Old 11-17-2012, 06:49 PM   #401
legendman
legendman's Avatar
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Nice progress, gonna be a bad ass ride when its done
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 11-17-2012, 10:18 PM   #402
Mattman2010
Mattman2010's Avatar
Thanks man!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 11-20-2012, 12:01 PM   #403
Mattman2010
Well I started getting some ideas for what I wanted to do for mounts. First I started out by cutting out some plates.
Here they are kind of bolted to the block.
After that I decided to make some templates to see what I could come up with for the block. Ive decided I am going to try to put the mounts at a 45 deg angle
As you can see I used a piece of wood to act as the cross member. I am thinking about welding a kind of bracket to the cross member to meet up with the mount for some extra oil pan clearence but I am trying to mount the motor pretty low so I will have to get the block in the frame and see how things fit.
Build Thread
Build Thread
Thread
Old 11-20-2012, 03:51 PM   #404
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I hate to burst your progress bubble, but you're really going to want the engine in the truck to do the mounts.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-20-2012, 04:21 PM   #405
Mattman2010
I know. I was getting an idea for them. I figure if I kind of have a plan now then I can modify what I figured out for now. Plus I'm waiting on some parts to show up....
Build Thread
Build Thread
Thread
Old 11-21-2012, 03:46 AM   #406
Dieselwrencher
Planning on these just leads to frustration. Haha
Ryan
Old 11-21-2012, 11:40 AM   #407
Mattman2010
I seem to work better with a plan. Now wheres my parts?
Build Thread
Build Thread
Thread
Old 11-22-2012, 01:01 PM   #408
Mattman2010
So I am still waiting on some parts before I can start mocking up the motor so I decided to mess with some stuff on the motor.
The first thing I wanted to get figured out was the throttle cable. Ive seen people use a dodge throttle cable, but this motor is set up a lot different than a dodge one so the throttle cable would not have worked. I had a extra chevy cable laying around so I decided to try to make that work. So I made this little bracket.
And here it is installed.
The cable does not look straight, but it becomes straight once you start to pull on the cable. Just plugging away a the little things till I can finally start to mount the motor and transmission.
Build Thread
Build Thread
Thread
Old 12-11-2012, 11:49 AM   #409
Mattman2010
Well I finally got the correct 12v adapter plate and also got a bell housing for the transmission.
Adapter Plate
Everything mounted to the transmission
Next step is to start mounting it up. Everything will get painted later, but its starting to get cold and I cant heat my shop so painting is going to have to wait. Once I get the motor mounted I am going to pull the cab and make the transmission cross member and then start working on all the small stuff I need to do to get this thing running. I have to run all new brake lines, fuel lines, and install a 40 gallon burb tank in the back.
Build Thread
Build Thread
Thread
Old 12-12-2012, 08:27 PM   #410
Mattman2010
Tonight I went ahead and set the motor in so that I can start fabbing up mounts. I have the motor setting on 4 jack stands and still have my chain hoist holding up on it some but it looks to be right where I need it.
Underneath
Front to rear angle (5*)
Side to side
Planning on trying to get the transmission and transfercase bolted up behind it this weekend and then start making the mounts. Not sure how I am going to do this just yet as I dont have a transmission jack, but I have used my shop crane to put my sm465 and np205 in this truck before so I may try that again.
Build Thread
Build Thread
Thread
Old 12-12-2012, 08:42 PM   #411
y5mgisi
Second Chance Program
y5mgisi's Avatar
Awesome! Cant wait to see how your mounts work out!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 12-13-2012, 01:43 AM   #412
Mattman2010
Thanks man, me too!
Build Thread
Build Thread
Thread
Old 12-13-2012, 01:05 PM   #413
Mattman2010
Got up this morning and decided to get the transmission and transfercase in. It actually went in pretty easy using my shop crane.
Going to start making mounts for the drivetrain soon. Looks like everything is in a good place and im happy with it.
Build Thread
Build Thread
Thread
Old 12-20-2012, 01:52 AM   #414
Mattman2010
Well started making the mounts, my first plan was not going to work so I have started a new idea. So far so good.
Passenger side
Start of the drivers side
There will be a lot of gussets added so it will be strong. Hoping to get these finished and then make a removable cross member soon.
Build Thread
Build Thread
Thread
Old 12-22-2012, 01:39 AM   #415
Mattman2010
Got the mounts made today. Went a little different than what I was starting out with. Took 2x4x1/4 tubing and cut the top part off and made my mounts.
Passenger side
Passenger side mounted
Drivers side
Drivers side mounted
I will be putting gussets on the bottom as well for added strength. Next thing to do is make the transmission cross member then I will pull the drive train out and fully weld all of the mounts then I'm going to drop the drive train back in and figure out something for an engine cross member.
Build Thread
Build Thread
Thread
Old 12-24-2012, 10:08 AM   #416
justpball
justpball's Avatar
Nice work bro! Can't wait to see it all together...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 12-24-2012, 04:54 PM   #417
Dieselwrencher
Looking good man. Where's the 2nd turbo going?
Ryan
Old 12-24-2012, 06:40 PM   #418
Mattman2010
Thanks man! I can't wait to drive it!
Not sure yet. I'll have to ask my engine builder what all I need to do to make twins work good first. Maybe see of he has a turbo that would work good with my current turbo.
Build Thread
Build Thread
Thread
Old 12-24-2012, 06:59 PM   #419
ryanroo
ryanroo's Avatar
i better watch this one too! lookin good. 6b swaps are always fun to watch
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-24-2012, 07:28 PM   #420
Mattman2010
Thanks man!
Build Thread
Build Thread
Thread
Old 01-01-2013, 09:18 PM   #421
Mattman2010
Well I have finally gotten some stuff done to the truck this past week. First I had to make a mount that went from the transmission to the transmission mount and then i made the cross piece for the cross member.
I then needed to connect the cross member to the frame so I made these 1" slugs with 2 1/2 inch holes in them for the bolts.
And here is the whole thing tacked in.
The brackets on the frame will be gusseted so it should hold pretty well.
Build Thread
Build Thread
Thread
Old 01-02-2013, 11:53 AM   #422
Dieselwrencher
Looking good. Is your front drive shaft going to clear it?
Ryan
Old 01-02-2013, 01:44 PM   #423
Mattman2010
Oh yeah there is plenty of room
Build Thread
Build Thread
Thread
Old 01-03-2013, 10:53 PM   #424
Mattman2010
Got the drive train pulled and welded up the the mounts. Dropped the motor back in to make sure that the mounts would hold the weight.
Will be picking up a dana 60 front axle for the truck monday.
Build Thread
Build Thread
Thread
Old 01-08-2013, 04:02 PM   #425
Mattman2010
Well last night I was able to make my trip to pick up a dana 60.
D60. Gears are flawless all that needs fixed are the u-joints.
Good bye ball joints!
Hello kingpins!
Next I will be picking up a 8" lift kit and some 16.5 dually wheels!
Build Thread
Build Thread
Thread
