Old 07-20-2020, 06:45 AM   #4451
Grizz1963
Grizz1963's Avatar
Re: Grizz's Redneck Express 1966 Chevy Short Fleetside RESTO-GO!
And another score
Headed for the clearance skip......
7 weeks of use from new.
Too expensive to repatriate back to the depot so written off.
Guess I have an almost new fridge for my lodgers extra stuff.
The other one I have is now free to someone for collecting. PM if you want the other one that I previously got.
Free stuff. Free money.
Love it.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-20-2020, 09:58 AM   #4452
Indian113
Indian113's Avatar
Good Score Rian!
Indian113 is offline   Reply With Quote
Old 07-20-2020, 06:07 PM   #4453
Grizz1963
Grizz1963's Avatar
Originally Posted by Indian113 View Post
Good Score Rian!
That it was.
My lodger leaves the 27th as they have managed to get ahead of schedule.
So a lot of the stuff purchased for the contract is too costly to repatriate to their depot 300 miles away.
So it gets dumped or left behind.
More progress.....
The rules.
Getting the posts cut down to the right height
Measure, use a level said Mickey, I rarely do.
I have had these posts since Boxing Day 2007 when Oldbus delivered them, along with my 1963 Ford Taunus Transit.
A significant OOOOPPPS moment.
Made up some new 10mm thick top plates, drilled and prepped and cut to size.]
Handy having a welder on site.
Decent grip......
Gluing steel
Posts welded, and put on foundations.
Only one problem, the tall one is facing the wrong way by 90’ as it would not seat on the foundation.
Problem to be addressed.
Posts are heavy enough to make them a two man lift.
Managed to damage the thread on only one.
Another thing to correct later.
One other job Andy did for me, was to weld together my stainless steel BBQ grille which had deteriorated over the last 10 years.
I did help........ honestly.
End of the day.....
Weekend over.
Old 07-22-2020, 03:16 AM   #4454
Grizz1963
Grizz1963's Avatar
Well......
This popped up on FB Memories this week.
Two years since adding the Toyota Argo front bumper section.
Best ever banger for your buck.
Fixed the thread.
Copper slip applied and all nuts tied down.
Also took the post out that was facing the wrong way and adjusted the holes by about 1mm each with a tungsten carbide grinder on my power drill
Then shimmed and tied down, plus cut the threads down to length and added more copper grease for future protection.
Using a Christmas gift from 15 years ago for the first time.
Nothing like getting that spirit level bubble just perfectly set.
Some design and redesign of the wall plates happened too.
More about that later.
But then time for some fun.
Picked up these stainless steel plates at the scrapyard for £2.00 along with a galvanised 3 bike bicycle rack.
Yup.......
Needed to make up a sign for the door on the compressor room.
All to be blamed on @PaulY
Done, with hanging tab.
Also delivered the bike stand to @PaulF while collecting a bicycle for neighbour Sam.
Got to meet new addition to their family, Ada.
Old 07-22-2020, 11:36 AM   #4455
Indian113
Indian113's Avatar
Odd how much you two have the same expression!
Old 07-22-2020, 05:46 PM   #4456
Grizz1963
Grizz1963's Avatar
How true.
Old 07-23-2020, 12:31 PM   #4457
Grizz1963
Grizz1963's Avatar
Made another batch of aniseed rusks inbetween Zoom and teams meetings.
Man must eat.
House smelled rather good for two days.
Plan originally was to create wall plates to hold the roof on the garage side.
But like all great plans, it was reviewed after we had measured and set out the steel as planned, then I decided that there was enough steel to use full lengths resting on the ground and bolted to the wall.
So start afresh....
Measure out 16 tabs and two straps on 65mm x 10mm flat bar, pilot drill, then 13mm holes to take the M12 Fisher bolts (Like Rawl Bolts, but longer threaded bar inserts to cut to length after fixing)
25 of these puppies for £29.00 or thereabouts
Tabs cutting used 1 x 1mm disc per 2.5 cuts.
