#4926 |
Chevy Enthusiast
Re: How about some pics of 73-91 crew cabs
Have you checked classicindustries.com? Idk if they're cheaper than rockauto but they were about half the price of what I got them for at oriellys.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#4927 |
[quote=CamaroChris;4828975]Does anyone know the color code to the blue on this truck??? I love it and need the code for the painter
#4928 | |
Stalker Nate
Yeah being only 20 min from the truck crossing & mail box helps. Pricing down there is 50% cheaper for HD pads compared to here. It's amazing that you can get HD pads for $50 set there vs $100 here for the good stuff. Usually I wait till I have a few items to order though to make it really worth my time and to save more. At least this way I can rebuild the whole rearend for $400 with HD parts and not have to skimp on it ![]() Didn't know about the height issue although any lifted vehicle can get a VI. Mine will stay stock height though since I need easy access to the bed. If it were just a toy it'd get 4" of lift asap haha Posted via Mobile Device
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
#4929 | |
Stalker Nate
![]() Posted via Mobile Device
#4930 |
![]() HERES MINE AFTER I CLEANED IT UP A LITTLE |
#4931 |
Chevy Enthusiast
That is nice!
#4932 |
Pic of my 1989 when I bought her.
R3500 with a 454 under the hood. I fell in love with her when I smoked the duallys in the yard even though I had that big steel service box on the back ![]() ![]()
Head down, ass up, smoke rollin! |
#4933 | |
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#4934 | |
Stalker Nate
#4935 | |
forest service sure knows how to order them! G80, locker HC4, 4:56 KC4, oil cooler LE8, 454 NL2, dual tanks NY7, t. case skidplate TP2, dual bat. V10, cold climate (block heater) V01, hd rad X6W, man. hubs Z53, gauges their color combo's suck though 62V, saddle int. 9V5, woodland green |
#4936 | |
Stalker Nate
I know for sure its woodland green with 4.56 gear, t-case skidplate, cold climate/block heater package and a fleetside dually haha I got that much out of the codes, which is also the obvious stuff ![]() Posted via Mobile Device
#4937 |
some of your codes are different than mine, '85 C/K, '90 R/V series. here's
a good place to decipher the rest of you spid RPOcodes.com |
#4938 | |
Stalker Nate
Now I just need to get a new tailgate and canopy or find a really cheap utility canopy to throw in there for when I travel. I just missed out on the perfect canopy for free!! I missed by minutes too as the guy posted on CL. Some many out there though I figure another free or less than $200 canopy will pop up again.
#4939 |
http://www.gm-trucks.com/rpo-code-lookup/?find=AEM
you will be able to find the rest of your codes here |
#4940 | |
1SB = PACKAGE-OPTION 02 (1SB) 60I = INTERIOR TRIM COLOR INTERIOR TRIM COLOR(60I) 60W = TRIM COMBINATION,VINYL,DARK COGNAC (60W) 9V5 = COLOR COMBINATION,WOODLAND GREEN (9V5) A01 = WINDOW,TINTED GLASS(ALL WINDOWS) TINTED GLS(A01) A52 = SEAT,FRONT BENCH,3-PASSENGER FRT BENCH ST(A52) AS3 = SEAT,REAR UTILITY R/SEAT(AS3) BS4 = INSULATION,CAB BACK PANEL CAB BACK INSULATION(BS4) C7A = GVW RATING(10000 LBS) 10000 GVWR(C7A) CMD D2C = GEAR SPEEDO DRIVEN (3866919) (D2C) D44 = MIRROR,OUTSIDE,BELOW EYELINE(PAINTED) O/S PAINTED MIR(D44) E5Z E63 = BODY EQUIPMENT,FLEETSIDE PICKUP BOX FLEETSIDE PUBX(E63) E6J E9Z FLT G60 = SPRING,REAR AUXILIARY RR AUX SPR(G60) HC4 = AXLE,REAR,4.56 RATIO 4.56R(HC4) JB8 = BRAKE SYSTEM,HYDRAULIC POWER DISC,DRUM HYD PWR DISC/DRUM BRK(JB8) K05 = HEATER,ENGINE BLOCK ENG BLK HTR(K05) K81 = GENERATOR,66 AMPERE 66 AMP(K81) KC4 = COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4) L19 = ENGINE,7.4L(7.4N),V8(E.F.I.) 7.4N(L19) M40 = TRANSMISSION,AUTOMATIC 3-SPEED(THM400-475/3L80) 3-SPD A/TRANS(M40) MX1 = TRANSMISSION,AUTOMATIC(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX1) NA5 = EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) NY7 = SHIELD,TRANSFER CASE TRFER CASE SHLD(NY7) P10 = CARRIER,SPARE TIRE SPA TIRE & WHL CARR(P10) R05 = WHEELS,DUAL REAR DUAL RR WHL(R05) R8L TGK = SPECIAL PAINT SOLID, USED FOR ORDERING PURPOSES. SPECIAL PAINT(TGK) U73 = ANTENNA,FIXED FIXED ANT(U73) UN9 = RADIO SUPPRESSION EQUIPMENT RDO SUPPR(UN9) UP7 = RADIO,PROVISIONS FOR MONAURAL INSTRUMENTATION RDO PROVISIONS(UP7) UT5 = RADIO,AM,ETR,INCLUDES CLOCK AM CLK RDO(UT5) V02 = RADIATOR,HEAVY DUTY,INCLUDES HEAVY DUTY TRANSMISSION OIL COOLER HVY DUTY RAD & TRANS OIL CLR(V02) V10 = COLD CLIMATE PROVISIONS OPTIONS COLD CLIMATE PROVISIONS(V10) V43 = BUMPER,REAR STEP(PAINTED) PAINTED STEP BPR(V43) V73 = VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) VXS X88 = CONVERSION CHEVROLET CHEVROLET(X88) XYL YD3 = AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3) YK6 YYL = TIRE REAR LT215/85R16/D BL R/PE ST TL OOR (9590797) TIRE(YYL) Z31 Z49 = MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS(CANADIAN) CANADIAN(Z49) ZE5 = TRIM LEVEL,BASE BASE LVL TR(ZE5) ZN3 ZYL = TIRE SPARE LT215/85R16/D BL R/PE ST TL OOR (9590797) SPARE TIRE(ZYL) I got that far. ![]()
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#4941 | |
Stalker Nate
#4942 |
Other than asking our resident square body assembly line supervisor (Keith Seymore), I do not know. Like you say, most are self explanatory, others...not so much.
#4943 |
most of whats left is in-house codes, except for the tires
ZN3 is a tuff one. FLT, sales processing option (fleet) R8L,control sales item XYL, front tire, LT 215/85R16D YK6, identification (SPO) Z31, price sheet identification |
#4944 |
Chevy Enthusiast
Have y'all looked under the seat for a build sheet?
#4945 |
Posted via Mobile Device[PHP][/PH
How do you post a pic from a phone Posted via Mobile Device |
#4946 |
1987 Silverado
#4947 |
Here's my '87 Silverado with A/C... its a work in progress..lol..but im off to a great start..
#4948 |
What Hump?
Mike think you want your pics inthe shortbed not crewcab section. Nice truck though.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
#4949 |
Ooops... Im new...havent got used to posting yet on here.. Thanks!!
#4950 |
Shined up for our church car show
Tags |
crew, crew cab, square body, squarebody, squarebody.net |
