#451 |
Re: 52 Project
Here's another good picture of the inner fender bracket if you're still looking (not mine):
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#452 |
Re: 52 Project
Thanks Bluejeep, dad ordered one from LMC truck and it seems like the right one. Looks just like the one in the above picture.
Do you know if the hood hinge bolts just a spacer or belleville washer on them? Seems like a lot of space between the head of the bolt and the hinge. I am talking about the hinge to hood interface. I should have taken some pictures of what I am talking about but didn't think about it. Bernie |
#453 |
Re: 52 Project
You do have the 4 sholder bolts for the hood and two for the springs
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#454 |
Re: 52 Project
here is pictures of the 4 large shoulder bolts for the hood and the two small ones for the springs
#455 | |
Re: 52 Project
Bernie |
#456 |
tobins 52 gmc
Re: 52 Project
Hi Bernie good to see you on here ,hope all is well .Would you have any pice of the E-Brake cables and what you are using .I would realy appreciate the info . Thank you Robert. will get som pic and info up soon
#457 | |
Re: 52 Project
Bernie |
#458 | |
Re: 52 Project
Is the bolt threads too long and bottoming out in the captured nut in the hood?
#459 | |
Re: 52 Project
Bernie |
#460 |
Re: 52 Project
Here are a couple of pictures of the hinge bolts that I am questioning. In the first picture you can see I found a thick washer to take up some of the space. I am not sure if I am missing something or if that is just the way it is?
Bernie |
#461 |
BIG CHEVY 3600 LONGBOX
Re: 52 Project
Those are shoulder bolts and it looks like the shoulder is too large to fit inside the hinge. Where did you get the bolts?
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
#462 | |
Re: 52 Project
We got them from LMC Truck, they are bottomed out against the hood and swivel on the hinge ok the only problem is the shoulders are to long...maybe. They might be ok or I am missing something else. Bernie |
#463 |
Re: 52 Project
Looks like you need a bolt with a shoulder about 1/4/1/8" shorter.
I would suggest you go to a stainless bolt. Not much more $ but will look better and longer. I bought a complete set of stainless for the entire truck. However when I need a few items I go to the Bolt Depot. Check them out: http://www.boltdepot.com/dimension.a...67&cs=244&cm=6
#464 | |
Re: 52 Project
![]() Bernie |
#465 |
Re: 52 Project
Bernie,
Do you think I need the firewall to radiator support braces ( I'm using a different firewall much like you) Also do you think I would need the inner fender support brace ( the one that the ebarke attached to, etc.) or can I just bolt it like the other side.. Right onto the toe board ( different toe bards than stock style too.) Thanks, Nick Nick Posted via Mobile Device |
#466 |
just sat here and read the whole thread, can't wait to see it finished, your doing a great job btw.
Markist oh well,..you'll have that!! ![]() |
#467 | ||
Re: 52 Project
Bernie |
#468 |
Re: 52 Project
If the bolt is bottomed out, can you use a washer (under the hex head) to close the gap where the shoulder of the bolt is showing?
#469 | |
Re: 52 Project
Bernie |
#470 |
Re: 52 Project
I have been busy doing everything but the truck for the past couple of months. Now that the weather has gotten a little cooler maybe I can get back on the truck. I mounted the AC unit and was trying to figure out the french head light kit last weekend. Here are a couple of pictures. I think this weekend I am going to try to weld in the buckets and see how they fit....has anyone done one of these before? I had Cajun post a few pictures but if anyone has anymore please post them for me...thanks.
Bernie |
#471 |
Re: 52 Project
Very cool Bernie!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#472 |
Certified Car Nut
Re: 52 Project
Hey Bernie, everything is look great and its nice to know you are still working on that truck. You've been missing in action, but then again so have I.lol
#473 |
Lost amongst the CORN
Re: 52 Project
Are those a Hagen french kit, they don't look like the kit Hagen sells?
Currently working on How To Videos and custom metal 70 Chevelle gettin Sliced and Diced Anything But STOCK 70 Chevelle SS455 not a typo its a BUICK BABY 49 and 72 Chevy Trucks restored to original...close to it Drommer Stor....Norwegian for Dream Big http://s969.photobucket.com/albums/a...lle/?start=all https://www.flickr.com/photos/47922830@N03/ Pictures of my work and projects |
#474 | |
Re: 52 Project
Bernie |
#475 | |
Re: 52 Project
Bernie |
