#4826 |
Re: What did you do to your truck today!
I finally got around to installing my new dash pad. I'm glad I have relatively small hands.
(before and after pics)
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
#4827 |
C/10 junkie
The new dash pad makes a big differance.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#4828 |
Replaced a tail light, and de-oxidized my tail light lenses and side markers on my '70 c20!
1970 C20, SM465, Eaton Ho52, HD coils, NO PB/PS/AC, 250 I6, Wood bed. All original minus a tune up! http://67-72chevytrucks.com/vboard/s...d.php?t=545486 Gentlemen wear a bow tie. |
#4829 |
Thanks! I agree! I've just been driving it and upgrading little stuff since I bought it......like getting the dash lights, wipers, and heater control working again, rebuilding the carburetor, etc. This is really the first upgrade/fix that actually makes it look like anything has been done!
#4830 | |
![]() Join Date: Dec 2006
![]() Posted via Mobile Device
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#4831 |
The bed's not on it. We have to cut the bedsides (same story as front) and get a 2 piece driveshaft made. Soon...(famous last words)
Unfortunately when we went to put the Porterbuilt hood hinges on we found some rust on the cowl right where the one hinge would go, probably wouldn't support the hood on the driver's side, so--since I'm only running 18's--we're going to try the stock hinges and cut away the inner portion of the fender AND the bottom of the hinge and see if it will lay out. The tire diameter is small enough that the heater box won't rub unless it's fully aired out, so the hinge thing may work. Otherwise it's sheetmetal repair time--which I wanted to hold off on for a bit. I can't weld, and I'm running out of money! ![]() |
#4832 |
At least it's not a photoshop of the drop this time. It's for real! Although, technically, I did blur the background in photoshop because it looked cooler, and those two blurred ladies were a bit hard on the eyes.
#4833 |
Jim, same story for me...first car show...they went crazy, and I won a trophy! This was on Saturday.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#4834 |
That's awesome!!
I was thinking maybe it was lame to bring my incomplete truck there, but people were all over it, while the immaculate restorations were looking lonely. |
#4835 | |
#4836 | |
Let a rat rod pull in,they run to it.I usually do. |
#4837 |
Me too.
#4838 | |
![]() Join Date: Jan 2006
BTW, nice truck! ![]() ![]()
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
#4839 |
Thanks! Yes, if you search "tilt-shift" you can see just the opposite effect can be created using a camera--or simulated in photoshop--with real scenes, making THEM look like models. Cool stuff.
#4840 |
Dropped it off at a local shop to have the exhaust done. Pics to follow when I get it back...
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
#4841 |
Thanks! I'll have to check that out. I'm kind of a photographer buff (very amateur), just don't get to spend enough time with a camera any more!
#4842 | |
![]() I have to tell you that I love the Torq Thrust on your truck. They are hands down my favorite wheel ever. I don't care how many people run them, they are simply awesome
#4843 |
Removed booster, steering column, modded firewall for Painless harness and painted firewall.
Wilson 1972 Cheyenne LWB, 350ci TH-350. Restoration in progress. |
#4844 |
drove it around the block for the first time since we brought it home! its far from being assembled but it was good to have it moving and stopping under its own power!
#4845 |
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! ![]() |
#4846 |
I've got grease on my mind.
Lets see..Installed and removed 9 headers...still trying to find a set that fits.
Shortys - 69648 - Fits 67-72 C20-C30 but not C10, kicks out to the side too much and hit frame, collector is in "C" channel, not ideal Tri-Y's - no part number - Fit beautiful on the driver's side, pass side only hit; 1. frame 2. Brake Line 3. Starter 4. Cross Member 5. Lower A-Arm 6. Trans Cooler Lines and the outlet points toward the flex plate cover Mid Length - 68600 - fits Camaros and Chevelle - both front tubes hit upper engine stand offs, pass side a bit worse Full Length - 69890 - Fits 67-87 C10- Pass side fits but hangs about 4" under frame, could not even get driver's side installed with almost everything removed The copper colored ones are what I started with and the set that is going back in. Hedman has a new Mid Length - 69016 - that no one stocks yet but they tell me they used an actual truck for fitment. The pass side looks good but the driver's side looks like it might drop a bit too soon. We'll see, if I can find a set. |
#4847 |
HI GUYS!! NEW HERE GREAT SITE!!
TODAY I removed floor vents and rstored them with paint, new seals,stainless nuts and bolts and custom brushed stainless knobs! ![]() |
#4848 | |
#4849 |
RAT1968 '68 Cab/'71 Parts
Had a hneated discussion with someone from the California DMV. She was crazy enough to send me her FAX no and I peppered her with FAX'es until she called back...
Now I have her phone number.....I got an ACTUAL PROMISE with someone with a REAL NAME that the tags will be here in seven days....We'll see. In the meantime, I've got time on my hands until the trailer comes to get me for the exhauset appointment tomorrow afternoon. So, I learned a new detailing "trick"...At least, new to me. I had banged the brand-new tinted rear window and left a small hole in the tint. There are a couple of other dings in the tint in various windows. I took this product "Nightshade" I had on hand for the tail and front turn signal lenses. Hit the spots with a very very slight amount of this on my brush. A couple of these pics show the interim procedure. But best results for me were attained by letting the stuff COMPLETELY dry and then slide over the area with a sharp safety blade. It's not perfect. But better. Good enough to live with for this driver.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#4850 | |
![]() Join Date: Mar 2012
Wow thats insane! I thought shorty Chevelle headers fit? I cant believe that with all the c10's out there, nobody has anything that bolts on and tucks out of the way. I have long tube headers on mine and they hang way below the frame. I need to replace them before I bag the truck. I am looking forward to any other info you post about this. Hopefully the headman headers fit and dont hang down. I was going to order chevelle shortys but I Better hold off for now... Lonnie
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
