Old 01-01-2013, 11:55 PM   #451
3r!c84
Badass
3r!c84's Avatar
Re: 86 squarebody made2drag
your uh drivers brake light it out....
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-28-2013, 11:48 AM   #452
Desert1957
Desert1957's Avatar
Originally Posted by watahyahknow View Post
there 2 3 4 link kits available that are bolt on and work with bags , they solve all those issues
Sorry to Hi-Jack this thread, but does anyone know who's bolt in kit this is?
Thanks in advance Desert
Desert1957 is offline   Reply With Quote
Old 01-28-2013, 01:48 PM   #453
SCOTI
SCOTI's Avatar
Porterbuilt.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-30-2013, 12:25 AM   #454
Sin7
Sin7's Avatar
looking good !
Sin7 = Luis
1959 Apache
Sin7 is offline   Reply With Quote
Old 01-30-2013, 12:30 PM   #455
truckzilla
truckzilla's Avatar
Unhappy Re: 86 squarebody made2drag
I wish I'd seen Nate's set-up before spending all I did on going with a four bar set-up and all the other brackets for the bags and all!
truckzilla is offline   Reply With Quote
Old 02-02-2013, 06:36 PM   #456
made2drag
made2drag's Avatar
Originally Posted by Sin7 View Post
looking good !
Thanks bro
made2drag is offline   Reply With Quote
Old 05-14-2013, 10:40 AM   #457
wraprail
wraprail's Avatar
Did you ever get your rear shocks mounted?
wraprail is offline   Reply With Quote
Old 05-14-2013, 12:00 PM   #458
made2drag
made2drag's Avatar
yes, i used front shocks from a 73-87. mounted bottom mounts to the leaf spring lower hardware plates and then upper shock mounts welded to the U shaped upper bag mounts. with the 2500's i have on the rear now the shocks only make a difference when i ride with the bags with less than 40 psi. i am currently looking for narrow but taller bags to fit in the space but allow me more lift and let the shocks work better. i think the only real answer is to use sleeve bags. ive heard they ride well.
my truck rode a 100 times better when i had 2600's mounted on the leafspring closer to the cab. i lost the ride placing them on the axle but i prefer them there for maintenance reasons, being able to see them in action while driving and knowing my truck will carry more load when i need it to
Old 06-15-2015, 12:08 AM   #459
64chevtruck
Howdy! Nice build I love those mid 80s C 10s. Nice work with yours ,
Have a good week,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 06-15-2015, 01:45 PM   #460
made2drag
made2drag's Avatar
Have a good week,
thanks!
Old 10-27-2015, 01:28 PM   #461
lower50's
lower50's's Avatar
Sweet truck does it drag when driving?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