Pile of bits to clean up, and grind a decent weld edge onto.
Better, ready to weld onto steel beams.
Also noticed what a mess the garage had turned into since starting this carport build.
Hopefully it will all come together and result in some real work getting done too.
During the day while working at the day job, I got a pic from one of the inmates of this forum and he was not a happY guY
On a train, Londonbound, wearing a virginal white gimp mask.
Later.
Old 07-25-2020, 05:46 AM   #4458
Grizz1963
Grizz1963's Avatar
So on Wednesday evening after work, I grabbed the supersized grinder and a new disc to start cutting the 200 x 100 beam we previously welded in half again as it was going to serve as one of the front upright posts.
I donned full PPE as that machine intimidates me.
Three quarter way through, I heard loud laughing when I stopped the machine to turn the beam onto its side.
It was Andy, stood with a beer in hand, camera in the other........
He also had never seen me wearing it all, including earplugs.
I was pleased to see him.
So once the beam was cut, we cut the last of the three galvanised beams @Oldbus had brought years ago in 2007 down to the right length for the rear support.
Then Andy burned two holes through the steel, we used a Bullnose Tungsten burr cutter to tidy the hole so that a long reach socket could get in there, and started to weld in two straps from behind and a bunch of tabs, all to hold the post that would be resting on a cement base onto the garage wall.
Done.
Then in another unprecedented move.......
I used a spirit level to Andy’s shock and dismay to get it straight.
Up the ladder with the SDS drill, 12mm first, followed by 20mm holes 100mm deep.
All the bolts ready, Ductape keeping it all together for the next fun step......
Threading all the tabs in at the same time, while holding that heavy beam in place.
I think Andy was impressed.
Job done, red oxide next once I made a spray painting cardboard mask to add to the job.
Only needs to top plate to be welded in
I will measure, drill and cut it on Saturday, welding Monday after work.
Bit by bit. Getting there.
One more upright to make up, and the paving to be completed around the other posts where the bolts are in the concrete foundations..
Need to start figuring what cross beams to use and the lay out of the frame and roofing.
Old 07-25-2020, 06:21 AM   #4459
Grizz1963
Grizz1963's Avatar
Almost back up to date now.
Thursday was another full on work day, training till after 5.00pm
Dinner with Sally and Andy, then back down to the garage to do the last post and also to cut in and fit,paving stones right up around the other posts.
Complex cuts, but if done right, the results are certainly rewarding.
Happy with these.
Andy carried on with getting the tabs welded onto the last post.
For those wondering about the tabs all being on one side, it’s because in both cases, rather than doing wall plates, the posts seem a better idea, but need to go on the edge of the concrete posts and I doubt it would resist tightening those M12 bolts on the Rawl bolts, so straps behind, out of sight and side tabs should be more than enough.
Adding the side gate post back onto the upright as it was previously on the wall.
Job done.
Next week a few small bits, the. Invite some pros to quote on fitting a good, industrial roof.
Old 07-25-2020, 01:06 PM   #4460
Grizz1963
Grizz1963's Avatar
Just when you think there is a bit of time to relax, you find more jobs that need doing, or do they find me?
Painted the house in about 2011
So it is kinda due again, and with adding the carport that will be stopping me getting up most of the front of the garage, I need to paint it before the roof goes up.
That means the house gets painted too......../
Went looking, along with device from the forums, Got Sandtex at Toolstation.
10 litres for £60.00
Colour is a PITA as I like brighter colours, but none available.
Ended up with pensioner spec Colour Cornish Cream.
I prefer brighter colours, but nothing worth having out there.
Last coat lasted 9 years, and I am mainly painting as the carport will cut garage front gale in half, so only need me on the roof in 10 years or so, let’s hope for good weather for a bit next week or so.
Saw this on FB today.
You forget how big a C10 actually is.
