12-03-2015, 08:45 AM | #401 |
Re: Project 68 k10 LWB..aka "The Hulk"
I was told my an old truck guy that truck tolerance on the assembly line was 1/4" so anything closer than that is a win. These weren't built for show trucks, no car was back then anyways.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
12-05-2015, 12:42 AM | #402 |
Okay so this is my first time replacing a cab corner. I must have put it and the rocker on 100 times.... So I just decided time to weld.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
12-05-2015, 12:49 AM | #403 |
Ok so I was having a hard time welding the cab corner where 2 layers of metal were. I am thinking contamination from whatever was between the layers of metal. Because the exposed metal was epoxy primed which I sanded off. But something was causing an issue.
I will try and get it finished welded up on Saturday.
12-13-2015, 12:19 PM | #404 |
Looking good sir! Did you get past the contamination problem?
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
12-15-2015, 12:42 AM | #405 |
Thanks and Yes just had to clean out the caulking the PO put on from underneath.
I had my bodyguy friend stop by when I had the rocker and door set. He said it looks better than original as far as the gaps. So since I didn't know how good was good I was afraid to just weld it. After he told me that I thought time to burn it in. This is a picture of the inner rocker with rust encapsulate on it.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! Last edited by First c10; 12-15-2015 at 12:50 AM. |
12-15-2015, 12:44 AM | #406 |
This is the out rocker primed. I painted it before I installed it
12-15-2015, 12:45 AM | #407 |
This is the rocker burnt in.
12-15-2015, 12:47 AM | #408 |
Close up of the driver rear door jab rocker.
12-15-2015, 11:19 AM | #409 |
Good job!
12-15-2015, 11:22 AM | #410 |
Looking real good. If you have time could you weld in the 16 seat nuts for me. I'm not looking forward to this step welding upside down.
12-16-2015, 12:16 PM | #411 | |
Thanks Brett.
12-17-2015, 12:55 AM | #412 |
hey guys I have a question regarding the holes in the firewall.i want to weld up the ones I don't need but not sure what all of them go to.
This picture is of the original throttle area and I think the top holes are for the windshield washer hoses. What did you guys do?
12-17-2015, 01:01 AM | #413 |
Does anyone have a picture or something about what each hole is for? Some I can figure out some not sure about.
12-17-2015, 07:54 AM | #414 |
This picture might help !
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
12-17-2015, 11:13 AM | #415 |
Here is another and one for A/C & non A/C. The extra hole not marked between the fuse block and the emergency brake I believe is for a tach harness.
12-17-2015, 11:38 AM | #416 |
Thank you Gary. I noticed that your cab is a little different than mine. Mine is a pre 71 I think as my cab did not have the throttle cable but the throttle pivot rod.
Can anyone tell me if I need the holes with the black arrows?
12-17-2015, 11:48 AM | #417 |
I filled in most of the holes on my fire wall. for the AC I cut out a bigger hole and did 1 patch panel. the smaller one I use a hole saw to make plug and welded them up.
12-17-2015, 12:00 PM | #418 | |
Do you have a picture of your firewall??
12-17-2015, 12:11 PM | #419 | |
I will study it.. Thank you!
12-17-2015, 01:18 PM | #420 |
3 of the holes are for the rubber plugs that hold the jute to the inside of the firewall, and the hole next to the steering column opening is for the collar that hold the column boot on. ( Screw hole )
12-17-2015, 02:09 PM | #421 |
12-18-2015, 12:44 AM | #422 |
I ran my washer hoses thru the cowel from inside the cab rather than out the fire wall and over the rain gutter.I brought the feed tube in below the parking brake cable. Much cleaner
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-18-2015, 12:46 AM | #423 |
For the hole with the black arrows i welded a 1" long piece of threaded rod in place of the screw and used nuts inside to hold the coloum dust boot in place
12-18-2015, 11:57 AM | #424 |
Can I weld up the holes and install studs to mount the jute with washers and nuts like you said about the column seal?
12-24-2015, 12:55 PM | #425 |
You could or don't bother with the padding at all you could use a stick on or spray on sound deadener perhaps?
