View Poll Results: If you had the option, which of these grills would you use?
Original 66 painted grill 1 20.00%
64-66 C60 painted grill 2 40.00%
an original aluminum grill that needs to be restored 2 40.00%
the repo aluminum grill that is now available 0 0%
Voters: 5. You may not vote on this poll
Old 03-25-2014, 09:40 PM   #401
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Well, I just got back from vacation. A week and a half in Akumal, Mexico getting some much needed sunshine. Drank a lot of Tequila, ate good food, and did a bunch of snorkeling. Now it's back to harsh reality of real life. Not much to update but tomorrow I start 3 days off and hope to get some stuff done. The water pump I bought was wrong so I sent it back and got another. I fitted up my driveshaft and I need to take it back and have the rear section shortened a little more, and I picked up a couple of fittings I needed to complete the brake plumbing so I hope to get that done, also. The weather is starting to warm up so I will be back on the body work again. Next is to get the cab flipped back upright and get the firewall patching done so I can get the cab back on the chassis and start fitting up the fenders, etc. So that's the plan for the next while.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is online now   Reply With Quote
Old 03-25-2014, 10:47 PM   #402
NEWFISHER
NEWFISHER's Avatar
Re: pdx-sanity66
Welcome back to the liquid sunshine of Oregon
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-26-2014, 01:13 AM   #403
siggyfreud
siggyfreud's Avatar
Re: pdx-sanity66
Indeed! I'm actually in Phoenix right now on business and am reluctant to return to the rain.
siggyfreud is offline   Reply With Quote
Old 03-26-2014, 11:33 AM   #404
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: pdx-sanity66
Welcome back to the Oregon rain! LOL! I'm jealous!!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-30-2014, 10:56 PM   #405
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks, man. The rain I didn't miss and we had a great time but it's nice to be back and working on the truck
I hope you had a great trip and got some of that sun.
Thanks, T.J.
Well, I did get some stuff done this last weekend but not as much as I had wanted. We have been looking for a new camper and we drove up to Kelso, WA to check one out on Friday and then came back and looked at the other one we had picked out. We had it narrowed down to just 2. We are planning of retiring in about 10 months and we want to travel around the US and other places and we want something that we can get in to places that you can't drag a trailer. I mentioned earlier that I had traded my Tundra in on a 2014 Silverado 3500HD 4x4 dually and the next step was the camper. Saturday we bought Lance 1170 2 slide out camper. We are now one step closer to our goal!
This also puts more pressure on me to get stuff done on Sanity during this next year.
I did manage to work on the serpentine system some more and it's starting to come together. I've got everything fit up except the power steering pump. I am rebuilding it first and I ordered a new reservoir for it. I am also going to replace the idler pulleys. I cleaned up the alternator and had it tested to make sure it was good before installation and I got a AC compressor dummy pulley and bracket to use. I cleaned up some casting marks and and got it painted. I got my replacement water pump and got it and the pulley mounted also. The front of the motor is almost complete.
Since the weather is starting to warm up some I also decided to get back to body work so I can get the cab flipped back up right and the set back on the frame soon after. There was one spot just above the dimmer switch and one spot under and around the Steering shaft hole that needed to be cut out and patched. I got them cut out and the patches fit up but ran out of time to drag out the welder so that will be next weekend.
I didn't have time to take some pics before going to work so I'll try to post a few tomorrow.
Sanity'66
Old 04-04-2014, 03:42 AM   #406
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I got the patches welded in today. You can see where there was a little bit of burn through on the top of the left patch and the right side of the right patch where I have also marked to cut out. The metal was still a little thin so I'll cut a couple more small patches to get to good metal. I also rust encapsulated the inner piece on the steering shaft opening after wire wheeling it and before welding in the patch. I also took a shot of the serpentine set up as it stands now. I'm heading to the swap meet in the morning with rain gear in tow.
Sanity'66
Old 04-04-2014, 11:21 AM   #407
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: pdx-sanity66
Nice work!
Old 04-06-2014, 07:43 PM   #408
Larry64
Re: pdx-sanity66
pdxhall
Great right-up. Getting ready to do my floor pans, inner & outer rockers, etc. Looking at the job you did I will need more patch panels.
Larry
Larry64 is offline   Reply With Quote
Old 04-07-2014, 06:33 PM   #409
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Originally Posted by Larry64 View Post
pdxhall
Larry
Thanks for looking in Larry. Good luck on the patching. It is a "learn as you go" for me. I've gotten a lot of good help and information from other guys builds.
I just got another shipment from Summit and thought I'd share. New idler and tensioner pulleys for the serpentine setup, power steering reservoir, and a Moog pitman arm. Now I can do my power steering setup and finish the serpentine system.