Bootfair in the morning
Old 07-25-2020, 01:36 PM   #4461
mjh1965
mjh1965's Avatar
Yes I posted that on Facebook. I couldn’t believe the price £39995 . https://www.ebay.co.uk/itm/203057871594 Nicely done truck though
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 07-26-2020, 05:22 AM   #4462
Grizz1963
Grizz1963's Avatar
Bootfair was good today.
First buy......
This is 38 years old.
Bought from the original owner, he used to sit in it.
Some cars, liked this madness.
£1.00 hammer.
Got a few pieces for Craig and his daughter Elli.
£1.00 for.the crown, and 50p for the letter E
Also got some really good Coca Cola glasses for him £8.00 for 4 glasses, lady threw in a free bottle opener. Then I negotiated another four Glasses into the price
Total haul.
Included a Jockey wheel for my welding caravan £4.00
Two glass stars for Sally’s garden shed wall 50p
VW camper plaque for shed £1.00
Box of 4x40mm screws, unopened £1.00
5 Hotwheels cars £1.00
Small hammer £1.00
Cast iron owl £1.00
One crystal glass FREE
And another item I really liked.
Now headed to the garage for some machining.
After another coffee.
Old 07-27-2020, 10:54 AM   #4463
Paul Y
That picture of me on the train is definitely getting around!
I absolutely detest those mask... Anyway.... Fantastic work as always Rian, putting some of us to shame.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 07-27-2020, 02:17 PM   #4464
Grizz1963
Grizz1963's Avatar
P.
Picture?
That was you ?
Thanks re work, seems there is always something to do.
Remember that little Toyota Deliboy that really had my attention?
It has sold, and the new owner has started a thread for it.
CLICK:
https://forum.retro-rides.org/thread...toyota-deliboy
Looks like it may have a good life there with him.
Has some plans for it too, already started.
This
Old 07-29-2020, 03:26 AM   #4465
Grizz1963
Grizz1963's Avatar
Prepped the last of the carport mounting plates over the weekend.
Also got a signed for parcel from Andy in Tulsa,Oklahoma yesterday.
Andy the lodger came back from his long weekend, he leaves on Thursday for his next contract.
Brought me a great garage gift for the kind of guy who works in flip flops , as evidenced the last couple of weeks doing a load of cutting and grinding.
An awesome ground magnet.
RESULT !!
I also had @PaulY complain because I had not found a KING DICK spanner for the door handle to his annexe.
So we made one up for him, hope he likes it.
Welded up, mounting plates came from a balustrade I found somewhere. Cut them shorter.
Then one to the real, last job on the list.
Welding the top plate up, and then onto the 200x100 RSJ
DONE !!
Followed by these, and Sally cooked us spicy chicken wraps.
Taken two days off work this week,
Hope to get some steel guys to come quote on making up the steels and fitting a roof for me.
Old 07-30-2020, 08:21 AM   #4466
Grizz1963
Grizz1963's Avatar
Dennis has been forging along with various jobs.
Including the NASCAR C10 build.
Radiator in.
Fuel lines in, hopefully the last time.
And an effort to make the truck lighter.
Also on the cars is Dennis making a full, fibreglass hood for it.
From Fayetteville in Arkansas, Clem at Tubatrucks.com sent Dennis some gun racks for the truck too.
Also landed from Andy in Tulsa, another parcel with his ‘reject” Alu-Bronze castings.
I love their imperfection, Andy the welder/lodger scooped one Bull**** Corner, and I gave him a good Hope -lacquer too.
Every now and then I realise I sooooo live in the wrong country.
Workshops, trucks, trucks, trucks.
Dennis currently dailies this, rather than his supersized GMC, says it is a nice change driving the little GMC Cabalero.
I love driving it when I go there, for a one owner from new truck before he got it, it has areal 70’s feel, despite being an 87 model.
At work, his Son Adam bought this 2006 for $250.00 including a full tank of gas.
