#451 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: How To: Ruin a Perfectly Good K/5
You could just haul it down to '*****en Rides' and be done! lol
#452 |
Still Learning
Awesome work dude!
#453 | |
A guy with a truck
Thanks, chipping away
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#454 |
A guy with a truck
Well, I finished up the kick panel and A pillar patches, then mocked up the outer rocker. Turns out, my bedside repair is just a touch off. Looks like it will need a pie cut to move it over to better align with the rocker
![]() Hope to wrap up this side early tomorrow and start tearing into the passenger side.
#455 |
A guy with a truck
Fixed the quarter--gap is much better now
#456 |
A guy with a truck
Plug welded the rocker in place, taking extra time to get the fitment right and I'm pretty happy with it. Also, this signals the end of rust repair on the driver side
#457 |
A guy with a truck
On to the passenger side: I started in the A pillar area, after getting the outer rocker cut off. Found pretty much the same damage in the floor support and rocker box just beneath it as the other side. Decided to open up the box (wish I'd done it on the other side) for better accessibility to patch the support and clean inside the box. Finished the day with patching the support and POR-ing everything I could reach
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 10-02-2016 at 01:46 AM. |
#458 |
A guy with a truck
Bonus: the kick panel and floor are solid on this side. Nice, shiny metal once I got to digging
![]() Second pic--anyone know what this is stamped on the firewall? This was hiding under a big glob of sealant, just above the floor seam.
#459 |
A guy with a truck
More progress: buttoned up the A pillar, coated the floor, and tearing into the B pillar. The last of the rust has been removed! It's all putting it back together now
#460 |
A guy with a truck
Ended here for the day: B pillar support welded in and bedside support halfway done. Ran out of shielding gas, so I had a POR party on everything I could reach on the passenger side.
Need to finish bedside support, fit outer skin and outer rocker, then rust repair is complete! (though I may have some work to do on the door bottoms...)
#461 |
Rust repair is coming along great! What is your protocol for welding adjacent to POR-15?
#462 | |
A guy with a truck
#463 |
I'm just glad to be here!
Looking Good! That stamp looks like it could be a QC mark or Prod. mark from the stamping plant...But I am just guessing...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#464 | |
A guy with a truck
![]() Took a break last night to spend time with the fam. I'll be back at it tonight with a fresh gas cylinder and hopefully get the quarter buttoned-up. Then its outer rocker and doors--can't wait to be done with the the noisy, dirty bits, though body work isn't much more fun...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 10-04-2016 at 12:15 PM. |
#465 | |
![]() Good work.
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15 GM 4 bolt 880 roller block, 062 Vortec Heads Comp Cams XR258HR-10, MSD Street Fighter HEI Edelbrock: Performer Intake 2116, 1405 Carb Long tube headers, 2.5" duals to Flow Master Super 40's Vortec Engine Build |
#466 |
This is such a cool build!! subscribed to see the finished product!!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
#467 | ||
A guy with a truck
![]() Quote:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 10-05-2016 at 12:47 AM. |
#468 |
A guy with a truck
Finished up the bedside support, then fitted and welded in the outer skin. This time, I did it with the outer rocker in place, so I don't have to come back and tweak the fit later...
![]() Tomorrow I'll fit the outer rocker and hopefully burn it in. Doesn't seem like it will need much massaging, but I haven't mocked up the door and fender with it yet.
#469 |
A guy with a truck
Burned in the pass rocker and then hosed down the inside of the boxes with rust encapsulator in a garden sprayer. Messy as hell, but worth it...
#470 |
![]() Join Date: May 2011
Good idea with the garden sprayer, I'm getting ready to squirt inside mine.Dont see the tension rod in that box, maybe just pic angle. Nice ruinin.
#471 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Great job! I'm lovin' the updates.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#472 | |
A guy with a truck
![]() ![]() Thanks a lot! I'll keep em comin'. Big push this weekend--we'll see how far I get
#473 |
A guy with a truck
Worked the first door--rust on both sides in the usual spot. Had to peel back the skin to find clean metal. Thankfully, the bottom is otherwise solid.
#474 |
A guy with a truck
Other side is better, but still needs a little love. Seems the trim was trapping water...
#475 |
Great work here. The intent still to just spot repair/paint?
