View Poll Results: 13" Brakes: Any Interest? | |||
Yes, interested | 195 | 95.59% | |
No thanks | 9 | 4.41% | |
Voters: 204. You may not vote on this poll |
06-15-2007, 12:39 PM | #26 |
Happy to be here
Re: How Much Interest: 13" Big Brake Upgrade
Scoti, I'm not sure who you have lined up on this but they are a lot of "do it yourself" options out there. The only thing that needs to be manufactured is the caliper mounting bracket, and mod the spindle to mount it.
You can machine down a 70-87 (5x5) hub and use C-4 hats to mount the 13" PBR C-4 rotors. Of course the hats would have to be re-drilled to 5x5 pattern. The brackets attach to the truck spindles, and you can mount C4 Calipers. The hats, rotors, and calipers can be bought brand new from parts suppliers, and the saving is very big.
06-15-2007, 01:43 PM | #27 | |
But I would prefer to have a hub that was intended for the purpose rather than one that wasn't (old rotor being cut down) & C4 13" rotors are kind of thin ( <1.25") so I prefer a thicker rotor for my heavier truck.
06-15-2007, 03:15 PM | #28 |
I have B body spindles on my 67 Chevelle with hubs cut down from Camaro rotors, 12" Corvette 1 1/4" rear rotors and Suburban calipers (3 5/8" piston). Cutting down the truck rotor should not be a problem.
The setup has been on the Chevelle for years and I have not had any problems with the custom made hubs. It works great! Dave |
06-15-2007, 03:46 PM | #29 |
Cruzzzn' Vet
Sounds Good
John |
06-15-2007, 04:16 PM | #30 | |
The main concern is making sure it's done responsibly. How much structural evaluation of the hub is actually done after the machine work? Did you just machine it & install it with 'real world' or 'on the road' testing? Do you have any pics?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-15-2007 at 05:18 PM. |
06-15-2007, 04:46 PM | #31 |
sign me up!!!
06-15-2007, 06:20 PM | #32 |
WTB this ad
What diameter wheel would you have to run to clear brakes that big?
06-15-2007, 07:06 PM | #33 |
17" minimum is typical for 13" rotor/upgraded caliper brake systems.
06-15-2007, 08:39 PM | #34 |
The Crazy Machanic
sounds cool and the power i got more stoopping power is always nice to have.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
06-16-2007, 12:48 AM | #35 |
I hated to vote "no thanks", but my truck is 3/4 ton, and my budget is one ounce.
1970 long fleet, 355 4 speed, primer, walnut goodies |
06-16-2007, 10:42 AM | #36 |
Hollister, CA.
DId you mean 63 and up ?? I have a coil sprung front end.
Defiantely would love the big brakes.....However, 13" brakes wont work with a stock 15" wheel......wonder if they make 17" wide-whites !!! John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 06-16-2007 at 10:45 AM. |
06-16-2007, 11:36 AM | #37 |
Yes. Check out Coker Tire.
06-16-2007, 01:00 PM | #38 |
If these get done before i go and buy a disc setup fro early classic then count me in. Heck, even if you dont finish until after id still be interested.
06-16-2007, 01:49 PM | #39 |
im really interested since i have to start thinking about what to do for the stopping issue for my 66 resto
06-19-2007, 09:12 PM | #40 |
I think I would like to run these mothers and they should bolt right up if this kit gets made.
06-20-2007, 08:25 AM | #41 |
Tot Roddin'
I'm on the bandwagon on this one! Put me down for front and rear (when available of course!) Can't afford those Baer and SSBC kits....
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-20-2007, 02:55 PM | #42 |
I am interested if you could do a matching front and rear set
06-20-2007, 03:15 PM | #43 |
They're also interested in this. It would be most likely be a PBR single piston rear as standard.
06-21-2007, 07:28 AM | #44 | |
Regular guy
I love the look of those ZO6 calipers but have you checked out the price for the pads for those puppies? I new they weren’t cheap but they were almost as much as the caliper itself!
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. |
06-21-2007, 09:50 PM | #45 |
Some guys over on ls1tech were saying you can get the pads for around $130 Hell that is still a lot of mo ra doe for me. I will stick with the c5 calipers for sure and just run a 14" rotor. You have a good point though about the price of the zo6 c6 stuff.
06-22-2007, 03:28 PM | #46 |
Not sure if you have contacted either of these guys in your research. They have both designed C5 brake conversions for A/F Body Chevys. If they do not have a kit for our trucks, they may be willing to create one if there is enough interest.
I am not sure how to post a link, but here are the websites: http://www.kore3.com/ http://www.engineeredvelocity.com/ |
06-25-2007, 11:17 AM | #47 |
im interested in a set if possible.
06-26-2007, 11:10 PM | #48 |
i'M INTERESTED IN AN UPGRADE BUT ONLY FOR A 4X4 AND BOTH FRONT AND REAR.
06-27-2007, 08:36 PM | #49 |
Scoti you know you can count me in since we were discussing this a couple weeks back...Im way in
06 Crew Cab GMC[/B] on 22's 07 Duramax 4x4 Lifted Maxed Out! 1972 2WD K5. 89k miles. Soon to be bagged, LS1 and bad! 1967 Short and Wide. Soon to be an LS1 and bagged |
06-27-2007, 10:42 PM | #50 | |
I'm still going forward & trying to make this happen .
