Old 10-14-2010, 07:26 PM   #426
Jonboy
Slots go on anything!
Re: LS1 into a 73 cheyenne
Originally Posted by smokedat View Post
I got my paint today it is PPG DBU WA 512Q Jetstream Blue Metallic Tintcoat 3. This is GM corvettes Z06 and ZR1 color. 4 gallons of reducer and 2 gallons of basecoat and 1 of midcoat you reduce with 1-1.25 of reduser so this is alot of material. For the sealer I am using PPG Deltron V-seal. For the clear I will be using Dupont Imron 500s.
I am doing a Corvette inspired theme truck using corvette components such as the engine, breaks, and paint color, so I am oficially calling this project the Z10 I will be making some custom embles to place in the fenders.
That last pic is old school. I didn't think you could even buy that in Cali.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-15-2010, 11:25 AM   #427
68 TT
Still plays with trucks
68 TT's Avatar
I got some more stainless goodies i got the bed bolt kit, door kit, the door strikers, and stainless shimms
They look great but make sure you coat the snot out of the threads with anti-seize compound. Stainless will bind up really easy and you can easily break the bolts trying to get them loose to make adjustments to the hinges and striker.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-15-2010, 10:23 PM   #428
mcbassin
Still Learning
mcbassin's Avatar
What he said!
I can't tell you how many stainless bolts I have had to remove because of galling threads. Anti-seize helps for sure.
mcbassin is offline   Reply With Quote
Old 10-16-2010, 05:45 PM   #429
franky69c10
chevy runs deep
franky69c10's Avatar
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 10-20-2010, 02:57 PM   #430
smokedat
smokedat's Avatar
I got the fron clip on and started to align the panels. The new hood looks effin sick.
smokedat is offline   Reply With Quote
Old 10-20-2010, 03:07 PM   #431
smokedat
smokedat's Avatar
finally finished the body work on the tail gate, this was really time consuming with all the curves and humps. It was a challenge to find a tail gate with the long extended chevrolet letters in good shape, with some luck I did find a second tail gate frome some other truck wich it to needed alot of work. The tail gate that came with this truck was trash it was warped and dinggd beyond what a hammer and filler could do.
Old 10-20-2010, 03:11 PM   #432
68 TT
68 TT's Avatar
Are you going to shave the locks & handles? Not usually a fan of this but your truck is so smooth it just looks out of place to have them.
Old 10-20-2010, 03:11 PM   #433
smokedat
smokedat's Avatar
Now i have ran into some techincal difficulties. Aligning the panes I want to get them as eaven as possible wich can be more difficult than u realize. The task of panel alignment is a long and tedius one. the side view and size of the gaps is fairly eaven.
sample pic
Old 10-20-2010, 03:14 PM   #434
smokedat
smokedat's Avatar
problem areas - there not flat eaven with one another
Old 10-20-2010, 03:16 PM   #435
smokedat
smokedat's Avatar
here is a picture of the engine compartment
Old 10-20-2010, 03:21 PM   #436
smokedat
smokedat's Avatar
No, I will be using the handles & locks. I am trying to capture and preserve the exteriror original look on this project.
Old 10-20-2010, 03:34 PM   #437
3r!c84
Badass
3r!c84's Avatar
i want your camara !!!!!!!!!!!!!!!!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-20-2010, 04:24 PM   #438
menace121978
menace121978's Avatar
awesome progress!!! looks sweet dude!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 10-20-2010, 06:47 PM   #439
nbpro
looks sweet
nbpro is offline   Reply With Quote
Old 10-20-2010, 11:56 PM   #440
texasfunk
texasfunk's Avatar
screw the camera, i want the truck!!! looking good!!!!!!!!!
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 10-21-2010, 08:36 AM   #441
Jonboy
The truck is looking really slick. Can't wait to see some paint on it!!
Old 10-21-2010, 04:43 PM   #442
smokedat
smokedat's Avatar
Thanks, I also cant wait to slap sum paint, its stil cookin but its almost there
Old 10-21-2010, 04:47 PM   #443
smokedat
smokedat's Avatar
Yesterday I applied som silver POR 15 on any exposed cavitys such like the tail lights and the inner fire wall, and top and botttom of dash. When I find the time I will cover the entire bottom of the cab and bed.
Old 10-21-2010, 04:51 PM   #444
smokedat
smokedat's Avatar
Today I am going to fix the cut out on the bottom of the bed for shackle clearance that the previos owner did. This area will most likely not be seen but I dont like it.
Old 10-21-2010, 06:03 PM   #445
aggie91
I'm just glad to be here!
aggie91's Avatar
I like the smoothed inside of the fenders, are you going to do the same with the underside of the hood?
Looking good! My son is leaning to that color too. His will be another few years before we think about paint...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-21-2010, 09:40 PM   #446
twoodson
looking good bro
twoodson is offline   Reply With Quote
Old 10-22-2010, 07:23 PM   #447
smokedat
smokedat's Avatar
Got it done, its a built up box. I sprayd sum rust encapsulator primer
so the welds dont oxidize.
Old 10-25-2010, 12:56 AM   #448
smokedat
smokedat's Avatar
i got rid of the original stopers and replaced them with these new low profile pancake style
Old 10-25-2010, 12:58 AM   #449
smokedat
smokedat's Avatar
I will start prepin the frame and differential to re shoot it
Old 10-25-2010, 01:18 AM   #450
smokedat
smokedat's Avatar
I am also goin to redo the cam. I havnt desided yet i just want streetability power and sound its going to be a weekend warrior not a DD. Heres a vid of a cammd LS1
73c10, c10, cheyenne, ls1, swap
