#451 |
![]() Join Date: Aug 2005
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Mounted the script:
![]() ![]() ![]() and tucked the wiring a bit. I need to make a metal version of that plastic cover... ![]() ![]() DS frame rail progress ![]() ![]() ![]() ![]() ![]() Last edited by Frizzle Fry; 02-14-2010 at 12:22 AM. |
#452 |
The shock towers didn't fully blend with the inners. I made this filler piece to improve the overall integration:
![]() ![]() ![]() ![]() Here's how it sits now. Need to make a few patch/filler panels for the DS and then on to the crossmember... ![]() |
#453 |
GEARHEAD
The work looks great as always, but I'm sorry. I have to comment on the outside yard shots. Cripes is it summer there already?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#454 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Nope not summer here yet good work as always mike...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#455 |
Dang !
"I feel the need for speed!"... as soon as I am done with my nap. |
#456 |
awesome work as usual , it does look nice and warm out there over here theres snow on the ground and temperatures near and below freesing
back on the oilfillercap idea , the cap i showed you prolly wouldnt fit its a barionet fitting like a radiatorcap i remembered the cap on that engine screws on . you might be able to cover it up with kindoff a jar lid shaped aloy/chromed piece gleued over the original cap just turn the top smaller and stick the metal over it , you might be able to use some aftermarked masterbrakecylindercanistercap (hmmm nice scrabbleword there) for it
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#457 |
VA72C10
![]() Join Date: Mar 2008
Looking great. Really like the extra filler piece and time to make it "right"
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#458 |
To quote a line from the movie 'Sex Drive': "Not bad, I've seen better"
![]() ![]() Curious though, are you going to paint the engine bay to match the exterior's original paint or is the entire car gonna get reshot? Also how do you keep down flash? Or do you grind it off before every update? ![]() Thanks
SEMPER FORTIS U.S. NAVY 97-05 USAF 94-97 Last edited by Mil-Spec; 02-13-2010 at 11:52 PM. |
#459 |
the pollock
wow frizzle....
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
#460 | ||||
Thank you sir! Thanks ![]() Quote:
Ah Yeeeeya ![]() Last edited by Frizzle Fry; 02-14-2010 at 12:26 AM. |
#461 |
It really does look great. What's the next hurdle?
SEMPER FORTIS U.S. NAVY 97-05 USAF 94-97 |
#462 |
Finish DS, front xmember, engine mounts, trans mounts, driveshaft, firewall/tunnel, control arms, steering, rear coilover mounts, fuel tank, fuel lines, wiring, start engine, heater install, rear brakes, brake lines, ebrake, disassemble/paint, reassemble, drive!
There's more and it probably won't follow that order exactly but that's the bulk of if. |
#463 | |
I had a V-8
Looks great!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
#464 |
Right, just give me an IV, Catheter, and cosco sized box of nodoz...
#465 |
dang i been away for a while and i missed all that. FF it looks awesome. love what you did with the gauge cluster. gives me ideas with my morris now.
as for your oil cap, you could get one of these from ebay and weld some other cover onto it. http://cgi.ebay.com/ebaymotors/BUDDY...item19b4c403ec http://cgi.ebay.com/ebaymotors/BLOX-...item5ad2e22f75 http://cgi.ebay.com/ebaymotors/Skunk...item4398e711a1 or you could get this one but i think it's plastic http://cgi.ebay.com/ebaymotors/JDM-H...item439cfe4954
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 ![]() |
#466 |
Back from Austin Tx. Thought I'd get to soak up a little sun down there and it f'n snowed while I was there!
I want to give a big thanks to Anthony Crivelli of Melbourne Australia for his extremely well-crafted write up on the project at Speedhunters.com. You can see more form him on speedhunters and his blog Progress Update: DS Frame/Shock-tower is in. The "filler piece" for behind the shock tower is made and tacked in. Running out of gas for the welder ...I'll have to come back to finish that later. On to the xmember now! Got the DS tie rod jig done last night. So now I can cut the center out of the S2000 xmember, plate it and add my tube laterals. Then it's time for engine/trans mounts and control arms ![]() For you pic hounds, here another item on it's way to the shop: ![]() |
#467 |
GEARHEAD
WOW! That tachometer goes all the way to 12,000!
Cool clock.
#468 |
When we last left off the DS shock tower had some air leaks left to be plugged ...so:
![]() ![]() ![]() add the filler piece to make it flow (final welding/grinding done later): ![]() On to the suspension crossmember. Got the DS tie-rod position jig'ed up like the PS (not shown) after mounting the rack on the stock xmember one last time: ![]() ![]() ...and lightened the crossmember (a little bandsaw action): ![]() This is all I need from the Honda piece to mount the arms to the frame. The rest will be fab'ed. ![]() ![]() Last edited by Frizzle Fry; 03-15-2010 at 01:53 AM. |
#469 |
xmember ends plated:
![]() ![]() ![]() ![]() other side: ![]() ![]() Installed. ![]() Just need to build the lateral connections now. But in order to do that, first I had to do this: Last edited by Frizzle Fry; 03-15-2010 at 02:10 AM. |
#470 |
the pollock
show off hehehe
#471 |
i allways said he worked fast but this is ridiculous
#472 |
sweet FF. lots of room to make the mount how you want it now!!
#473 |
![]() Been working a TON of OT again but I'll get the xmember laterals bent up and melted in this week. Then it's motor/trans mount time ![]() ![]() |
#474 |
i just noticed in your time laps. tubby sitting over there patiently with what looks like a bunch of parts sitting in him.
#475 |
Funny you mention tubby. I have been avoiding cannibalizing projects ...until yesterday. Stole a u-joint and DD shaft for the DriftBeam steering from tubby's parts pile