And was given this one for free two weeks late.
Time we changed our employers.
In other news.
From Russia, Vladimir offered me a Moscow plate for my collection.
Saturday came and went.
Sunday Bootfair delivered.
At £4.00 compared to the normal range of £10-20 fora jockey wheel, this price was right.
Meaning I could move the shed carAvan and the welding caravan plus other junk off the drive.
Consolidating pallets with half bags of sharp sand and gravel for concrete when I chop up the driveway and move it 400mm to the side in order to straighten it out.
Looks like a holiday camp.
Looking better.
Posts in perspective.
Loads of work to get to this simple point.
Other direction
From Mickeys place, he is about 500mm below my level.
Once all was tidied and sorted, I put stuff back in place
Have called a steel rigging and roofing guy to come look if he is prepared to take on a small job like this.
Hopefully he will come on Friday to look.
Old 07-30-2020, 11:27 AM   #4467
Nice area there Rian. Should be a very good spot once it is covered.
Old 07-30-2020, 02:32 PM   #4468
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good Rian. The one BS Corner casting missing the Bull part of the text is fitting for what I has been going on in 2020...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-01-2020, 04:33 AM   #4469
Grizz1963
Grizz1963's Avatar
Thanks Bill.
Should be really good for the dirty, dusty part of getting my body work done on the cab, doors, bedsides etc.
Plus keeping stuff dry. (Hoarded)
So true.
But we will look back one day......
Old 08-01-2020, 04:34 AM   #4470
Grizz1963
Grizz1963's Avatar
Early morning chore on Friday.
Collect a non working medium sized glass door fridge about 7 miles from here in the Galaxy.
Purpose?
Airtight, solvents storage cabinet with a bit of insulation.
Should work.
So living rurally has its perks.
Harvesting and baling out behind the house till 11.00pm
Being able to watch or even go for a ride in the combine
Beats city living any day.
Amazing how these big trucks run through the fields to collect the large bales of rapeseed canola “Hay” to go to Holland by road.
Military style operation.
Started to paint the garage, before the roof goes on the carport, so I have full access to everything, and can do all the cutting in in nooks and crannies.
Two charts everywhere with a 1” brush as it gets into places.
Roller next, two coats as well, to give good cover on colour change.
Next is brush paint the whole house, which is covered in rough pebble dash.
Why do people do it.
Happy Sunflowers.
A new to me, used tool.
20000rpm 90 degree die grinder, ordered some quick release 2” and 3” grinding wheels for it.
Seen them used, and Dennis lives with his in his body shop.
Wanted one a few years as they seem really useful.
Andy the lodger brought me an air powered impact wrench with torque adjustable power settings from his garage last weekend, he bought it for a job years ago, never used it since, reckoned I would use it more after seeing me use the electric Clarke, I had bought to use in the C10 5 years ago and have used regularly on various jobs since then
Nice.
New company car was due mid-March.
Delivery yesterday.
Chuffed.
Sunset last night, pics taken 10 minutes apart.
Looking toward London’s Canary Wharf.
Moon 35 minutes after sunset.
Crazy.
Moon.
Looking away from London, toward France.
Old 08-02-2020, 01:11 PM   #4471
Grizz1963
Grizz1963's Avatar
It was mate Andy in Tulsa, Oklahoma’s best friends 71st birthday yesterday.
So he took her on a little road trip to Kansas on back roads through Osage county.
Loads of oil it seems, belonging to the Osage Tribe.
He sent a pic of the FJ next to the road, with an oil derrick in the background.
Wish I was there.
Old 08-02-2020, 06:58 PM   #4472
Indian113
Indian113's Avatar
Rian, I'm kind of bummed out as last year I couldn't join in the USA trip of the wild bunch and this year has to be cancelled because of Covid! I sure hope you guy's can head this way again.
