#451 |
GEARHEAD
Re: Over 25 Years Later, Finally My 71 C-10 Truck Build
Small update, Finished the first round of sanding and filled the low spots with metal glaze. I'm not sure I'll get back out there tonight (probably not), but I just need to knock the glaze down and re-primer the front driver quarter and top of the cab. Then another spray of guide coat and start all over again, hopefully with flatter results.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#452 |
what a discipline and patience..respect!
keep up the good work and I think I speak for all the followers if I say we're all rooting for ya ![]() |
#453 |
GEARHEAD
I appreciate that, really. I'm sure everyone wants me to go for the gold and do it all myself. Who knows, we'll see, no promises. I'll just keep taking little steps and maybe one of these days, I'll turn around and find it all done.
#454 | |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#455 |
Looks good! I'm going to door door skins soon. Subscribed.
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 ![]() My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
#456 | |
GEARHEAD
I think I'll copy this paragraph into the posts from back then also.
#457 | |
GEARHEAD
Had to drive up to Minneapolis this morning to bring my oldest home for a week of sitting on her butt resting. ![]() Once we got back I headed out to the garage and got my metal glaze sanded down. I wiped the dust off and since we are have a very windy day, I opened the garage door and the man door and started blowing as much dust loose as possible. The garage is covered top to bottom, side to side, in and out with primer/putty dust. I just sprayed some wax/grease remover on it, wiped it down and letting it dry off before the next layer of primer goes on. I'm going to spray it kind of heavy in a few areas because I think I'm going to need it. By tonight I should be right back to where I was on 2/5/2011, post 384. ![]() Hopefully with better results this time. Should just be spot repairs after this round of sanding though. Pics later.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 03-12-2011 at 06:07 PM. |
#458 |
VA72C10
I think you've been doing good one it. (Not that my opinion is worth much
![]() Every time you prime it and sand it's just going to make the paint job that much better.
#459 | |
GEARHEAD
#460 |
GEARHEAD
Got 2 coats of primer on, with a couple extra coats in the known low spots. I hope it's enough to block out good this next time. I have to work tomorrow and get some things done with the wife, so I'm not sure when I'll get back on my sanding block again. Probably in a couple days.
One picture, probably 8 hours of work... ![]()
#461 |
VA72C10
Only one pic?
#462 |
GEARHEAD
I had a short work day today, so I got some garage time. I started by cleaning up my work bench a bit. I was struggling to find space to mix primer and clean the gun, etc.
![]() But while I was doing that, I was letting the guide coat set up. ![]() Started sanding the hood and top of the cab. It's going alright, not perfect, but much better. I think I'll just have some spots to fix and it'll be good to go. ![]() ![]() This is the biggest low spot so far. I also had one small spot on the top front corner of the cab. Easy fix. ![]() The first 2k primer I used was from transtar and was recommended by a local body shop as what they normally use. Not having any other experience, I went with it and was not happy with how it sanded. I had also used SEM guide coat, which seemed very heavy to me, not just how I sprayed it, but it just seemed thick and spattery, which also made sanding harder. This time I used the Summit 2k primer and a duplicolor guide coat (also from summit) and what a world of difference. The primer was thicker and I had some trouble spraying it with my 1.8 tip gun, but it was filling better. I kept it thick when I was spot spraying, then added some more reducer for whole panel spraying and it was fine. The duplicolor guidecoat is much lighter and almost like spraying dust. This combination was much easier to sand. Can't even compare the 2. The transtar would clog up the paper in a few strokes, faster if you hit the epoxy. I was constantly clearing it or replacing it. The summit sands great and I had no problems with clogging the paper. I would blow it off with air sometimes, but I did not have to replace it once during the sanding I did today. Transtar= bad, summit= much better. I can't say its great because I haven't used anything else, but it worked great for me and was about half the cost of the transtar. I saved me money in paper also, which I also got from summit in rolls, and has been working good.
#463 |
VA72C10
Good info on your experience!
