#4826 |
![]() Join Date: Oct 2016
Re: What did you do with your truck today, Part 3
#4827 |
Thank you and everyone else on the forum that helps me out. This is my first time doing anything on this level. I have only been a R&R car guy before. I build dry ice manufacturing plants in my real life. I have a good understanding of principals but without the help of others I would be stumbling in the dark. I am and will be forever grateful.
#4828 | |
#4829 | |
#4830 |
Thanks for the link. I did figure out that there is a serial number (? ) on the front of the right axle tube. my problem is the many years of grease and dirt covering it up. looks like next weekends project is to soak the area with brake clean and take a wire wheel to it. hopefully i can find the number.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
#4831 | |
For extra credit, media blast the front of the right tube while it's in the car. Good Luck!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
#4832 |
Hey dransport, if you dont mind the smell, spray a little diesel on the area and let it soak. Castrol super clean works well too. If you get it cleaned but find it hard to make the numbers out try a quick coat of lacquer, let it dry, then use a fine file lightly over the area, or sandpaper on a wood block. This removes the paint from the tube but leaves the paint in the divets made from the number stamps. It has worked for me before for things like this.
#4833 |
I think I'm ready to try again. One of the problems I had with the 4 jaw chuck was getting it tight enough to suit me without deforming it. I went back to the 3 jaw because it lines up with the spokes (6) in the pulley. I also made this thing to hold it against the chuck for piece of mind. I figure if it slips it might not destroy itself and me. I also made a new and improved tool. Nothing left but the doing. I have .004" runout.
#4834 |
Well I haven't failed yet because I haven't given up. It is now a quest. Here's what I know. Pulley is 6061 aluminum. Coating is type 3 anodizing .002"-.004" thick. The tool bits I'm using are not some overseas sweat shop steel they are repurposed Armstrong high speed cobalt. I think it's pretty hard stuff. The test pulley I made is 6061 aluminum. It cut it like butter. The same tool worked terribly on the first groove on the real pulley. After looking at it I thought I forgot to put a relief cut on the front of the tool. The manufacturer and the anodizing company both told me that machining the finish was no problem. After thinking about it they have probably never done it. I sanded the finish off the face for countersinking and it was a nightmare. It laughed at aircraft stripper and we get the good stuff here. I spent a lot of time making the second tool and was quite proud of it. I checked my tool height and set my RPM's. I ran it in and it Angelina Jolie'd itself and was gone in 60 seconds.
it barely scratched the surface, more like a dent. I took an insert tool and came in from the side at .005" and shaved it off. Gone baby gone. I ordered a nice grinding wheel and some HHS tool bits, probably from a sweat chop overseas. Sorry so long. Thank you for your time. |
#4835 | |
I am a little concerned about the .004" runout. I could see that causing a resonance at some RPM if the grooves are not concentric with the O.D. of the pulley, and with the shaft that it's mounted on.
#4836 |
Well it could have been the coating? I cut it off so it's round now I guess. My secondary radiator has an electric pump on it so it wouldn't strand me. at least the A/C and P/S would still work.
#4837 |
That should do it. Looks like you're ready to soldier on!
#4838 |
I finished my water pump pulley! I'm calling it a big win. It seems my problem all along was the coating. This is the first time I made a lathe tool from scratch. I used a jewelers file and 500 grit sandpaper to radius the tops and deburr it. Thanks for everyone's advice and support. A special thanks to idbeast. I still need to have it anodized black but they have a $100 minimum so I might wait until I have more to take in.
#4839 | |
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) Last edited by DransportGarage; 04-03-2021 at 02:32 AM. |
#4840 |
![]() ![]() Join Date: Oct 2014
Impressive work!! Top notch
#4841 |
Got the new calipers and stainless brake lines installed after the false start last weekend. I also cleaned inside the front wheel wells and the front half of the undercarriage, including the chrome oil pan, pulleys, etc...
Tired and sore from rolling around on the floor for 2 days. |
#4842 | |
#4843 |
I took the panel truck out for the monthly gathering at the local country store. Fun little show with a couple dozen cars, live music, and food vendors.
BTW: I got my new gauges installed. Dolphin sent me a free replacement set, and they work perfectly. Kudos to Dolphin for great customer service!
1951 Chevy Panel Truck Last edited by MiraclePieCo; 04-05-2021 at 04:55 AM. |
#4844 |
![]() Join Date: Aug 2011
Removed and replaced spark plugs. Holy crap were they covered in thick black carbon. Its amazing the truck started. Seems I've been warming her up with the choke too much. Starts so much easier with the fresh plugs. Had black coming out the tail pipe as well. To much choke.
Pat 1949 unmolested Indy Farm Deluxe AD 1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544 |
#4845 |
Dunno if you are familiar with the old stuff, manual chokes etc, but in general if it is running like it has a big cam in it, "loping", then too much choke. You gotta babysit the old girl, release the choke a little at a time and enough so it still runs but just on the edge.
#4846 |
been driving the wheels off of it lately. love when everything works.
#4847 | |
I know what you mean. After getting my gauges sorted out I'm feeling real good about my truck.
1951 Chevy Panel Truck |
#4848 |
Broke the dang master cylinder cover. I actually remembered to keep the battery charged this year so I could get it fired up quickly when I found the right day for first drive. Yesterday was the day. Brake pedal was low so I attempted to open the stock master to check fluid level and it broke in half. Grumbledy grumble. The cylinder date codes to the truck correctly and I'd like to keep it so I guess it's off to Ebay to try and find a replacement cover for cheap.
#4849 |
I went to Wisconsin and picked up another chassis for the 53 3100. It's in nice shape and was only $150 from a guy on Stovebolt. It should have taken 8 hours but someone put Chicago in the way so it took 11.
#4850 |
![]() ![]() Join Date: Nov 2008
I FINALLY finished my dad's old masonry box for use in the '55 bed. Considering what I started with I think it finished out nicely. The Chevrolet script is from a 1954 car sourced from eBay.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
