Old 12-07-2014, 10:30 PM   #426
LEEVON
LEEVON's Avatar
Re: My version of the s10 swap
Looking good!!!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-14-2014, 09:30 PM   #427
BlueJeep
BlueJeep's Avatar
Spent a bunch of time working on the oil cans I had in the back of the cab. After a bunch of learning, some stretching here and some shrinking there and the cab is now ready for the body shop. I couldn't reach my hand in far enough to do all the stretching I needed to do so I had to get creative.
Here's what I came up with. Worked very well and I needed to make some post dollies anyway so killed two birds....
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-15-2014, 11:26 AM   #428
Rude Dude
Rude Dude's Avatar
Great idea on the dolly tools! Love the spray on bed liner too.
Rude Dude is offline   Reply With Quote
Old 12-15-2014, 05:11 PM   #429
99 to Life
99 to Life's Avatar
very nice two birds with one stone
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-15-2014, 06:15 PM   #430
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Love the Shed! And the bottom of the cab is perfect!
ChuckDriver is offline   Reply With Quote
Old 12-15-2014, 10:43 PM   #431
BlueJeep
BlueJeep's Avatar
Thanks guys! When I have time, I need to finish a stand I started making for tools like this. Something that I can move around and use for planishing and shaping. Don't know how many times I wished I'd had a stationary dolly so I could hold the panel with one hand and beat on it with the other. This was step 1 for that idea.
Thanks! I already had neighbors come down and taken Christmas pictures beside it.
Next task for this week or next weekend will be to fix this door. It only needs the little flap that is folded over the inner door frame. The door itself has pits but proved to be solid after it was sandblasted, so those will just get filled. Should be a fairly easy task.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-22-2014, 12:28 AM   #432
BlueJeep
BlueJeep's Avatar
Door is fixed.
Rolled the frame back in the garage. Time to finish up some things and get ready for the cab to go to the bodyshop.
Painted and installed new steering components, painted and installed the sway bar with new end links and bushings.
Bent up and installed the brake line for the rear brakes.
Welded in my O2 sensor fittings and painted the exhaust with VHT dull aluminum paint.
I also drilled out the original oil pressure sender to 1/8" NPT and am currently looking for an extension in as few of fittings as possible to make this work and clear the intake bolts.
Over the next couple days I'll get the exhaust installed for good and the cab on too!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-28-2014, 11:26 PM   #433
BlueJeep
BlueJeep's Avatar
Oil pressure sending unit, check! Rear brake line, EVAP line, fuel lines, exhaust, check! Re-epoxied the floor and inside of the firewall and seam sealed the inside seams, check! Cab off to the body shop, check!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-28-2014, 11:32 PM   #434
99 to Life
99 to Life's Avatar
looking good. get as many checks off the list as you can, cause they are never ending it seems!
Old 12-28-2014, 11:33 PM   #435
BlueJeep
BlueJeep's Avatar
Now with the truck out of the garage I can finish up some other things that I've started. Need to do some maintenance on some of my tools and finish a metal shaping stand that I started on.
Stand with sand bag attachment:
How I set up the wheels:
And post dolly attachment. Tomorrow after I pick up a new band saw blade I have some other attachments and do-dads I'll add to it to increase the utility of it. I'll mount the stretcher/strinker to it and the Beverly shear too, so I can just put whatever attachment I need at the time on it.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-29-2014, 03:26 PM   #436
Troy Sr
Troy Sr's Avatar
Now that's a nice tool!!!
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 12-30-2014, 09:48 PM   #437
T Hilde
Hmmmm? I think I know what you meant.
LOL, he does build nice equipment
T Hilde is offline   Reply With Quote
Old 12-30-2014, 11:29 PM   #438
Uncle Jimi
Uncle Jimi's Avatar
Your build looks killer! I'm wondering what you are using for seam sealer? Thanks!!
Uncle Jimi is offline   Reply With Quote
Old 12-30-2014, 11:37 PM   #439
99 to Life
99 to Life's Avatar
jimi, I used a couple different brands of seam sealer. You can find them on ebay. One was from TP tools, if you haven't heard of them, they have alot of great stuff. There is an epoxy based and just a cheaper rubber based. The epoxy base is really stiff when dry and is more money. Rubber based was ok, esp for the price.