Sanity'66
Old 04-07-2014, 07:36 PM   #410
siggyfreud
siggyfreud's Avatar
Re: pdx-sanity66
Looking good! I've been receiving Summit boxes like mad for a few months now. Looks like the Portland area is giving Summit some healthy support.
Wish I could patch weld like you.
Old 04-07-2014, 11:07 PM   #411
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: pdx-sanity66
X2.
Old 04-08-2014, 11:09 PM   #412
McMurphy
McMurphy's Avatar
Re: pdx-sanity66
I am real interested in seeing how you tear down the PS pump you are rebuilding....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 04-09-2014, 10:11 AM   #413
1963c-10
1963c-10's Avatar
Re: pdx-sanity66
Nice work on the patches. The frame and engine look great...glad you got the mounts figured out.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-22-2014, 12:40 AM   #414
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks, siggy. I'm on a first name basis with the delivery guys right now.
X2.
Thanks, T.J.
I started the tear down last weekend and took a bunch of pics. There are some really good videos on Youtube that go through the steps. It's real easy.
Thanks, man.
Sanity'66
Old 04-22-2014, 12:45 AM   #415
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Here's the patch work I finished last weekend.Besides the area I shown in the last pics, I finished the edge patch and closed up the clutch hole. I'm pretty much ready to set the cab back upright and finish the firewall.
Sanity'66
Old 04-22-2014, 03:58 PM   #416
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: pdx-sanity66
Good work! Looks good!
Old 05-10-2014, 09:53 PM   #417
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
It's been awhile since I updated the thread but I've been getting some stuff done. First off I finished rebuilding my power steering pump. Here are a few pics of the tear down. There are some good videos on youtube of the process.
Sanity'66
Old 05-10-2014, 09:59 PM   #418
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Here's the assembly ready to put back together with new o-rings and seal. There is also a bushing available where the shaft goes through the housing but mine was in great shape so I chose not to replace it If you have any wobble in the shaft the bushing needs to be pressed out and the new one pressed back in. The rest is just putting it back together the way it came apart. The last pic is painted up all pretty along with the alternator pulley.
Sanity'66
Old 05-10-2014, 10:07 PM   #419
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I also got my driveshaft back from having it shortened and it's ready to go in, and I got my cab flipped back off of it's back and ready to start finishing up the firewall.
I also picked up a 67-72 rear Blazer/Custom bumper. My plan is for a painted rear bumper and this one is chrome so I will either see if I can trade it to someone for a painted one or scuff up and paint this one.
And finally, I also got my Lokar 23" Nostalgia shifter for the 700r4 and the "TV made easy" kit from Bowtie Overdrives.
More pics to follow.
Sanity'66
Old 05-11-2014, 07:54 AM   #420
bj383ss
bj383ss's Avatar
Re: pdx-sanity66
Im very interested in how your shifter works out I am planning to go the same route. I also like the Bowtie overdrive stuff for the 700r4. I plan on buying the cable setup and maybe the valve they sale as well.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 05-11-2014, 08:51 PM   #421
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Bret
I think the shifter is going to work out perfectly. I did some preliminary measuring and I think it will sit just in the right position I am looking for, very close to stock. And it has almost a foot of adjustment options front to rear. I have been very impressed with Bowtie Overdrives write ups and instructions on setting these transmissions up. The cable kit comes with the cable, the carb mount and gaskets, the TV brackets for the carb, and the replacement spring for the valve so it requires pulling the pan to install the spring. Which valve are you referring to?
Sanity'66
Old 05-11-2014, 11:24 PM   #422
CRGRS 66
CRGRS 66's Avatar
Re: pdx-sanity66
Great progress!!!!!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-22-2014, 07:16 PM   #423
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Okay, it's picture day. I haven't been keeping up too good lately but here are a few new additions.
First, This is the last picture I'll bother you with of the serpentine belt system. It's all finished now except putting on the belt A brand new one came with the system but it seems to be a little short. Maybe a little different with the AC delete pulley rather than the AC compressor. I haven't checked yet. Nest is a pic of the cab flipped back, doors hung just to get them out of the way. I've been shuffling them around the garage all winter. And finally, I picked up another tailgate and a 67-72 rear bumper. I've already got 2 tailgates, this makes 3, but I couldn't pass up the deal and it's as perfect as a used tailgate that you'll find outside of NOS or and early take off. I have been planning on using one of these bumpers since the beginning of the build but I've been looking for a painted original. For the price, I'll strip this one and powdercoat it. The last pic is my new Lokar shifter and trans dipstick.
I'm going to patch a few holes in the firewall and then get some epoxy on it in the next couple of days.
Sanity'66
Old 05-23-2014, 09:56 AM   #424
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: pdx-sanity66
Nice!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-23-2014, 08:30 PM   #425
Bomp
Bomp's Avatar
Re: pdx-sanity66
Your motor and frame look so crisp and clean. Always like looking in on the progress.
Bomp is offline   Reply With Quote
