side but on the other the connector's metal case looks asthough it's sitting directly on the PCB, straddling 2 copper planes as well as several smaller traces. The reason I mention this is that vibration could cause the connector's conductive case to scratch through the solder mask and ultimately causing a short.
Potentially causing you problems and headaches.
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Mil-Spec is offline   Reply With Quote
Old 01-17-2010, 01:17 AM   #418
Frizzle Fry
Hey there Mil-spec. First, Thanks Second, why would anyone switch from Air Force to Navy???
Other functions of the PCB. Yes, I plan to build a board to remote mount many of the indicator LEDs and LCD.
I will mount the PCB high under/behind the dash inside the plastic enclosure. It has fairly flat front/back covers. The front cover includes the Acura gauge faces that no one will see.
The 9-pin DSUB connector (often used for RS-232) mounted to the board is not the one shown in the vice with soldered wires (that's the gauge side). The one on the board has crimped/inserted pins and a plastic section/pin-housing protruding from the back side, which is what comes close to touching the PCB but is actually held off the board by the stand-offs.
I'll get some close-up shots of that for ya.
Old 01-17-2010, 04:26 AM   #419
Frizzle Fry
Here you go Mil-spec. What do you think?
Got the 52mm tach and stuffed it in the hole just to see how it looked (tilted back in the hole, not secured):
Looked pretty sweet IMO, but the non-matching bezel and curved glass would bug the crap outa me so...
It took a lot to get that bezel on there, but it was worth it. There is no lense in the pics. I need to have one cut because the fuel gauge lense was too small. I still need to mod the needle to resemble the others and get rid of the dolphin logo.
Old 01-17-2010, 04:33 AM   #420
Frizzle Fry
Also got some grinding done.
Before:
After:
...and the most fun area (still need to add the filler strip and grind/smooth the back half)
Old 01-17-2010, 05:01 AM   #421
Twisted Minis
Twisted Minis's Avatar
Looking awesome.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 01-17-2010, 09:35 AM   #422
hgs_notes
GEARHEAD
hgs_notes's Avatar
There is an article in this months hot rod about the sunbeam tiger. I found an older article on their web site, but not the current one. Imagine, you could have had a V8!
http://www.hotrod.com/featuredvehicl...ger/index.html
Old 01-17-2010, 02:48 PM   #423
Frizzle Fry
Yes, I could have had a V8 ...for far less money too. But then it would just be yet another V8 swap. Believe it or not this little Honda 4-banger, which is basically 1/2 of their formula one V8, makes more power than the Tiger's Ford V8. The tiger's power plant made 164HP and later 200HP. The F20C makes 240HP in factory trim. Yes, low end grunt is lacking compared to the V8 but in a light car with proper gearing the lighter, higher rev'ing F20C will be nuthin but grins in a straight line as well as in the twisties.
Old 01-17-2010, 04:08 PM   #424
watahyahknow
dont forget the boatanker weight that you now dont have over the front wheels this little car will actually go around a corner
Old 01-17-2010, 05:06 PM   #425
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
This is just wrong in so many diffrent ways
you have some amazing fab skills wish i had these skills
this is a very very cool project you have have
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
