Old 03-06-2011, 02:07 PM   #401
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by Zoomin View Post
Did you catch anything today, Mike?
It was windy and kinda cold today, hope it was worthwhile for ya.
You might want to start making multiples of this stuff to support your hobby.
We caught a few, the wind kicked our tails. Finished down at the bottom of the pack. Nice idea, barely have time to do mine though. I still need a mailing address from you.......
Originally Posted by my67chevytruck View Post
nicely done Mike!... when we going fishing....
Thanks, lets go.
Originally Posted by usmcchevy View Post
As always, awesome work!
Thanks.
mcbassin is offline   Reply With Quote
Old 04-01-2011, 04:34 PM   #402
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Time for a mild update. Progress has been pretty slow. Things get pretty slow this time of year with fishing and golf seasons taking over most our free time. I have worked on it a little though. I got the rear end all cleaned up primered and painted, then installed new seals all around. I blasted the outer brake mount plates, primered and painted them too. Then reassembled the third member and installed the axles. Got one side of the brakes assembled. Then found out I only ordered the right hand side of the brake hardware. I'll probably just clean up the old hardware and re-use most of it. I also picked up a 4l60E on Craigslist the other day, supposed to only have 70k miles on it? It looks pretty greasy. We'll see when I pull the pan. Here are the pics:
Old 04-04-2011, 10:45 AM   #403
JohnC
JohnC's Avatar
Re: 1969 Short Wide
Sweet!
JohnC is offline   Reply With Quote
Old 04-04-2011, 11:18 AM   #404
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Dunno man a leaky valve cover and make anything look nasty in only a couple thousand miles so lets hope that it is good in there when you drop the pan
Scott
93 crew cab build
Project 62
Old 04-04-2011, 11:59 PM   #405
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by JohnC View Post
Sweet!
Thanks.
Yep, I have high hopes. We'll see. It won't break the bank as a core if it needs rebuilt anyway. You know how cheap I am.
Old 04-05-2011, 08:44 AM   #406
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 1969 Short Wide
Trans looks about right to me, my 30K engine/trans was just about that bad.........yet my 00 Silverado was perfectly clean with 130K and I only sprayed it off twice.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-06-2011, 06:42 AM   #407
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 1969 Short Wide
Nice progress!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-19-2011, 11:21 PM   #408
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Hope your right. I really need that thing to work out without a rebuild.
Originally Posted by 72BlckButy View Post
Nice progress!
Thanks Nate!
Old 04-20-2011, 09:24 AM   #409
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Time for another small update. I have just about finished the rear suspension modifications. Got the brakes installed, got the front sway bar installed.
I picked up an adjustable panhard bar from Tom (T Korinek) HERE. Then I lengthened it 12.5".......which turned out to be around 4" too long after my mock up at ride height (measure once cut twice).
I used some pics from Keith (lolife99) of his pandhard relocation mount to design my own. I have it painted and ready for final install. Next step is new shocks for the rear and brake lines, then gas tank and lines. Can't wait to get to the LS install after that. It will be downhill from there. Here are the pics:
Bar sectioned
Made a 12.5" lenthener (4" too long shoud be 8.5")
Bar Welded the second time
Mock up to decide where to weld the mounting tabs
Pieces for the mount (decided not to use the gusset, upper middle)
assembled before welding
Welded
Fit on the chassis
Old 04-20-2011, 09:25 AM   #410
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
More pictures:
Planning for sway bar mounting (had to remove rivet on the cross member)
Sway bar installed, not a big fan of the blue bushings, that's what Rock Auto sent me.
Old 04-20-2011, 09:52 AM   #411
dougminton
dougminton's Avatar
Re: 1969 Short Wide
Nice work on the panhard mount.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 04-20-2011, 11:37 AM   #412
68 TT
Still plays with trucks
68 TT's Avatar
Re: 1969 Short Wide
Nice progress Mike. Wish I was making some but it won't quit snowing.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-20-2011, 11:49 AM   #413
bjcaldwe
bjcaldwe's Avatar
Re: 1969 Short Wide
Looks good Mike.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 04-20-2011, 12:28 PM   #414
67cheby
67cheby
67cheby's Avatar
Re: 1969 Short Wide
very clean...nicely done
67cheby is offline   Reply With Quote
Old 04-20-2011, 02:45 PM   #415
JohnC
JohnC's Avatar
Re: 1969 Short Wide
Nice!
Old 04-20-2011, 04:26 PM   #416
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Doug!
Thanks, Snow? wow it's been consistantly over 60 here.
Originally Posted by bjcaldwe View Post
Looks good Mike.
Thanks Billy
Thanks Cheby!
Nice!
Thanks John!
More to come soon......hopefully.
Old 04-20-2011, 05:04 PM   #417
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1969 Short Wide
Very nice fab and welding work on that pan hard bar! Keep up the great work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-20-2011, 06:56 PM   #418
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: 1969 Short Wide
looks good im ready to see this one in person
screaminchevypickup is offline   Reply With Quote
Old 04-20-2011, 07:23 PM   #419
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Ryan!
Thanks Kyle!
It's not much to look at right now compared to yours but, sure when your in my neighborhood stop by. I have a pretty good salvage out back if you need some parts too.
Old 04-20-2011, 10:25 PM   #420
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 1969 Short Wide
Nice work! I like the little details you include...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-21-2011, 12:26 AM   #421
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks man. I hope those little details will help make it easier for someone take on part of the fabrication on their own. There is a wealth of knowledge on this forum. Most of my build is just someone elses ideas that I tweaked to make it work on the cheap.
Old 04-21-2011, 12:38 AM   #422
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Got a roller now...kinda. Still need to buy rear drums and shocks.
Finished the rear setup after painting the bar and mount.
finished the suspension (except shocks)
Installed the painted parts
Back on the ground2
Old 04-21-2011, 12:47 PM   #423
gopokes
gopokes's Avatar
Re: 1969 Short Wide
Looking good! I like the panahard bar.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 04-21-2011, 02:07 PM   #424
chevy88
chevy88's Avatar
Re: 1969 Short Wide
Nice roller, I don't care what they say about you, you do have other talents than just fishing. LOL.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 04-21-2011, 07:52 PM   #425
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Wow looking good Mike!
Scott
93 crew cab build
Project 62
