Old 02-27-2016, 03:09 PM   #451
racecougar
racecougar's Avatar
Re: Bringing the '65 back to life
Went tool shopping with Dad this morning, then finished up the wheel well lip on the driver side panel while he painted bed floor boards. Back to fighting the rust monster tomorrow.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 02-28-2016, 07:35 PM   #452
racecougar
racecougar's Avatar
Cut out rust, create a patch panel, weld, blend, repeat.
Old 03-05-2016, 05:43 PM   #453
racecougar
racecougar's Avatar
Fixed a bunch of small issues on the drivers bedside today (holes, dents, rust, etc.), then zipped out the rusty inner panels.
Old 03-06-2016, 05:32 PM   #454
racecougar
racecougar's Avatar
Nice, clean, inner panels all welded in. The drivers bedside is ready for bodywork and paint.
Old 03-07-2016, 10:28 AM   #455
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice progress!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-07-2016, 08:33 PM   #456
racecougar
racecougar's Avatar
Thanks! Hoping to knock out the inner panels on the passenger bedside next weekend.
Old 03-12-2016, 04:45 PM   #457
racecougar
racecougar's Avatar
Dad started bolting the floor boards into the bed today while I cut the inner panels out of the other bed side (hence all the dust).
Old 03-13-2016, 06:09 PM   #458
racecougar
racecougar's Avatar
Had to replace a bit more sheetmetal on the passenger bed side, but the inner panels are now fitted, tacked, and screwed in place. I'll finish it up when I'm at the shop next.
Dad finished installing the floor boards. Changing the layout to a uniform board width was well worth the extra effort, in my opinion. Don't mind the dust, I was making plenty of it again today.
Old 03-13-2016, 08:48 PM   #459
60chevyjim
60chevyjim's Avatar
nice job . I like the bed floor too.
who sells the inner bed side parts you have there ?
thanks jim
60chevyjim is offline   Reply With Quote
Old 03-13-2016, 10:08 PM   #460
racecougar
racecougar's Avatar
Thanks, Jim. Mar-K makes the inner bed panels, and they're great pieces.
Old 03-23-2016, 01:59 PM   #461
88k5jimmy
Originally Posted by racecougar View Post
Another aggravating day over at the shop. We started looking at/disassembling the steering columns to see what parts we'll use, what we need to get, etc., but I need to do some research. We're trying to use a '72 auto column with parts from the original '65 manual column, to eventually operate a cable shift 4L80E. Not exactly sure how that is all going to work yet.
What did you find out about swapping the 72 column in? I've read that the 72 year columns don't secure the same on the original mount under the dash and some people have used a large hose clamp to secure column to the mount. How did you secure the 72 column to the original mount?
88k5jimmy is offline   Reply With Quote
Old 03-23-2016, 07:29 PM   #462
racecougar
racecougar's Avatar
Finished that up a few pages back.
The column is secured to the stock column/handbrake mount via a hose clamp. You can see it in this pic.
Old 03-25-2016, 08:38 PM   #463
racecougar
racecougar's Avatar
Took last weekend off because I was sick, plus had other projects that needed to be done. Back at it today though. Finished up replacing the inner panels on the passenger bed side and welded up the holes in the top rail from the tool boxes.
Old 03-26-2016, 01:28 PM   #464
racecougar
racecougar's Avatar
Bed mock-up is underway. We're both anxious to get it painted and set it back on the frame now.
Old 03-27-2016, 03:39 PM   #465
racecougar
racecougar's Avatar
Fit the tailgate, squared everything up, drilled the rest of the holes in the front bed panel, then started addressing the tubs. Looks like we'll need to add ~5-3/4" from each of the original tubs to the ones in the photo. Unfortunately, the portion needed from the original tubs will require a fair amount of repair work (lots o' rust).
Old 03-28-2016, 03:48 PM   #466
racecougar
racecougar's Avatar
Got a good start on the driver side tub today. I'll get back to it next weekend.
Old 04-02-2016, 06:36 PM   #467
racecougar
racecougar's Avatar
Started welding up the other tub this morning.
Old 04-03-2016, 04:00 PM   #468
racecougar
racecougar's Avatar
Somewhere during the production run for these trucks, GM decided to change the stamping for the rear wheel wells. The original '65 pieces featured an additional character line (a little ledge) that the other set of tubs did not have. I spent the morning correcting that, as well as the bolt hole locations on the passenger side tub. I'll address those issues on the driver side tub next weekend.
Now we're getting somewhere. The passenger side tub needs a little rust repair, then it will be ready for body work and paint. The driver side tub still needs the seam welded, the extra character lines deleted, the bolt holes relocated, and the rust repaired before body work.
Old 04-09-2016, 04:48 PM   #469
racecougar
racecougar's Avatar
Finished welding up the seam on the driverside tub today, then took the afternoon off to go morel hunting with the wife.
Old 04-10-2016, 05:09 PM   #470
racecougar
racecougar's Avatar
Spent the better part of the day repairing rust in areas no one will ever see. At least I'll know it's taken care of.
Old 04-16-2016, 04:23 PM   #471
racecougar
racecougar's Avatar
Deleted the extra character lines and the incorrect holes in the driverside tub today. All that's left is to locate, drill, and file the mounting holes on both tubs, then everything is ready for bodywork and paint.
Old 04-17-2016, 06:13 PM   #472
racecougar
racecougar's Avatar
The tubs are in and fit to the bed. We had them in and out more times than I care to count today. Just need to drill the five holes in the bed wood and three more holes in the bed side for the passenger side tub, then it's all wrapped up.
Old 05-01-2016, 02:23 PM   #473
racecougar
racecougar's Avatar
Been busy lately, but I was able to get back to the bed for a little while this morning.
Old 05-01-2016, 06:06 PM   #474
RANDY COX
RANDY COX's Avatar
Hey, Just read through your build and man that's a lot of work but I see you had some good help your DAD...I thought my truck had some rust. But it all had to be replaced to. So I know the amount of work it takes...a lot. I'm still in stages of a build myself my son was supposed to help but he has his own project so Daddyo is pretty much on his own...Anywho great job and keep plugging along one day it'll be done..maybe not finished as I don't think they ever get totally finished buy hey.. And Congrats on your marriage...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-08-2016, 04:20 PM   #475
racecougar
racecougar's Avatar
Thanks Randy. It sure is a lot of work, but it certainly can be enjoyable.
Ah, the scent of filler in the air. Smells like progress, and sore arms. Bumped the dents out of both tubs last night, then cleaned up the sheetmetal this morning and started working with filler.