#464 |
looking good!!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#465 |
What brand epoxy primer did you go with? Did you have any problems with the recoat window before you shot the 2k primer? (i.e. did you have to scuff up the epoxy primer before you shot the 2k?)
1971 C10 Cheyenne Super Build Thread Here: http://67-72chevytrucks.com/vboard/s...d.php?t=411867 |
#466 | |
GEARHEAD
I wouldn't recommend doing it that way, but that's how it goes sometimes. I think the length of time the primer had to dry/cure and shrink (if any) before it was worked on makes a difference also.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 03-15-2011 at 05:15 PM. |
#467 |
GEARHEAD
Been a few days, time for an update. Yesterday I spoke with the local paint rep for Martin Sr about their products. They supply the local Napa and he gave me some tips, etc. Then today I was at the local body shop and talked to them a bit more about what I was doing, what my plans for progression were, and got some more (and conflicting) advice. I'm also going to check the other part store in town that handles Dupont and Nason products.
I was doing more blocking today and during that, when the mind tends to wander, I was thinking about a pneumatic in-line sander and if it would make this job easier. The body shop was dubious and said I was 'cheating', but loaned me a sander anyway. All I can say is that it has pros and cons. They will be doing some painting next week and said I could watch if I was around and learn. My main worry is that I know my own habits of laying it on too heavy and getting runs and/or orange peel. I want to see how the gun should be spraying, how heavy the coats should be, what it should look like when sprayed properly, etc. I think it will help me a lot to see it in person and not a picture in a book or online, or from a DVD. Pros: definitely faster, seemed to leave a pretty smooth finish using 180 grit, and it didn't load up too bad. Cons: The sander was pretty hefty and not really a shoulder saver for the work like I thought it would be. I was pretty tight between the shoulder blades after a couple hours work. It's a total air hog and I had to stop and let the compressor catch up more than any other tool I have. Sandpaper did load up more than hand sanding. I was also having some problems with the sander bogging down, not sure why, drops of oil didn't help. Probably just a well worn tool. Anywho, on to the progress and pics. Sanded some more, found a few lows and highs, but just a few. Overall, it is coming out pretty flat and I won't have too much rework to do. Got most of the hood done. ![]() About 90% of the driver door and bedside done. ![]() Then turned the truck around and got most of the other door done. ![]() Then got a start on the pass bedside. The lower portion had the most work done and I wanted to see how it came out. Pretty good, but needs a little more work done. ![]()
#468 |
VA72C10
Looking really good! Paint should lay down super slick!!!
#469 | |
spirit rider66
![]() Join Date: Oct 2008
Location: pahrump, nevada, in the bowels of the Mojave desert
:Chevy: If you don't run your own life,, some one else will. ![]() ![]() ![]() |
#470 |
GEARHEAD
Finally got a couple hours out in the garage to sand some more. Yippee! Finished most of the pass side bed and door, then started the tailgate again. It might need just a bit more touch up work, but the bedside and door are looking good. Hopefully I'll finish this stage of sanding this weekend. There are just a handful of small low spots to fix so far. I think I'll do a thin coat of primer to fill the sanding scratches then move on to the finer grit.
#471 |
Looks great. Hang it there you are almost there!
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 ![]() My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! Last edited by 67_ShortFleet; 03-24-2011 at 11:31 PM. |
#472 |
VA72C10
Nice job man! Keep at it....you're closer to paint than you were last week
#473 |
GEARHEAD
Thanks guys. I keep telling myself I am so close to paint, yet it seems like I never get closer. I think I'll get over that hump this weekend. I ordered another $40 worth of sandpaper last night, 220, (already have a bunch of 320), then 400 and 600.
#474 |
67cheby
![]() Join Date: Sep 2008
just start telling yourself ....... I AM SAVING A TON OF MONEY, I AM SAVING A TON OF MONEY !! that should be great motivation
#475 |
The truck is looking good! I would be ecstatic if any of my projects were that close to paint.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
