#426 |
Re: SkinnyG's '61 Apache
I'm really enjoying the blaster. It's a cheap 10 gallon pressure pot sandblaster. Lots of negative reviews, but I'm loving it. Absolutely loving it. Except when it's freezing outside, like today.
You'll want a good compressor. I mean cutting the mounting flange off the entire rear fender, and extending the fenders outboard maybe an inch or so. The bed/fenders are narrower than the cab itself.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#427 |
![]() ![]() ![]() Join Date: Jan 2018
I'd be doing the same that you are with the blaster, so that'll probably work for me.
I've seen many people widen older fenders to go over a dually rear by adding a strip of sheet metal through the middle of the fender. Maybe see if you can source another fender or two to get the amount of metal you want and the shape? Although, you do have the tools and skill set to make your own section, so might not need another fender or two
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#428 |
![]() Join Date: Dec 2012
IDK about that, but I always thought this idea to widen the rear fenders to match the inside to the outside was really thinking outside the box
JK |
#429 |
They recently did an episode on Car Fix (MotorTrend on demand) where they widened the fenders on a stepside in a more conventional style.
It can't be hard-they did it all on a 30 minute TV show.
JK Last edited by jkeating1; 01-15-2021 at 11:52 PM. |
#430 |
Ah. I'll look for that episode. 22 minutes plus commercials sounds right up my alley.
#431 | |
http://67-72chevytrucks.com/vboard/s...57#post6711157 http://67-72chevytrucks.com/vboard/s...483885&page=15 http://67-72chevytrucks.com/vboard/s...d.php?t=505805 http://67-72chevytrucks.com/vboard/s...d.php?t=650721 Yeah...... Nah.
#432 |
Season 9 Episode 13 "Patina Truck"
JK |
#433 |
Moderator
![]() ![]() Join Date: Aug 2011
Some impressive work going on in this build. Thanks for the pics.
#434 |
Not really motivated in the shop today.
Letting epoxy cure further before welding. Tidied a bit. I played around with some tubing and I think I have a decent plan for the panhard.
#435 |
Welded in, and I got to experiment with the "shrinking disc" I picked up - they are, indeed, magic. I likely won't spend a lot of time making this area perfect, absolutely zero people are ever going to see it (good place to experiment).
#436 |
My son worked some picture magic and come up with this:
#437 |
![]() Join Date: Nov 2013
I bounce between inspired by and terrified by your battle with rust. Thanks again for documenting all of it.
#438 |
One step at a time.
The whole project is almost overwhelming, if I sit down and think about it. Instead, I try to pick one thing, and do that one thing. Eventually, all the one things will get done and it will be done. And my truck isn't as bad for rust as others on here.
#439 |
I'm a bright yellow fan so I love the pic!
It must be satisfying to know your actual door gaps are better than the rendering.
JK |
#440 |
![]() Join Date: Jul 2014
[QUOTE=SkinnyG;8865936]One step at a time.
The whole project is almost overwhelming, if I sit down and think about it. Instead, I try to pick one thing, and do that one thing. Eventually, all the one things will get done and it will be done. Exactly sums up my project!
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
#441 |
In the momentary meantime, I cut the grooves in the boards for the bed on the table saw at work:
#442 | |
John 3:16 - Saved me... God Bless |
#443 |
Your sons render is cool! gives it that cool look and kinda like a comic book look in a real world setting. i like it.
#444 |
Two wrongs might make a right.
In cutting the bed wood, I accidentally grooved the outer boards that the bed sides sit on. They are apparently not supposed to be grooved at all. Except when I placed the new angle strips, I accounted for the groove I was going to put in. So it's probably going to be ok. We'll see.
#445 |
Was intending to work on the hood today, but instead I placed all the freshly grooved bed boards in to see how they looked, and discovered I mis-estimated board spacing by 1/32" per side, and need to trim the end boards some more. No matter.
Then I fired up the heat gun and scraped undercoating off the bed crossmembers, and fully welded the risers so I can do hidden bed-to-frame fasteners. And my hands and wrists have been killing me lately, so it looks like I'm not going to get much done this weekend.
#446 |
Grrr.
I ordered Trex decking from my local Home Depot. The three 20' lengths arrived, except the forklift operator drove over them, chipping one and breaking another. They ordered me two more 12' board to replace the two board lengths I needed, except while I said "non-grooved" what they ordered was "grooved." Didn't think it mattered. But guess what - it does. The "grooved" Trex is thicker by about 1/16". Which means the boards I placed at the ends are too thick, and I'll have to re-cut the 1/8" part of the grooves on the rest of the boards, as I referenced the end boards to make the last cuts, and the rest of the boards are thinner, so those cuts aren't deep enough. And of course, nobody is at the "special order desk" until Monday. Grrr.
#447 |
Dang....
#448 |
I cut the thicker "grooved" Trex board down about 1/16" by setting the table blade height to "scary" and trying to avoid finger contact as I pushed the thicker boards through.
Just as a reference: Trex Select comes in 5.5" widths. I used seven boards at full width, and the end boards were cut to 3.5" wide. This seemed to work fine, but you may want to do your own measurement. ![]() ![]()
#449 | |
#450 |
I'm having second thoughts about how I did the end board widths. I cut them so they did not go past the bolts. I think they should go past the bolts to better support the sides.
It looks like I should have cut the end boards at 4". Which I -had- done, and then second-guessed myself. Guess I'm ordering another board....
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 01-26-2021 at 11:20 AM. |