Old 08-05-2020, 09:24 AM   #4473
Grizz1963
Grizz1963's Avatar
Yes, not happy with the way things have gone Ray, but that is life.
We will be back.
Photobucket is a pain, again.
Stolen fruit is the best.
Two hours worth of collecting in 5 sites.
Trust me,
3 hours in there, cleaning and removing all the stones to leave me with 5kg or 10 pounds of fruit.
Add a litre of water, and bring to the boil for about 20 minutes, then add 4.5kg of sugar.
Boil for about 90 minutes till all the water is gone, testing cold viscosity from time to time.
In the mean time sterilise all the bottles and lids in the dishwasher.
Once cooked, use a jug to decant hot (it is dangerous) jam into bottles.
Add lids once all is done.
Take a bottle outside, check the light penetration, take a photo and gloat.
I add extra lemon juice, as I prefer a slightly tangy jam.
Also less sugar than recommend, but it still is very sweet.
Need more fruit now.
Old 08-05-2020, 10:30 AM   #4474
Grizz1963
Grizz1963's Avatar
Had steel guy over yesterday.
Quote to come when he has done design and pricing..
Pulled down the posts last night after measuring, they need a 200mm drop to get it more right.
Cut them shorter at lunch today, new plates to be drilled and welded possibly tonight.
Photobucket is a pain.
Old 08-08-2020, 06:14 AM   #4475
Grizz1963
Grizz1963's Avatar
Once again Photobucket being useless.
Went to see Sally at her best friends place, they have been friends since age 4 years old.
The neighbour had this Fordson tractor, been restored and he now sold it and replaced with a classic mini, because neighbours objected to him driving it in a residential area.
Finished painting the garage and steels.
Next up.
House, horrible job.
Balers came and completed harvest, bales loaded in the fields onto curtain sliders and headed to Holland for their dairy industry. One way to inflate U.K. prices I guess.
Had the steel structural guy here on Monday.
Suggested I lower the posts by 200mm at the front and change the drop off angle and rear.
Which meant disassemble, cut, paint and generate new top plates and weld them back on.
New setting, green is line, though it will be a bit lower at the rear, orange is 200mm high RSJ’s
Blue is where roof will be extending to.
Greg the new lodger who replaced Andy the welding manager is a plater (boilermaker) and weirdly, stepped into Andy’s shoes readily, looking for stuff to do, loving a BBQ and beer.
So the carport build is continuing with some serious professional help and advice. (I guess it is like me going to the USA on holiday and getting a thrill being allowed to drive tractors, and swing chainsaws as part of my therapy)
Weird to me, how both Andy and Greg work on site without a knife to do various small cutting jobs.
He commented that he should really have a knife when I was cutting some foreign dried meat products with my French Opinel while we were having a beer and a chat on the deck.
So I fetched a few from my stash and collection (I do like a nice knife) and offered him one to take for himself.
Too many choices.
In the end he selected this little guy, a nice cutter which feels good in the hand too.
He did request a decent T-Bone to cook on the fire, so on Friday I went to my favourite Turkish butcher to get some cut.
35oz steaks were not a challenge, that is 1kg steak to those who do not understand Imperial.
Flame grilled to perfection.
I love cooking fast on a really hot fire, but it does hurt when you have a lot of stuff to turn and manage.
Note, my BBQ’s rarely look like the Pride of Britain, blackened pork sausages and cheap burger patties.
Greg saw me hurting, disappeared and next thing came back with these.......
Kevlar, cut resistant and good to protect my knuckles from the glow of the coals.
He also did suggest we set up my Mig Welder for MMA so that I can do stick welding.
Needed an adaptor, tongue and cable plus welding rods as I had given away my Stick welder, some masks, chipping hammer and all my rods a few months ago to a mate who needed it more than me.
Oh, and I could do with a real lesson to add to a lifetime of self taught bodgery to make sure my welds were strong and correctly laid. Not that I ever had complaints before.
And then the weekend was over.