Bluejeep, I might have to steal your awesome pedestal idea!
Old 12-30-2014, 11:56 PM   #440
BlueJeep
BlueJeep's Avatar
Thanks! I'm looking forward to using it to planish welds. I'm thinking it'll be much quicker than holding the dolly and hoping the panel didn't move.
Thanks!
Couple years ago I started using Eastwood brush on seam sealer, it was OK. For the bottom and top of the floor I've been using Lord Fusor (stole that research from Frizzle Fry), and I'm very happy with it.
Steal away! I'm posting pics hoping it'll spark someone else to get a good idea of something I can steal back in the future!
It gets better, more attachments! A chunk of this should be handy:
And one of these should be useful:
Added some supports and some attachment holders, so it is self-contained:
If you couldn't tell, I'm just making tools out of heavy metal objects I've collected. The only "purchased" components here were the sand bag, wheels, and the Harbor Freight dollies, of which I welded a piece of 1" solid rod to to make post dollies. The rest was steel, most of which I had lying around.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-31-2014, 12:03 AM   #441
BlueJeep
BlueJeep's Avatar
Next up on the "shop tools" list was some maintenance on the press. My poor press has been used heavily, and for the last [too ashamed to mention how many] years it's been bent. The 3/4" plate at the top was pretty stressed, so I picked up a 1" plate to replace it. This, combined with the 3/8" thick gusset I added to the top side should move the weak link to something else that will surprise me someday!
Before - note the areas without paint being where the metal has been stressed:
I should have put a straight edge against it, the picture doesn't make it look as bad.
And the repair, before gusseting or painting.
That should do the trick!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 01-01-2015, 09:33 PM   #442
BlueJeep
BlueJeep's Avatar
Today I worked on the splash pan that goes on the bottom of the grille. I wanted to "de-hump" it where the hand crank would have gone through and also wanted to direct air up and into the radiator. Most of the hard fitment work is done now, just need to finish it up.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 01-01-2015, 10:31 PM   #443
99 to Life
99 to Life's Avatar
looks great
Old 01-02-2015, 10:47 PM   #444
BlueJeep
BlueJeep's Avatar
I stopped by an upholstery shop earlier in the week to show him my seat and ask about prices, options, etc. He said no go on my existing seat. It had a soft spot in it that I always thought was strange on the top edge of the seat back. He said it was a mouse tunnel, and to find a new seat. He also advised me to not get one that had the fabric glued to the foam as the first one did too, and it would have better results. I stopped by the pick-and-pull today and for $35 got a different one, this one he gave the thumbs up on. He also said I should bring my wife back to pick out a color of vinyl as men often get these decisions wrong....
Here's the "new" seat in front of the "old" one. The tear is only in the cover that will be replaced anyway. Headrests will not be retained:
And the vinyl I picked out.....we'll see if it holds up to the wife test when I get a chance to stop back there with her.
I think it will look nice with the green:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 01-02-2015, 11:10 PM   #445
99 to Life
99 to Life's Avatar
looking good, those seats outta 88-98 style chevy
Old 01-03-2015, 12:17 AM   #446
oldman3
oldman3's Avatar
Like the color of the material...Jim
oldman3 is offline   Reply With Quote
Old 01-03-2015, 01:32 AM   #447
BlueJeep
BlueJeep's Avatar
Yeah, like 88-94ish. Earlier ones had the fabric glued to the foam.
Thanks Jim!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 01-04-2015, 11:58 PM   #448
BlueJeep
BlueJeep's Avatar
This weekend I started in on the rear fenders. Similar to what I had to fix on the front fenders. Surprisingly, the original fenders are 20 gauge.
Before:
During:
And after:
This week I hope to get some time in to start in on the other problem areas on this fender:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 01-05-2015, 12:24 AM   #449
oldman3
oldman3's Avatar
Super nice job on the fender repair. Next part should be a piece of cake for you..Jim
Old 01-05-2015, 12:33 AM   #450
99 to Life
99 to Life's Avatar
looks great
