Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 08-07-2017, 11:01 PM   #426
awbrown
Re: finally come
lOOKS GOOD !!!
awbrown is offline   Reply With Quote
Old 08-21-2017, 11:09 PM   #427
pimpston65
pimpston65's Avatar
Re: finally come
just dialed in my mig welder
pimpston65 is offline   Reply With Quote
Old 08-21-2017, 11:10 PM   #428
pimpston65
pimpston65's Avatar
Re: finally come
back side
Old 08-21-2017, 11:31 PM   #429
Bomp
Bomp's Avatar
Re: finally come
Something to be said about 100% penetration!
WooHoo Looks Good
Bomp is offline   Reply With Quote
Old 08-22-2017, 10:38 AM   #430
pimpston65
pimpston65's Avatar
Re: finally come
WooHoo Looks Good
thanks. i was hoping a member made a comment, cuz i havent welded much and now i have a heap of patching to do. since you approve i can rest easy bout my skills...
Old 08-22-2017, 10:54 AM   #431
pimpston65
pimpston65's Avatar
Re: finally come
WooHoo Looks Good
Old 08-22-2017, 02:55 PM   #432
wahl4m
Re: finally come
you need to hammer & dolly the weld as you go ! got to the -metalmeet .com or allmetalshaping sites -lots of help available there -you do have to dig in the archives a bit ?? good luck !! mike
wahl4m is offline   Reply With Quote
Old 08-22-2017, 04:16 PM   #433
pimpston65
pimpston65's Avatar
Re: finally come
thanks for the info. i'll check it out tonight!!! oh i forgot its on the rear quarters of the burb that im working on, they have the inner panel so no dolly action.
Old 08-22-2017, 07:02 PM   #434
lower50's
lower50's's Avatar
Re: finally come
Well that's a great start.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-23-2017, 06:38 AM   #435
wahl4m
Re: finally come
remember -yoiu might use some weld thru primer -inside that 1/4 -or leave a spot on the back side for access for undercoat or something in there or it will rust real quick when the outside is finished ?? there should be lots of info on the 2 metal sites i mentioned - it would also be easier if the body is on a positioner for welding ?? im about ready to start on my 59 napco carry all ,lots of the same welding spots to be done !!
Old 08-23-2017, 07:25 AM   #436
pimpston65
pimpston65's Avatar
Re: finally come
i have a large area to patch. i will need to peel parts off to get access to internal parts such as the clam shell recieiver that i will be grafting a new rustfree piece back on. so i can get to the back side then
Old 08-23-2017, 09:29 AM   #437
LT1 Burb
LT1 Burb's Avatar
Re: finally come
Looks good, nice job.
LT1 Burb is offline   Reply With Quote
Old 08-24-2017, 05:07 PM   #438
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
Re: finally come
I guess I need some more adjustments to mine. Type of welder, settings?
1964 Chevy Suburban 4x4
1966 GMC Suburban 4x4
Baketown Scotty is offline   Reply With Quote
Old 08-24-2017, 05:27 PM   #439
pimpston65
pimpston65's Avatar
Re: finally come
craftsman 120v set to min. temp and 3ish wire speed. I think im running non flux core wire, but I will check. no shielding gas... plus whats cool, when i flip to max temp and same wire speed i can weld 1/4" plate with same results!!!
Old 08-24-2017, 06:15 PM   #440
lower50's
lower50's's Avatar
Re: finally come
If your gas less it will be flux core wire.
1951 MG TD
Old 08-24-2017, 06:56 PM   #441
pimpston65
pimpston65's Avatar
Re: finally come
should be, but i think im running non flux core. i will double ck unless non flux core wont run through my machine.
Old 08-25-2017, 05:47 AM   #442
pimpston65
pimpston65's Avatar
Re: finally come
guess i was incorrect, here's the wire u been running.
Old 08-26-2017, 02:46 PM   #443
Baketown Scotty
Junior Member
Re: finally come
Thanks Pimpston65. I'm using gas on Lincoln 135, setting B(from A,B,C,D) and number 3 (out of 10). Next time out I'll take it down to 2 and see. Thanks.
Old 09-08-2017, 12:57 PM   #444
pimpston65
pimpston65's Avatar
Re: finally come
might be a bit a overkill, but i had the lift jig remade in steel. i also made it a tandem. now i use 2 hoists instead of one.
Old 09-08-2017, 12:59 PM   #445
pimpston65
pimpston65's Avatar
Re: finally come
i had the center one added also with the idea of being able to flip it and use it to lift from the back pointing in, but i may cut those brackets off.
Old 09-15-2017, 01:05 AM   #446
pimpston65
pimpston65's Avatar
Re: finally come
i must be lucky. found the rear cab support from desert valley auto parts. they cut it out,boxed and shipped for $250 btw the rear cab support is different then the pickups, so thats why i say i was lucky to find one not rusted away!!!
Old 09-15-2017, 02:54 PM   #447
lower50's
lower50's's Avatar
Re: finally come
Score!!!
1951 MG TD
Old 09-15-2017, 04:55 PM   #448
pimpston65
pimpston65's Avatar
Re: finally come
Score!!!
score is right!!! "soon" this puzzle will be complete...
Old 09-16-2017, 12:29 PM   #449
Bomp
Bomp's Avatar
Re: finally come
Can't turn back now. Instead of pimpstone65 we'll have to call you pimpdoc
Old 09-16-2017, 10:50 PM   #450
pimpston65
pimpston65's Avatar
Re: finally come
shut ur face, i like it!!!
