Old 04-26-2020, 08:12 PM   #4401
mick53
Re: What did you do with your truck today, Part 3
I started working on my turn signals and cruise for my 53. The turn signal mech is from a tri five apache. The cruise is Dakota Digital. I had a slight fitment problem on the cruise control handle. I practiced on an old one I had to see if it would work. I milled it square and flat. I then filed groves in the mech 1 molecule at a time. I sliced a 1/4-20 bolt to fill the void at the bottom and installed a screw in the top. It works amazingly well. Tight fit and no slop. Sometimes I get lucky. The hardest part was turning my mill upside down.
mick53 is offline   Reply With Quote
Old 04-26-2020, 11:41 PM   #4402
mikebte
Front springs installed. I may need to change shocks as they are close to the compression limit. Bump stops removed as they were very close.
Rides nice. Next to install the rear and align my steering wheel.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 04-27-2020, 12:21 AM   #4403
nvrdone
mikebte: what steering box are you using?
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 04-27-2020, 02:37 AM   #4404
MiraclePieCo
MiraclePieCo's Avatar
Steering wheel alignment should be easy with that turnbuckle on the drag link!
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 04-27-2020, 08:19 AM   #4405
Black_Sheep
Black_Sheep's Avatar
Adjusted the wiper linkage so the transmissions wouldn’t go over center and dismantled the passenger side door to diagnose the short in the solenoid for the shaved door handle. Discovered the solenoid has a dead short. I ordered a new one and put the door back together so I can use my truck in the meantime...
Black_Sheep is offline   Reply With Quote
Old 04-27-2020, 08:19 AM   #4406
Black_Sheep
Duplicate post
Old 04-27-2020, 08:57 AM   #4407
mikebte
CPP steering box. Had to make the stock steering box hole a small amount bigger for it to clear. Works nice!
One more leaf down and one to go, plus the parts I ordered for some other stuff found along the way. But almost have the springs done.
My YouTube:
Old 04-27-2020, 06:12 PM   #4408
mick53
I finished rebuilding my turn signal mech. and installed the cruise control handle I altered. I blasted it with a fine Garnet. I'm still surprised at how well the handle fits.
Old 04-28-2020, 07:22 PM   #4409
mikebte
Finished the drop springs. Had to remove the bump stops all the way around. Rear seems to clear but I'll need to change the sway bar location a bit. Front kits the frame if not careful, I'll most likely make a front shackle that's a little longer and it should resolve the issue.
Loaded up all my scrap in the back and it squats a bit. Ride is much better and that was the goal.
My YouTube:
Old 04-30-2020, 09:53 AM   #4410
MARTINSR
MARTINSR's Avatar
Damn you guys are getting some cool stuff done, can't wait to get back to mine!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 04-30-2020, 05:12 PM   #4411
mikebte
Brian
I can't wait for you to get back to yours ether, I have enjoyed watching your 5 minutes a day. After all, your build convinced me to stay leaf spring and It does ride nice.
My YouTube:
Old 04-30-2020, 11:37 PM   #4412
mick53
[QUOTE=mikebte;8729252]I can't wait for you to get back to yours ether, I have enjoyed watching your 5 minutes a day. After all, your build convinced me to stay leaf spring and It does ride nice.[
I'm also keeping my leaf springs. Check this guy out on leaf springs.
https://www.youtube.com/watch?v=S7rCGda4Ab8
Old 05-01-2020, 08:29 AM   #4413
mikebte
[quote=mick53;8729578]
That is very cool, even running the inline 6 and straight up killing the LS runners on the track. Always. Enjoy stuff like this, people using creativity and enjoying the car.
My YouTube:
Old 05-01-2020, 08:52 AM   #4414
mick53
[quote=mikebte;8729733]
I love the sound of an angry inline 6.
Old 05-01-2020, 05:50 PM   #4415
mikebte
Well I had ordered new shackles with my leaf springs from the usual scum bags only to find out they were unable to get shackles from the supplier. Since I am a rather impatient person I installed the new springs without them only to find out the original shackles were in fantastic shape. Asides from 7 of the 16 original seals had gone MIA, the new bushings in the leafs fit the old pins nice.
As they are in such good shape I ordered 16 replacement seals and just installed them on the old shackles.
Since I was at it I also started taking off the tie rods for new boots as the 6 year old boots are gone from the Arizona heat. Poly will be filling the void.
My YouTube:
Old 05-03-2020, 08:45 PM   #4416
mick53
Haven't got much done this weekend, a few hours of polishing. I have a 12" X 36" lathe coming tomorrow So I have to make room and run 220v over there.
Old 05-03-2020, 11:44 PM   #4417
idbeast
Last week the wife wanted to go for a ride in the 56, so we started driving and the front fenders started dragging on the tires, (77 nova front clip) so I took it home and went down and picked up some 1" spacers to put in the coils, it didn't help at all. So I dug out the new 1 1/2" lowering springs that came with tubular control arms I bought, and installed them, the front end sat even lower then when I started, so I took off my 2" drop spindles and put the stock one back on. Now it rides great without rubbing!
idbeast is offline   Reply With Quote
Old 05-04-2020, 03:53 AM   #4418
MiraclePieCo
Looks pretty darn good too!
Old 05-04-2020, 03:59 AM   #4419
DransportGarage
DransportGarage's Avatar
Originally Posted by miraclepieco View Post
looks pretty darn good too!
x2
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 05-04-2020, 10:12 AM   #4420
nvrdone
nice stance. looks like it should be a great driver. especially with this weekend's weather in Seattle.
Old 05-04-2020, 10:21 PM   #4421
nvrdone
so today I made some great progress on my power drum brake conversion. for those of you who have helped with ideas, thanks much.
I was talking with a friend who owns, at last count, 38 Buicks of all models, classics and hot rods. Anyway, he suggested that I check the clearance between the push rod from the brake pedal to the booster & said it should be about 1/8 - 1/4" just so there was no pressure on the shoes. I checked & mine was almost 1". adjusted that & got a big improvement. he also said that on manual brakes the pedal ratio should be 6:1 and on power it should be 4:1. I checked mine and it was at 6:1. I was able to drill another hole in the lower arm & get 5:1 which again helped pedal travel. at this point the pedal travel feels much better but may need more work. tomorrow I will test drive it. wish me luck.
Old 05-05-2020, 05:32 PM   #4422
Mains52
I managed to make boxing plates and weld them into the rear area of my frame where my 4 link will be.
Mains52 is offline   Reply With Quote
Old 05-05-2020, 10:14 PM   #4423
mick53
I spent most of the day making a place for the new lathe but I received the rest of my fasteners for the thermostat housing on the 292.
Old 05-05-2020, 10:21 PM   #4424
vintovka
vintovka's Avatar
While ot thought i'd mention that if many lathes of that size need ample access behind them. Some with rear electrical controls need a foot or so. Many realize it too late.
vintovka is offline   Reply With Quote
Old 05-05-2020, 10:23 PM   #4425
nvrdone
test drove the truck today & brakes feel better, but still not 100%. pedal has more travel than I would like. feels like there is still air in the brake lines so Friday im taking it to a friend's shop for a look see and to bleed the brakes. so at least im making progress
